05-23-2023, 05:58 PM | #23 | |
Rep 8,736
Drives: eVeRyOnE mAD!
I have an iPhone 14 Pro with Element case and have no issues fiddling with its position in the tray to start charging. note: I rarely use the wireless tray because it’s so slow, and I rarely need a signal boost from the LTE compensator so my phone is usually externally mounted on a MagSafe charger at chest level. |
05-23-2023, 06:01 PM | #24 |
Rep 6,844
If I remember, the manual lists the maximum size of a phone that can be accommodated. To get a reasonable charge, the induction coil must be aligned, which is what that LED indictor is trying to tell you. Combine that with a potential case, which also has a maximum thickness, and you may have problems getting a charge. When the thing isn't aligned, it will produce more heat as it's less efficient in the energy transfer.
05-23-2023, 06:44 PM | #25 | |
Rep 479
Drives: 2022 BMW X5 xDrive 40i
The charging coil is in a very specific place on these phones. If I put in in the charger cradle sideways, it needs 2 of those little foam strips the charger came with to match up. But like you say, it's slow and not my normal mode of charging anyway. It's just iffy.
2022 X5 xDrive40i
Black/Black/Black |
05-24-2023, 05:15 AM | #26 | |
Rep 213
X5 xDrive 45e 2023 / Mineral White / Tartufo / Anthracite-Brown Poplar
05-24-2023, 07:36 AM | #27 |
Rep 8,736
04-12-2024, 02:13 PM | #28 | |
Rep 1
Get some 90deg usb connectors and you’ll be set: https://a.co/d/8XKB4TE The MagSafe on this keeps your phone secure and the short cable on it means you won’t have an excessive cable in the way. Digital Key still works too!! |
nZtiZia4674.00 |
