02-04-2020, 09:55 AM | #23 | |
Rep 903
2) if you lower it to get out prior, the car stays lowered for the next time you get it. I usually hit the lowering toggle right after I park or turn off the car 3) Never tried lower the seat yet, so not an issue I actually like to see the car lowered when parked yes, only thing i'm afraid of is wearing out the air suspension because we use it so much. hope if it does break, its before the 4 year warranty expires. actually posted on another thread about this concern and a few stated not to worry too much. it is only a car after all. not going to get that option and not use it |
Marty in NY2712.50 |
02-04-2020, 05:41 PM | #24 |
LOVE BMW
54
Rep 117
I'm new to the forum. What I've used is Adams Leather conditioner two to three times a year on my BMW's. I haven't experienced the problem your having by doing that. Make sure whatever product you are using is providing good uv protection. Goodluck.
02-04-2020, 05:45 PM | #25 |
LOVE BMW
54
Rep 117
My 2020 X5 running boards are experiencing small rust spots on both of them. Are you experiencing that on yours by chance? It's winter where I live so I don't have the opportunities to take care of as of yet.
02-05-2020, 08:49 AM | #26 | |
Rep 903
We have the Msport pack, so no running boards on ours. |
02-16-2020, 08:18 AM | #27 | |
Rep 4,331
Not unusual, the dealer was not able to either show me or explain how the car will maintain its lowered position after exit so its still lowered upon the next entry. So, here are a couple more questions for you. - What size wheels and tires do you have? (every half inch makes a diff) - You said you lower the suspension before getting out...do you do that before or after you shut the engine off? - You then get out and lock the car and the air suspension stays in the lowest height while the car is locked, correct? No matter how long before you unlock it, it stays lowered, correct? (just wondering if after a set time, it auto reverts back to the middle height) - Can you assign the drivers seat height to your key fob profile so as soon as you unlock the door and before you get in, the seat lowers? Can you make it lower with that same key fob profile as you lock it upon exit and have it stay in that position till you get back in? We got in and out of the X5 yesterday several times and by the end of our testing, the back of my wife's legs were hurting. Ok, so in reality, we would not be getting in and out in succession like we did yesterday but would still like to explore the best purchase option to minimize this issue. So I am of the opinion that I need to go with with 19" wheels coupled with the air suspension and then program the key fob to lower the seat upon entry/exit. Ugh! |
02-16-2020, 09:48 AM | #28 | ||
Rep 4,246
My personal experience to your questions below, Marty:
When I park, I hit the 2VR toggle to lower it to Load level, then hit the engine shut off button. Or you can shut off the engine and hit the toggle. There's vehicle residual power to lower it. The passenger can open their door before it finishes lowering. If the driver opens their door before it finishes lowering, it will stop lowering and display a message on the iDrive control display. The time it takes to lower from Sport level to Load level is short - under 15 secs. If you're lowering from Normal level to Load level, be prepared to wait a little longer - 30 secs. Quote:
The next time you head out, when you unlock get into the vehicle, turn it on - it will stay in Load level until you press the accelerator to drive off. BUT if you press any of the Driving Experience Controls - Comfort, Sport, Eco or hit the air suspension toggle it will adjust to the level selected.
