02-11-2022, 06:00 AM | #89 |
Rep 2,072
Great work on the testing guys, I haven't had any time to test or even drive much and probably won't for the next week so its great that you are making progress here!
02-11-2022, 07:11 AM | #90 |
Rep 130
It would not let me enter an integer higher than 7.
22 BMW X7 M50i
24 Porsche Macan GTS 24 MB GLS 580 (wifey) 23 Countryman JW Cooper (wifey) |
02-11-2022, 11:52 AM | #91 |
Rep 692
You can go anywhere between 0 hex and F7 hex. (0-127 decimal). Anyway, not that it matters much.
Bimmercode best coding options (Basic and Advanced):
https://g20.bimmerpost.com/forums/sh...5#post29807925 |
02-11-2022, 12:08 PM | #92 | |
Rep 4,109
I've managed to address the console display dimming but not the gauge cluster. However, it sounds like your approach differs. We messed with the light sensor's trigger values so it effectively has to be darker than is likely ever possible for it to dim the console display. But even though said sensor is in the gauge cluster, our tweaks never affected it. Can you clarify your approach? Not the how—you've illustrated that nicely… thanks—rather, what is it you're manipulating to cause the desired effect. Thx! r33_RGSport FYI |
gnolivos319.00 |
02-12-2022, 10:09 AM | #93 | ||
Rep 4,109
Thanks, imdiekeb!! Update: so the coding worked. The daylight brightness no longer changes according to ambient lighting conditions. However, the brightest it gets is not equivalent to the brightest it used to get when in direct sunlight. Even shining a flashlight there has no impact. So while my gauge cluster is now far, far better than it has ever been, the console/headunit display is actually dimmer than it was with my prior solution. I'm gonna read through the coding again and see if the values you supplied can be tweaked up or down depending on their meaning to positive effect. Last edited by limeypride; 02-12-2022 at 12:09 PM.. |
r33_RGSport12971.00 AGONXF30270.50 |
02-12-2022, 10:53 AM | #94 |
Rep 692
Did anyone ever get an explanation from imdiekeb for what the 3 codes do?
02-12-2022, 12:23 PM | #95 | |
Rep 4,109
APIX_CID_UND_ZIN - DIM_CURVE_X2 translates poorly to APIX CID AND ZIN DIM CURVE X2 ... my guess is the APIX referenced here is a lighting bus developed by Inova and the value represents a trigger on a light curve to control LEDs attached to their bus. // this is, however, a massive fuckin' amount of inference/speculation DIM_TAG_NACHT_LICHT_EIN_ENABLE translates to DIM DAY NIGHT LIGHT ON ENABLE: aktiv ... with the translation, it reads to me like the NIGHT brightness setting now also governs the daytime brightness in unison with ambient light roll wheel control in the headlight cluster. imdiekeb's instructions would seem to corroborate that. As for the 3rd setting, it's too short & too vague to even make an educated guess. imdiekeb Do you have any more details as to each value's specific effect? |
02-12-2022, 12:25 PM | #96 |
Rep 692
DTN is Day to Night threshold value.
limeypride4425.00 |
02-12-2022, 12:26 PM | #97 |
Rep 4,109
02-12-2022, 12:29 PM | #98 | |
Rep 692
Then changed it to 7F and it definitely stays bright all the time now during the day.
limeypride4425.00 |
02-12-2022, 12:29 PM | #99 |
Rep 4,109
Thanks. So this perhaps governs the ambient lighting trigger that the car uses to assert it's nighttime (or that you've driven into a dark-arsed tunnel). That makes sense in principle but the sky in the BMW nav system changes when the car thinks it's nighttime, this isn't happening... could be another trigger for that one I suppose.
02-12-2022, 12:31 PM | #100 | |
Rep 692
02-12-2022, 12:38 PM | #101 | ||
Rep 4,109
Aside: I just realized that the headunit's brightness setting no longer increases brightness linearly, in fact, anything above 6 or 7 (assuming a 1-base) actually lowers the brightness. : |
02-12-2022, 12:40 PM | #102 |
Rep 692
What do you mean? How are you increasing the HU brightness. Say more please.
02-12-2022, 12:43 PM | #103 |
Rep 4,109
02-12-2022, 03:41 PM | #104 | |
Rep 692
I have been driving all day and it is very bright as before. Shining a light doesn't make anything brighter now, and I'm really thinking it's at full Brightness constantly during the day. Also while on that topic, I'm not loving the idea of having this full brightness during the day, specifically when it's maybe 45 mins before dusk. It's overpowering. I need to understand the 3 code changes to see if I can find a way to make it fully bright during the day (and not sensitive to the tint etc) but in a way that it will dim somewhat when it starts truly getting dark outside. I think maybe changing that dim curve value to something somewhat higher than purely 0x00 might do the trick.
02-12-2022, 05:00 PM | #105 | ||
Rep 4,109
The gauge cluster is far better than before but still not as bright as it can be. However, I'd say I've got a workable solution now. Related: I'm driving my wife's '22 X5 M50 and its larger display seems brighter under the same conditions as my M8. If you don't like it this bright, adjust the nighttime brightness. |
02-14-2022, 09:40 AM | #106 |
Rep 692
Im testing now with DTN value of 5F. That is right in between the default 3F and the max 7F. It appears to me that this is the best compromise that will dim the screens at least SOME during the late hours of dusk. I will report back.
02-15-2022, 08:05 PM | #107 |
Rep 8
Hello, everyone. I've been away and haven't looked at the forum until now. I'm glad to see that some of you are trying out the settings I reported on. It seems that some of you are seeing the cluster too bright at night. I found that I had to both set the night time brightness in the cluster display settings to it's lowest value AND turn down the scroll wheel quite far. But, I have good lighting both day and night now.
Some have asked what each setting does and how I came to these changes....and I would LOVE to tell you, BUT I CAN'T. I simply don't know. I came upon these settings by much trial and error....and some luck. If those out there that are smarter than I am (most of you) could figure them all out, I would love to know myself. For now, I'm just WAY happier with my X5! |
gnolivos319.00 |
02-16-2022, 01:09 AM | #108 |
Born to Drive
73
Rep 56
Fantastic news to improve the display brightness.
Can someone provide a link to how to do the coding? Will the dealer do that or is it done by the vehicle user?
2022 X5 M50i in Manhattan Green Metallic.
02-16-2022, 07:45 AM | #109 |
Rep 692
Get an adapter for use with bimmercode. Dealer won't do it.
02-16-2022, 08:37 AM | #110 |
Rep 76
As one that implemented Bimmerlight it is GREAT to see that far sharper minds than mine have come up with a coding solution. I went all the way back to BMWNA regarding this subject with the normal "blow-off" on each step of the way. Thanks to all that have taken the time to create this. I will keep an eye on this thread to see what developments/updates/tweaks occur.
One question I do have, coming from a non-coder. Will this coding get wiped out each time there is a software update ?? Again, thanks to all. |
