07-17-2019, 09:20 PM | #287 |
Rep 2,609
I asked Stephan recently, his reply seemed likely generated by his personal Magic 8 Ball:
07-21-2019, 04:59 PM | #289 |
Rep 5,450
Just had this issues, bought the OBDLink LX from amazon on prime day as it was on for 35 bucks and says supported, seems to work fine, was able to code other modules but it will not code the tailgate module, just says coding error right away, reads ok, coded the lock beep in the alarm module no problem. Emailed them to see what they say, their site says the adapter should work with an android device for all modules from what I can tell, but maybe I just meed the MX+?
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
07-21-2019, 05:08 PM | #290 | |
456bhp for breakfast
425
Rep 913
07-21-2019, 05:29 PM | #291 |
Rep 5,450
Any idea if the bug is with just coding that module in general or the combo of the adapter and coding and other adapters work?
07-21-2019, 05:32 PM | #292 | |
425
Rep 913
07-21-2019, 06:56 PM | #293 |
Rep 5,450
Ah ok, hopefully they update soon, literally the only thing I really wanted was close the door from the remote with a short press.
07-21-2019, 09:43 PM | #294 |
Rep 853
I was able to code tailgate with Veapeak module
2018 540ix msport
2015 X5 msport 2013 750ix msport 2011 550ix msport 2009 e92 335i msport |
07-22-2019, 10:04 AM | #295 |
Rep 5,450
I heard back from them and they confirmed it is a bug and they are looking into it.
07-22-2019, 10:05 AM | #296 |
Rep 5,450
When did you do it - looks like the bug was introduced, so this used to work but no longer does unless it works with the veapeak only for some reason - did you code this recently and with a current updated version of the app?
07-28-2019, 06:33 PM | #297 |
Rep 5,450
Seems it has gone from broken to more broken - there was an update this week and not the tailgate ecu comes up as not supported at all, very unhappy with the app, bought it for one reason and that was to code the tailgate as others have done it with the app and now it is so broken it won't even let you read the ecu.
07-28-2019, 06:37 PM | #298 |
Rep 83
The tailgate was broken in the last release.
He probably disabled til it’s working again. I emailed him and confirmed it wasn’t working in the last release after receiving errors during programming |
07-28-2019, 06:47 PM | #299 |
817
Rep 1,785
I was able to code my tailgate using a Veapeak about 2 months ago using Bimmercode.
COL(Ret), US Army Hagerstown MD 2019 X5 40i MSport Alpine White/Coffee (my 13th BMW) 2015 Mercedes SL400; 2009 Lexus RX350 |
07-28-2019, 08:49 PM | #300 |
Rep 5,450
Ya it used to work then they broke it and say it is a known issue and now they have removed the module as supported from the app, I could read it last week no problem and make changes and it would error writing them back, now you can't even read the settings.
07-29-2019, 07:02 AM | #301 |
Rep 5,450
Got a little more info from Stephan, he said it is an issue with that module needing messages longer than 512 bytes and that is not possible with one of the bluetooth or wifi adapters, so he disabled it for now. He did say it works with enet (so ethernet adapter on iphone will do it).
08-10-2019, 08:08 PM | #302 |
Member
899
Rep 2,032
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [10.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
Is the developer working on anything?
08-19-2019, 04:50 PM | #303 |
Rep 21
Issue with programming custom buttons after coding?
Does anybody have a problem programming the custom buttons after coding? I recently tried to program some of unassigned buttons and it says "unable to save". All previously programmed buttons work just fine. They cannot be overwritten either. I coded ASS and the tailgate button. I don't know if this is a coding issue or something else.
I just read some of the recent reply on this thread. It seems like the tailgate coding is removed due to a bug. I coded the tailgate button right when it became available. Haven't tried to program the custom buttons until recently.. |
08-19-2019, 06:26 PM | #304 | |
401
Rep 338
08-20-2019, 07:43 AM | #305 | |
Rep 853
I did it about 3 months ago. I just checked last week and the function on Veepeak was not available anymore.
2018 540ix msport
08-20-2019, 02:34 PM | #306 |
Rep 5,450
Thanks I did get a soLotion from the developer using an iPhone, Ethernet obd adapter and an older version to code it.
08-20-2019, 03:16 PM | #307 | |
257
Rep 332
EDIT; Nevermind, found my own answer, but kinda expensive at about $100. https://www.belkin.com/us/p/P-F8J227/ Last edited by Fuzzy Master; 08-20-2019 at 03:22 PM.. |
08-24-2019, 04:34 PM | #308 | |
Rep 5,450
