05-17-2022, 05:27 PM | #1 |
Rep 153
Wheel offset question
Hello,
I have an G06 with 740M wheels. I am looking to buy a set of wheels. I have square setup from factory even though it was an m-sport package. Didn’t realize in US they come with square setup vs. Staggered. So I am assuming the factory wheels are 9Jx20 ET35 (P/N 36118071996) I am looking at aftermarket wheels and want to go staggered setup. However the offset isn’t the same as factory Fronts are 10 and the Rear are 11 instead of oem specks of 9 in the fronts and 10.5 in the rear. What should I expect if I choose to install these, like any suspension or clearance issues or anything else I should be congnizant of? They can forge to my specifications, but had these in stock so I thought I’d ask here as to what to expect. Thanks, |
05-21-2022, 12:06 PM | #2 |
Rep 1,340
hi, I recommend starting with OEM spec offsets plus the equivalent of 15mm spacer up front and 20mm in the rear. You can also go much more aggressive than that, the equivalent of 20mm spacer up front and 28mm spacer in the rear.
Ultimately it is a preference but 15mm/20mm would be a starting point. Are you planning on lowering your X6? |
