      11-14-2019, 12:31 PM   #1
Stealthall
Drives: BMW X5 40i
Anyone priced a M Sport front bumper?
Just out of curiosity, has anyone priced a M Sport front bumper? Or know of a site where you can purchase them?
Maybe its too costly....don’t know.
      11-15-2019, 03:52 AM   #2
Ninefourteener
Ninefourteener's Avatar
1346
Drives: 2020 X5 M50i, 2020 Alfa 4C
I don't know for sure about the GO5....
but, I can tell you that typically, it takes a couple years for OEM parts to hit the market and become readily available to "regular" consumers.
I can also tell you, that you ABSOLUTELY want an OEM part. In about a year, you will start seeing aftermarket front bumper molds to convert cars to the MSport variant. They are TERRIBLE quality.... all of them. They don't fit properly, and you'll always see "wavy-ness" in the material.
Don't buy an aftermarket bumper... ever.
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019
690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813
6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342
      11-15-2019, 08:02 AM   #3
Kolegata
Drives: BMW X5 G05
You can try bmw paradigm or hamann, i buy hamann for 900 euro
      11-15-2019, 08:05 AM   #4
Stealthall
Drives: BMW X5 40i
Ok, thanks for the response. I am having the dealership give me a quote as well...I will post when I hear back.
      11-15-2019, 10:09 AM   #5
Stealthall
Drives: BMW X5 40i
Here is the quote from the dealer....painted and installed.
I priced it myself with an OEM parts site...and she is about 30% less.
I am not sure what pieces and parts are not needed on the list that transfer from the current bumper system if any...
For those interested....there you go.
hiki08173.50
      11-10-2020, 04:24 PM   #6
Anthony555
Anthony555's Avatar
Drives: 2008 BMW M3 / 2015 M4 SSII
Switching X-line to M-sport bumper
I used the parts list above and it was largely correct. There was one set of duplicate parts. the Fog lamp surround... The list has two different sets. And then 2 parts were missing. The left and right gloss air intakes, that are nested In the center of the bumper, as well as the associated tow hitch cover and the blank cover.
The overall install was pretty easy.
0) Remove Front Wheels
1) Remove wheel arch trim
2) Remove wheel wells
3) Remove decorative grills
4) REmove all screws on the bumper itself
5) release clips around the grill
6) Wiggle bumper free
7) Unplug wire harness on the passenger side
Bumper is free
8) Put all parts that are on the list above into the new bumper
9) Bring wire harness from old bumper (unclip sensors and fog lamps)
10) Install all clips and wire harness onto the new bumper
11) Fit to the vehicle
12) Screw in the top and sides of the bumper to the car
13) Srew in Wheel wells
14) attach all other screws around the lower bumper and side trim area
15) re-attach wheel arch trim
16) re-attach front grill
It took me about 5 hours but I was also being extra careful.
Also, there are 4 plastic rivets that you will need from the dealer that is not in the parts list above. I purchased 6 because I thought I would mess a couple up possibly... and I did, so maybe buy 7 to be safe. ($1.50 each). You need a rivit gun to install those.
2015 M4 SSII -
hiki08173.50
      11-10-2020, 04:31 PM   #7
Anthony555
Anthony555's Avatar
Also a couple other notes.
The m-sport bumper comes with 6 Parking Distance Sensor holes in the bumper. The X-line has only 4 sensor holes. So you have two options.
1) Have the body shop patch and fill 2 outer most holes, when they are painting the bumper
2) Buy some used or dead sensors and just put them in place to fill the holes.
I opted for option 1, because I had no idea if I could find used or auto wrecker sensors.
As you can see in the picture, 2 of my sensors are painted white, from the original bumper. I think it looks kind of cool. But I may apply some round 3M wrap to make them black.
2015 M4 SSII -
      11-10-2020, 04:38 PM   #8
Anthony555
Anthony555's Avatar
X5 x-line to msport bumper change
Here is the inside back of the bumper for info on that.
2015 M4 SSII -
      11-13-2020, 11:00 PM   #9
akuma753
Drives: BMW F30 340i / BMW G05 X5
Anthony555 - thanks posting this - it looks great! I may be interested in doing the same sometime down the road. Potentially dumb question here - did you get the bumper painted before or after the install?
      12-31-2020, 09:13 AM   #10
viperdoc
viperdoc's Avatar
364
Drives: X7/‘21 45e/‘23 45e
that looks great. Out of curiosity, did you do anything to the lower side trim or rear bumper trim to make them white as well?
      02-17-2021, 07:10 PM   #11
raldy14
Drives: BMW X5 (G05)
Bumper is free
Hello,
your bmw is an Xline, in case it is, did u change the rear bumpers, arch sides and the sides skirts?
      02-25-2021, 07:22 PM   #12
raldy14
Hello, could you send us the links where did you buy the oem parts?
      05-31-2021, 01:42 PM   #13
raldy14
Did u change the rear bumper also?
      07-07-2022, 10:00 AM   #14
maybe_bimmer
Drives: 22 45e
Anthony555 do you have a photo of the left side fog light area without the bumper on? Thanks.
