      12-29-2023, 10:19 PM   #1
newbiebmwx5
Drives: bmw x5
Do M wheel/tires fit on non M version?
If someone on X5M had 295/35r-21 wheel/tire set , would those fit on the regular x5? Or is there a difference that will prevent it from doing so? Thanks!
      12-29-2023, 10:33 PM   #2
eelnoraa
Drives: G05 X5
Non M stock 21” is 275/45R21. 295/35R21 is just 2.1% larger in diameter. This aspect, I don’t see why it won’t work if you out this in all 4 corners. Transfer case won’t know. Actual speed will ve 2.1% faster.
Please also check center hub pattern and offset.
2022 G05 B58/PHEV
+ a few very old BMWs
      12-30-2023, 06:15 PM   #3
slicky
Drives: Cadilac ATS-V
I bought this combination from Costco but had to cancel as they would not install. The load rating of a 295/35/21 tire is much lower than that of a OEM 315/35/21. Would it be ok, nevertheless.....probably. Or perhaps they could blow out if you load up the car enough and hit a big enough pothole. Who knows.
No major tire shop will install them. If you get someone to install them, no major tire shop will patch them up if you get a puncture.
      01-01-2024, 06:50 PM   #4
newbiebmwx5
Drives: bmw x5
Any thoughts if x7 wheel/tires would fit?
285/50-20 Bridgestone Blizzak DM-V2 on 20x8.5 MSW Rims