Marty in NY2712.50 dream54ing485.50 |
02-16-2020, 10:09 AM | #29 | |
Rep 4,331
The air suspension seems pretty flexible but the only X5 we have had to test it on at the dealer was a 50i with 21" wheels so even at its lowest height, my wife still had entry/exit issues. I've been trying to find one with 19" wheels and air suspension but have not been lucky yet. Can you also possibly address my questions on the key fob/seat height and how that would work? |
02-16-2020, 11:01 AM | #30 | ||
Rep 4,246
X5 M50i with standard M Adaptive or DHP with M Adaptive Pro is 8.3" whereas X5 M50i with 2VR is 8.7" - this is for all 20" to 22" wheel/tire size combinations. Load level for all X5 40i/50i/M50i with air suspension is 7.125" https://g05.bimmerpost.com/forums/sh...38;postcount=2 https://g05.bimmerpost.com/forums/sh...8;postcount=22 TLDR; 40i M Sport with M Adaptive is equivalent to 2VR-air Normal height - 8.7" M50i with standard M Adaptive or DHP with Adaptive M Pro is equivalent to 2VR-air Dynamic height - 8.3" 40i M Sport and M50i with 2VR-air in Sport mode provides the lowest drivable ground height - 7.9" Quote:
Your wife could store: Memory 1: Entry/Exit settings, eg lowest seat height Memory 2: Drive settings, eg her driving seat height, angle etc. Her key fob would invoke whichever memory setting she last used or it may default to Memory 1 - can't recall. For entry: X5 would be in Load level. Unlocking with comfort access or fob would invoke Memory 1 - lowest seat setting for entry. Once inside, she would hit the Memory 2 to invoke seat height for driving. Existing: Set vehicle to park, set air suspension to Load level, hit Memory 1 for entry/exit seat height, turn off vehicle at any time - don't open driver door until Load level is complete. To set up multiple ConnectDrive driver profiles to store memory settings, what you'll want to do is when you take delivery: 1. Set up your ConnectDrive account with a primary subscriber and secondary subscriber 2. Primary subscriber would be you 3. Secondary subscriber would be your wife This allows you associate a driver profile for each remote and auto switch to that driver profile to recall seating position, exterior mirror position, steering wheel position, height of heads up, iDrive, media etc.
02-16-2020, 03:13 PM | #31 | |
Rep 4,331
Just to confirm my understanding...in terms of ground clearance. If the base ground clearance is 8.7" for example, are you saying that the air suspension option lowers the car below that to 7.5" at its lowest height setting? |
02-16-2020, 03:30 PM | #32 | |
Rep 4,246
Correction: 2VR in lowest height setting (Load level), ground clearance is reduced to 7.125" X5 40i/50i/M50i with 2VR - Level Heights and Ground Clearances Off-road level = +40mm/+1.575in, 10.275" GC High level = +20mm/+0.787in, 9.487" GC Normal level = 0mm / 0in, 8.7in" GC Dynamic level (not user selectable and over 87mph) = -10mm/-0.393in, 9.093" GC Sport level = -20mm/-0.787in, 7.913" GC Load level = -40mm/-1.575in, 7.125" GC
02-16-2020, 04:12 PM | #33 | |
Rep 4,331
So I guess what you're saying is they compensate for the diff between a 19" or a 22" tire by the sidewall height alone, right? So in the case between a 19 and 22", the 1.5" is sidewall height and the ground clearance stays the same. |
02-16-2020, 04:39 PM | #34 | ||
Rep 4,246
- it's a limited account that's used for backing up Driver Profile settings to the cloud - BMW Assist in case she's in an accident - she can download the BMW Connect app to her phone and sign in there too - you'll use to her log in bro to set up her Driver Profile in iDrive and associate with her remote Quote:
Yes, Sir!
Marty in NY2712.50 NWAviator13.50 |
02-16-2020, 05:22 PM | #35 | |
Rep 4,331
Auricom4361.50 |
02-17-2020, 10:26 AM | #36 | |
Rep 903
We sometime lower the car before and sometimes after the engine turns off. it depends when i remember to hit the toggle. Yes, car stays lowered till the next time we drive it. car doesnt raise till its driven (automatically) or if you want to manually toggle back to normal height. I do not think you can set the height on the keyfob profile, well we never tried, pretty sure its not possible. **mis-read. Wife does have her seat lowered, difference is minmal. legs still rubs the seat upon exit/entry Last edited by dream54ing; 02-17-2020 at 10:31 AM.. |
02-17-2020, 08:00 PM | #37 | |
Rep 4,331
Thanks. When you say your wife has her seat lowered, is that via a profile on her key fob? If so, does it auto lower upon unlocking the doors? |
02-18-2020, 08:58 AM | #38 |
Rep 903
its set low, but not lowest. she set it to the lowest she comfortable while driving. It doesnt move unless I drove it last with my profile. Not sure if there's a option that lowers the seat before/after you get in/out via key fob profile. let me know if your able to figure it out. lol.
