11-18-2021, 02:17 PM | #1 |
Laker
38
Rep 116
Windshield replacement - airbubble
hi, my '21 45e windshield was replaced yesterday by Safelite. When delivered, there was a cent sized air bubble at the windshield camera (photo atatched) just below the 'Connected Drive' wording.
Technician said it is an air bubble and would go away in a day. Its still there today. Wanted to check if anyone had this issue, if this air bubble will eventually go away or it needs to be fixed by the technician. There are no sensor/camera warnings or anything until now. |
11-18-2021, 08:19 PM | #3 |
535
Rep 365
Drives: 2011 AW E92 ZCP 6MT
Garage List 2021 Toyota Tacoma [0.00]
2020 BMW X5 [9.00] 2020 Subaru WRX [0.00] 2019 Ford Raptor [0.00] 2011 BMW M3 [0.00] |
Guess you could try gently heating it from the outside to confirm.
But I agree, that's likely not going to disappear
AW 2011 E92 ZCP 6MT single hump w/speed cloth.
Alpine Stage 2 | Apex Manufacturing X-Pipe | Corsa | BayOptiks | Haimus Racing CF Plenum MW 2020 G05 X5 with delicious coffee interior |
11-19-2021, 08:50 AM | #4 |
Self-Deprecating Narcissist
7274
Rep 6,561
Manufacturing defect. It will not go away. It should not have been installed. Demand replacement. This is one of the many reasons I go with OEM glass and have the dealer install.
11-19-2021, 11:02 AM | #5 |
Rep 180
I don't have a G05, but that looks like the gel pad for the rain sensor. Safelite likely reused the old one. If you remove the rain sensor, you should be able to remove the air pocket by gently massaging the gel pad. If not, replacement pads are available.
11-19-2021, 11:13 AM | #6 | |
Rep 4,487
11-19-2021, 11:25 AM | #7 |
Rep 842
If joesid is correct and I think he is - Do you think the rain sensor is working normally with this issue? If not then it should be on Safelite to correct it.
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50 |
11-19-2021, 12:50 PM | #8 |
Rep 23
I've had (believe it or not) 3 windshields replaced in the past year..each time with OEM glass...and thankfully have not had that issue. That looks like OEM glass to me so I think it is an installation problem and I would for sure have them re-do it....or at least try. Not sure about your BMW dealers around there but here (MN) none of the dealers install glass and outsource to local glass places like Safelite.
Also as a sidenote if any of you out there are driving around newer X5's without glass insurance coverage...I'd recommend getting it. These windshields cost close to $4k to replace (with OEM glass). |
11-19-2021, 04:20 PM | #9 |
7274
Rep 6,561
It appears to be in the frit band of the windshield and if so then it is most likely in the laminate. If that is the case then it is a defect and should not have been installed to begin with but should be replaced. I
11-19-2021, 04:28 PM | #10 | |
Rep 30
Tech said that to you so he didn't have to redo the windshield install. Best of luck |
11-19-2021, 04:32 PM | #11 | |
Rep 4,487
11-20-2021, 09:28 AM | #12 |
258
Rep 319
Safelight just did a replacement on ours. They used factory BMW glass. Our X6M50i has all the windshield sensors they can put on it. we did have to take it to their location to have the install done for the calibration of things though.
2024 X3 M40i. wife says no Mods since it's aLease.. I see a JB4 tune in the near future.
2014 328i Melbourne Red Sport Line Dinan Dinantronics tune, Dinan Exhaust, Dinan Suspension, H&R Sway bars, 18x9 APEX PS-7 ,AFE CAI, BMW M Performance Brakes Retired |
04-13-2024, 05:06 PM | #15 |
Rep 3
I just fixed mine today on my 2021 X5 M50i if anyone is looking to do it, read instructions below.
My windshield was replaced by the original owner. I bought the car and discovered it wasn’t working becuase of air and dirt on the gel on top of the sensor. Took it to BMW under warranty and they said they cannot warranty it since it’s not a factory windshield and quoted me $375 to replace the gel and “calibrate” the sensor. I declined the repair. I bought this gel on Amazon. https://a.co/d/0ucQk29 To do the fix: I turned the car completely off, made sure it was not on ignition either. Took the plastic trim pieces off around the mirror Took the mirror off by sliding it down…be careful as exerting too much force will slide it right off and may scratch the dash or iDrive screen. And disconnected the electrical connector. Next, I disconnected the rain sensor. Took the metal pin off that held the rain sensor. Took off the gel pad that caused it not to work. Cleaned the sensor and windshield (where the sensor goes) with rubbing alcohol. Wiped both the sensor and area in the windshield with microfiber to make sure there is no dust particles on both. Took the sensor and put it on a leveled surface. Injected the 2 part gel onto the sensor and made sure it went all the way to the edge and formed a decently thick crown. On my vehicle, I covered the rain sensor with the gel. Some cars have a raised edge for the gel not to get into the sensor, but mine was one flat surface. Once it cured (about 4 mins indoors), I took it and clipped it back into place and checked from the outside that there are no more air bubbles. I connected the sensor and put the wiper in auto mode and sprayed water and worked right away! I did not have to re-calibrate anything, just re-used the sensor that came with the car. Please note: if you have an air bubble after doing the new gel, it will likely not come out so I re-did the gel with a little bit more and i had no air bubbles to massage out the 2nd time. Just be careful of the gel nozzle because it may solidify in the special nozzle, so try to do the repair quickly to avoid a clogged nozzle if you have to re-do the gel. $16 to get it up and running, saved myself $375 at the dealer. The cheapest gel pad that is for the car was about $40 and the gel linked above worked like a charm. Hope this helps! |
Marty in NY2831.50 |
