12-23-2022, 01:24 PM | #23 |
Rep 8,812
Drives: eVeRyOnE mAD!
for clarification, the $500 wireless charger option doesn't include mobile hotspot. that's a separate feature. you're confusing this with the LTE compensator (booster) which is included with the wireless charger option. this component has been useful for some owners, so it's advised not to decline this option based solely on the subpar performance of the wireless charger
12-23-2022, 01:26 PM | #24 |
13
Rep 32
12-23-2022, 01:34 PM | #25 | |
Rep 8,812
https://g05.bimmerpost.com/forums/sh...1&postcount=11 |
12-23-2022, 05:16 PM | #26 |
Rep 6,893
Other than looks, unless you're tracking your vehicle, larger tires/wheels are primarily eye candy. The taller sidewalls of the OEM stock 19" wheels give a better ride, cost less to replace, and are easier to find when the time comes. They may not work if you opt for one of the performance braking options, but again, unless you're tracking the vehicle, pulling a trailer, or live in the mountains, not going to gain you much. Most people don't press the brakes hard enough in an emergency, but all of the brake choices can lock up the wheels (activating ABS), and then, the only differences are in what tires you have.
If you're carrying people in the rear, and they're old enough, you might want the four-zone HVAC so they can control their own temperatures along with maybe rear heated seats. All vehicles have a backup camera, but having the parking package gives you a 3-D top-down view that can be handy. |
12-23-2022, 09:13 PM | #27 |
Rep 537
I personally don’t think the running boards are effective for anything other than getting your pants dirty. We had a rental X5 with them on and were super disappointed. Maybe others have a different perspective.
12-23-2022, 10:42 PM | #28 |
Rep 253
If the side skirts on an X5 are similar to the ones on X6 then I'd strongly suggest getting the running boards. My pants rub against the dirt prone side skirts every time I get in or out of our X6 and my kids use them as a step stool to climb in or or .
12-24-2022, 12:39 AM | #29 |
Rep 172
If you can charge your car every night. The price per mile driving is definitely lower for 45e. But not everyone has a garage. Testifying as a 45e owner.
12-24-2022, 12:49 AM | #30 |
Rep 172
The best things for 45e are:
1. Air suspension. Best riding quality among BMW. 2. Pre heating / cooling without burning gas (you need this if you park your vehicle inside.) 3. Reduced gas usage -> lower cost per mile, tax incentive, better for the climate. (not everyone cares about this, but I do. We send too much money to the sand monkeys in the middle west for this bullshit) 4. Instant torque 5. Easier on the brake pads. Honestly, I almost never have to brake unless I want some spirited driving. They might last 3-4 times longer than my gas vehicle. 6. It's awesome for camping. Using the battery-hold mode, I can sleep in the car with full AC. Downsides: 1. It's heavier. So definitely not good for tracks. 2. I can't see engine rpm unless in the sports manual. What a waste for the b58. 3. Can't rev engine All in all, I would buy another 45e if I had the money. Last edited by wbeemer; 12-24-2022 at 12:50 AM.. Reason: improve wording |
12-24-2022, 12:58 AM | #31 |
Rep 6,893
The cost per mile will depend on the costs of both the liquid fuel and your electricity costs...so EV mode might be cheaper, or more expensive, but if you charge from home, the convenience is worth it to me. The second biggest thing is the ability to precondition while parked in my garage. Third, it just drives nicely! While it's heavier than the 40i, the power:weight ratios are essentially identical, so there's no penalty and the instant torque is nice. With the ICE and gearbox detuned, at the same road speeds, the 45e's ICE is turning slower than the 40i, which means lower noise, fuel consumption, and likely longevity which becomes important if you're one to keep your vehicle long-term...not so much if you lease or trade frequently. If you've exhausted the HV battery, the 45e on a longer trip is slightly less efficient, but can make that up if you can recharge it during stop and go.
12-24-2022, 01:17 AM | #32 | |
Rep 172
12-24-2022, 07:55 AM | #33 | |
17
Rep 44
12-24-2022, 08:44 AM | #34 | |
Rep 547
12-24-2022, 08:47 AM | #35 |
224
Rep 314
I've had both the 40i and now on our 2nd 45e... For us it's 45e all the way - Even without the EV Credit I'd be buying the 45e.
If I were the OP, I'd be hard after one before the 12/31 deadline and save the extra $7500 too! Heck, with it being year-end and the economy slowing, you might even get some discounting thrown in! |
12-24-2022, 08:52 AM | #36 | |
Rep 8,812
https://fortune.com/2022/12/21/infla...-before-march/ |
12-24-2022, 11:17 AM | #37 |
Rep 145
I’m seeing the number of available X5 45e’s on sites like BMW herb chambers in Boston has gone up. It used to be around 3-4 and today I see 9. Now this is not a guarantee that they are really available, site may not be up to date but the fact the number is increasing is noteworthy
12-24-2022, 11:58 AM | #38 | |
Rep 284
Drives: 2023 X5 X45e
cptcolo103.50 |
12-24-2022, 12:29 PM | #39 | |
Rep 3,708
To the ZF. 6th gears in both are direct drive 1:1 ratio. Below 6th, 40i has shorter ratios (larger number). Above 6th, 40i has taller ratio (smaller numbers). Overall, 40i has wider spread of gears. We can do some math for below 6th. But at 6-8th, 45e will have higher rpm at the same speed because both gear ratio and final ratio are “shorter” |
12-24-2022, 04:07 PM | #40 |
Rep 6,893
The 40i and 45e have a different rear differential, so, I've had trouble finding the final drive ratio, but the transmissions are different throughout the gear range.
12-24-2022, 07:25 PM | #41 | |
Rep 3,708
Then we have to also see if this make sense. 45e is 800lb heavier, it is very natural to have shorter gear ratio than the lighter 40i, specially at the top end. Otherwise, the 8th gear will become useless, any small acceleration will kit it down to 7th. As to the so called "detune" 45e engine. I actually don't think it is simply detune. The max torque of 40i and 45e ICE seem to be the same, but if I have to make a wild guess, 45e will reach max torque at lower RPM. I don't have time to look up torque/HP curve for side by side comparison. But everything has a catch, reaching peak torque at lower RPM means torque will drop off soon. This also mean lower peak HP. This also explain why ECU is set to lower red light, because there is no reason to raise redline if torque is already drop off enough. So the so called detuning isn't a detune, but a remap to handle a heavier car, causing drop in HP.
2022 G05 B58/PHEV
+ a few very old BMWs |
12-24-2022, 07:30 PM | #42 |
Rep 3,708
It depend on where you are/electricity rate. For me, at current gas price, EV at home charging definitely don't win over ICE. I am also a 45e owner. I am paying $0.48/kWh for winter, and $0.55/kWh for summer here
2022 G05 B58/PHEV
12-25-2022, 12:12 AM | #43 |
Rep 6,893
Even though the 45e is heavier, the power:weight ratios are essentially identical, and the torque comes on earlier with the 45e.
Regardless, for my use pattern, the 45e ends up being the better choice and while the gas vs electric cost varies based on the price fluctuations of the energy used, the convenience of almost never having to stop for gas is an advantage. |
12-25-2022, 12:43 AM | #44 | |
Rep 3,708
So I do want potential buyers to see it this way. Sure everyone has range anxiety, but in practice, does that ever materialize? Even if it does, how many times? Of 1 time in a year thing. I would just rent a car for such a trip. But then this give electricity rate make sense. In CA, most EV buyers are just drinking EV coolaid. |
