11-07-2023, 04:57 PM | #89 |
Rep 290
Similar to Mike02z Zunsport delivery arrived today...dang that is fast! Now I'm wondering how much of the total cost was attributed to shipping.
11-11-2023, 12:04 PM | #90 |
Rep 898
Zunsport oil cooler guard/screen installed during winter wheel change/installation. My mechanic was impressed. He feels BMW needs to address this issue at design stage or offer after sale part/update!
11-11-2023, 07:20 PM | #91 | |
Rep 21
Drives: 2024 G82 M4 Competition
The ONLY critique I have is that you have to drill two small self tapped screws in the plastic molding just past the backend of the cooler’s rubber trim border. I, of course, removed the entire plastic trim piece to inspect and ensure I wouldn’nt be drilling into or close to oil cooler piping. I can confirm there is plenty clearance if you use the two provided screws that come in the kit. Overall 4.8 stars, only because of having to drill into otherwise untapped plastic trim. Otherwise, a smart buy if you don’t want to fork out $450+ for a beefier plate. As for airflow restrictions, I ran decently hard on a hot day in stop-and-go traffic, as well as a few hard pulls on open road and noted NO difference at all in oil temps. Definitely would recommend if you are ok with not having the “armor plating” that Turner’s unit provides. |
Mike02z2082.50 Autoaddict324.00 PipeM3200.50 DSTR1284.50 Pool Shark527.00 Lupeskew651.50 2011ninja3417.00 calbearz2437.00 |
11-12-2023, 09:01 AM | #92 |
2591
Rep 1,952
$17 alternative https://www.amazon.com/Modengzhe-Pai...07LC6TQFB?th=1
11-12-2023, 10:58 AM | #93 | |
Rep 2,745
Drives: 2024 M4 Convertible
11-12-2023, 12:29 PM | #95 | |
Rep 83
11-12-2023, 12:45 PM | #96 |
2591
Rep 1,952
Cut it to 28"x5.5" with metal shears, slide it under the rear clips first, then move the rubber airdam back and forth and it'll loosen the front clips a bit, bend the mesh a bit and slide it under the front clips.
11-12-2023, 12:57 PM | #97 |
Rep 83
11-12-2023, 01:14 PM | #98 |
2591
Rep 1,952
I think its doable, the front end is pretty high on stock springs. Otherwise drive one side up on a curb.
11-12-2023, 02:25 PM | #101 | |
Rep 2,745
Well BMW decided to put a $0 piece of nothing in front of the rad itself surrounded by a $5 piece of plastic on the bottom of the car, so tit for tat IMO. :P |
11-12-2023, 02:29 PM | #102 |
Rep 487
Here's one way I would do it!
11-12-2023, 03:05 PM | #103 |
2591
Rep 1,952
I can make you one and charge you $200 if you want...
11-12-2023, 04:59 PM | #104 |
Rep 290
Wow--smart approach! Maybe if I had waited to see this thread evolve, I might have considered this. .
11-12-2023, 10:28 PM | #105 | |
Rep 1,042
Is the oil drain bolt on top of that large circular cut out behind the Mishimoto plate?
2024 M2, 2024 CGT4RS, 2020 M2 CS, 2021 Macan GTS, 2017 Cayenne S, 2002 M Coupe |
11-12-2023, 11:01 PM | #106 |
Rep 2,093
11-13-2023, 06:12 PM | #107 |
Rep 21
My thoughts exactly. Constant contact/microvibrations over time and erroding that aluminum ducting if the coating ever gives out on the mess would be my major concern. I’m all for $17, but peace of mind is priceless.
calbearz2437.00 |
11-13-2023, 07:02 PM | #108 |
2591
Rep 1,952
You can zip tie it to the outside clips, also cut it larger than I did, no more microvibrations.
11-14-2023, 12:00 PM | #109 |
Rep 487
11-14-2023, 01:36 PM | #110 |
Rep 990
Ordered mine(Zunsport) on Amazon, was here two days later with international shipping.
Pool Shark527.00 |
