      03-18-2024, 07:21 PM   #1
romeof1
Drives: 2020 X5
Tire Fitment for 741M wheels
Good evening,
I have a G05 and looking to get 741M wheels for it.
RIM SIZE: FRONT: 21X9.5 REAR: 21X10.5
Someone is selling a package with the following tires on them and I am wondering if they will cause rubbing or need spacers:
FRONT: 275/40/21
REAR: 325/40/21
Thank you all in advance
      03-18-2024, 07:38 PM   #2
eelnoraa
Drives: G05 X5
Originally Posted by romeof1 View Post
Good evening,
FRONT: 275/40/21
REAR: 325/40/21
Stock size is
Front: 275/40R21
Rear: 315/35R21
difference in diameter is 0.
With rear change to 325/40R21, diameter is increase by 5%. It is huge difference.
2022 G05 B58/PHEV
+ a few very old BMWs
      03-19-2024, 04:40 PM   #3
bloom
bloom's Avatar
15
Drives: none
Make sure that rear is the stock 315/35/21 size or your transfer case will blow up
These are stock rims for g05 x5’s… no spacers or rubbing will happen… and don’t put the rear wheels on the front (it doesn’t fit).
      03-21-2024, 09:41 AM   #4
romeof1
Drives: 2020 X5
Thank you for the information.
What if the rears are 315/40/21 instead of the stock 315/35/21? Is that safe to run with along with 275/40/21 up front?
      03-23-2024, 09:28 PM   #5
slicky
Drives: Cadilac ATS-V
No. You are totally out of wack with your proposed sizes. Run a comparison calculator. Front and rear diameter must be basically the same. If you start deviating, you are going to be buying an expensive new transfer case and another set of tires that actually match.
