09-19-2022, 09:02 AM | #67 |
Rep 4,337
How many times have you tried to code ASS? I found that since the OBD port is up under the dash, out of my line of sight, that I did not have the adapter completely plugged in the first time I tried it yesterday, before my post. However, enough pins apparently were making contact OR it gravity slipped out of a pin or two because all of a sudden BimmerCode started acting strange and this was after I had already read all the cars modules and coded one.
I reached down and reapplied upward pressure to the adapter while slightly wiggling it upward and then all was fine. Could it be that what ever pin or pins needed for the ASS setting, weren't properly seated in your case? In any event, next time you plug it in, go to the gear icon in BimmerCode, bring up the manual and scroll down to the appropriate section for your connection method and verify you have met all the criteria. You could also try putting the car in diagnostic mode even though TurtleBoy's does it automatically and his set up is about the same as yours. Do you have the full version of BimmerCode? |
Russ103308.00 |
09-19-2022, 09:03 AM | #68 |
Rep 4,337
09-19-2022, 09:49 AM | #69 |
13275
Rep 19,805
I heard back from Stephan, iD8 is not fully supported and they are currently working on it.
09-19-2022, 10:27 AM | #70 |
Rep 1,078
From page 153 of the X7's OM (X5 & X6 should be similar), the following conditions prevent the auto start/stop function from shutting the engine off:
▷ In case of a steep downhill grade. ▷ Brake not engaged strongly enough. ▷ The outside temperature is high and automatic climate control is running. ▷ The car's interior has not yet been heated or cooled to the required level. ▷ Where there is a risk of window condensation when the automatic climate control is switched on. ▷ Engine or other parts not at operating temperature. ▷ Engine cooling is required. ▷ The wheels are at a sharp angle or the steering wheel is being turned. ▷ Vehicle battery is heavily discharged. ▷ At higher elevations. ▷ Hood is unlocked. ▷ Hill Descent Control is activated. ▷ The Automatic Parking Assistant is activated. ▷ Stop-and-go traffic. ▷ Selector lever position in N or R. ▷ After driving in reverse. ▷ Use of fuel with high ethanol content. Some of these are quite definite, while others seem rather vague ("high ethanol content" -- E15? / "Stop and Go Traffic" -- I thought this was purpose? / "At high elevations" - 7700 feet where I live doesn't do it.). These are the circumstances where the instrument panel display will show a square box with the "A" inscribed with the circle arrow & start stop, with a diagonal line across the box, indicating that ASS is active but inhibited. |
09-19-2022, 09:14 PM | #71 | |
308
Rep 340
I had no problem coding fog lights with high beams and turning off the seatbelt nazi alarm so far. |
05-26-2023, 05:51 PM | #72 |
Rep 589
I used to code ASS memory active with my Bimmercodr. Then I manually turn it off by pressing the bottom next to the shifter and that's it. Car always remember I had it off....
Usually after OTA updateI have to repeat this and it works everytime no issue..... UNTIL yesterday, I had my car in draler for service. Dealer updated the software in my car to 03/2023.53. When I first get the car back, I notice ASS is ensbled...I figured no issue, I just have to code it again...But then today, after coding it, it still didn't remember my last setting....then I tried to code ASS disable. It still doesn't work....Now the car always have ASS ON, very annoying.. Anybody has the same issues? |
05-26-2023, 07:08 PM | #73 | |
13275
Rep 19,805
05-26-2023, 10:24 PM | #74 |
Rep 589
05-27-2023, 11:00 AM | #75 |
Rep 97
In some cars, the default Comfort mode (in this case, Comfort D) can be sluggish, like you have to floor it to get the car moving. But, in my car, it's tuned just about right for daily driving - shifts when I would expect, is super smooth, throttle doesn't feel laggy at all, but also isn't too touchy like some Sport modes. I really like it.
The fact that the driving mode is otherwise perfect, at least for me, makes it extra disappointing that auto stop/start is forced on in that mode, because it takes the driving experience from amazing to terrible when you get in stop-and-go traffic. I don't care what anyone says, it isn't seamless, especially in a situation where you have to ride the brake or feather the throttle. I'm trying to train myself to get used to switching from D to S when I encounter traffic but I hate that I have to do that. |
05-27-2023, 11:37 AM | #76 | |
Rep 1,155
2024 M60i Frozen pure grey/Black Merino
2023 M50i Tanzanite / Ivory/Night Blue Merino gone 2022 40i G05 Arctic grey/Ivory Merino gone |
blinsc93.00 |
05-27-2023, 12:10 PM | #77 |
230
Rep 365
I assume with a 50e auto stop/start is a non issue since in stop and go situations you are almost always under electric power. Is that a correct assumption?
05-27-2023, 10:00 PM | #79 |
Rep 6,806
Yes, you'll normally be starting from a stop with the EV motor and 'tow-start' mode is quite smooth if the ICE is then needed. The actual starter motor is only used if you're forcing the ICE on from a stop. So, with tow-start, how smooth it is, is entirely up to the computer program, and they seem to have that dialed down pretty good.
05-28-2023, 03:19 PM | #80 | |
805
Rep 1,790
05-30-2023, 08:07 PM | #82 | |
Rep 589
I contacted Bimmercode, they acknowledged such situation and they are working on a fix, but there's no easy solution yet.... |
07-26-2023, 08:10 AM | #83 |
Rep 7
Coding service
Does anyone in the Tampa, FL area offer the coding service? I don't like installing apps on my phone and would like to disable the auto start/stop and seatbelt chime.
r33_RGSport12971.00 |
07-26-2023, 08:20 AM | #84 | |
13275
Rep 19,805
r33_RGSport12971.00 csparker12.00 |
07-26-2023, 03:30 PM | #85 |
Rep 6,806
TO code remotely, you need a WIN PC with teamworks app, an Ethernet OBD II adapter, and WiFi where the vehicle is parked. The coder will have some specifics about what you need. But, with that, he can tap into your vehicle and code pretty much anything that is codeable from remote.
07-27-2023, 10:22 AM | #86 | |
12971
Rep 18,716
07-30-2023, 05:53 PM | #87 | |
237
Rep 372
2021 G05 X5 s40i Phytonic Blue | Ivory White Vernasca | Anthracite-Brown Poplar Matte Trim
2015 F10 535i M-Sport Space Gray | Black Nappa (Gone) |
07-30-2023, 06:13 PM | #88 |
Rep 6,806
Yep...senior moment. It is a neat program...I used it to figure out problems with my mother's computer from home as she was 400-miles away...not a convenient personal service call! It's free for personal use, costs for commercial use though.
