01-16-2021, 09:11 PM | #133 |
Yngwie J Malmsteen
27
Rep 68
Drives: F93 M8 GC - G07 X7
So the error was a front broken ride height sensor connector. Installer broke the tab and it came loose. Told them about rear awaiting that information on Monday. $245 for connector and install.
155ND903.50 |
01-17-2021, 09:27 AM | #134 |
Rep 3,499
Thanks for the update, I was thinking it would have been an issue from installer. Curious about the rear as well.
2022 M8 Comp Convertible
01-17-2021, 07:44 PM | #135 | |
57
Rep 326
Drives: G05 X5 30d, Boxster GTS (981)
01-18-2021, 11:08 AM | #137 | ||
617
Rep 361
It's more stable on the road and car feels more absorbent of the bumps. Then again, driving on NYC roads, it's hard to give a proper observation....lol |
01-18-2021, 01:05 PM | #139 |
Rep 3,499
First its not that simple of an answer... Two things really matter, your relationship with the Service provider (OEM, 3rd party certified), and if you are willing to fight legally if BMW refuses to warranty suspension components if one to fail.
I've talked with my SA, he has done warranty work with other vehicles with just springs replaced.. He said where BMW tends to draw the line is a full coil over replacement. Meaning you remove the OEM active dampening. That being said there are a lot cases I'd have to dig some of them up where companies have refused to warranty, and court sided with owner. Meaning in the US a company who refuses to warranty OEM parts due to aftermarket accessories must prove that aftermarket part caused the failure. Its called The Magnuson-Moss Warranty Act you can google that.
01-19-2021, 04:32 PM | #140 | ||
5403
Rep 10,825
r33_RGSport12803.00 |
01-19-2021, 06:14 PM | #141 | |||
29
Rep 39
2009 E92
2013 S4 2016 RRS SC 2018 440I GG 2019 M550i |
01-19-2021, 08:32 PM | #143 | ||||
29
Rep 39
2009 E92
01-19-2021, 09:01 PM | #144 | |||||
12803
Rep 18,627
But not available yet. H&R sport spring is ideal if you don't care about the rake. While H&R VTF or MSS will allow you to adjust the rake. It just the VTF cost more while allowing to go lower, which is higher risk at shortening your shocks life. My vote on solution to slamming is to go with full coilover. BTW, my MSS stocking order just landed. So, I'll post pictures on local customers ride that I'll be doing.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com March SALES!! Evolution Racewerks - Until 04/01 | PM for DEALS MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
01-20-2021, 01:01 PM | #145 | |
Yngwie J Malmsteen
27
Rep 68
Attached is the alignment sheet. Still has camber upfront. Question. Does this look ok? |
QF8221.00 |
01-20-2021, 01:44 PM | #146 | |
Rep 3,499
01-25-2021, 09:57 PM | #147 |
12803
Rep 18,627
Finally they are here.
01-25-2021, 10:07 PM | #148 |
2962
Rep 1,765
Getting mine installed tomorrow!
01-25-2021, 10:11 PM | #149 |
12803
Rep 18,627
01-25-2021, 10:39 PM | #150 |
2962
Rep 1,765
For sure man
01-26-2021, 02:39 PM | #151 | |
Rep 254
01-26-2021, 05:13 PM | #152 |
Rep 8,774
Those getting this kit installed make sure you point out to the installer that for the rear the black helper spring needs to be pressed into the perch before it is installed. The MSS instructions just calls for using the cars weight to accomplish this but it might not align straight.
I just got my kit from Ben (top notch service and price!) and was figuring out how everything went together and that was the first thing i noticed that could cause noise from the rear is if the black spring isn't pressed into the adjustable perch locking it in. Alan
Tenac4504.50 r33_RGSport12803.00 |
01-26-2021, 07:09 PM | #153 | |
12803
Rep 18,627
Usually McPherson does. But, all car's rear suspension do have camber and toe regardless of suspension style.
01-26-2021, 07:10 PM | #154 | |
12803
Rep 18,627
Today customer can't make it, should be tomorrow. I'll share the video on how to get it done.
