      09-20-2023, 05:43 PM   #1
VETTEPRO
248
Drives: 2021 X5M Comp, Grigio Telesto
0-60 Times Stock, Dinan Tuner, JB4 etc.
Just curious what times everyone is getting on a 21 up that can't be tuned.
I have a Dinan Tuner, secondary downpipes, air filters and an x-pipe to delete the resonator.
Mine ran 3.19 with a 1' runout and 3.41 without. DA was 1500' and 73 degrees. Zero incline.
I was thinking of getting a JB4 in place of the Dinan. I still have my Meth injection system from my F85.
2021 Individual Grigio Telesto Gray Pearl Metallic X5M C, BC Forged, Dinan tuned, Dinan suspension, MAD Downpipes, Dinan Exhaust. More to come.
Owner, Designer, Tuner- A&A Corvette Superchargers
WWW.AACORVETTE.COM
      09-20-2023, 07:49 PM   #2
Hit_Apex
Riding the knock sensor
Hit_Apex's Avatar
2371
Drives: 21 X5MC | 23 M4CSL
2021 BMW X5MC  [0.00]
I did 3.18 no run out and 11.2 at 121mph on RaceChip GTS black. Now on JB4 and it is faster but haven't dragy'd yet. Only mods are BMC filters.
Edit: this is on E25-E30 which I run daily.
Appreciate 3
vitipr171.00
r33_RGSport12971.00
      09-20-2023, 08:07 PM   #3
VETTEPRO
248
I was running crappy 91 Octane. Our gas is so bad, BM3 actually has a separate tune for California. I do sometimes run E30. The only station that has E85 is $6.79 for 91. It's definitely faster with the E added.
      09-20-2023, 09:16 PM   #4
weinerbarn
Unapologetic Tool Hoarder
weinerbarn's Avatar
734
Drives: 2020 X5 M Competition
JB4 Map2 on a 2020. I think this was all stock besides the JB4 on 93 octane. I've added a secondary cat delete but fairly certain this run was before I added that. Also had my wife in the passenger seat but she only adds about a 100 pounds
      09-20-2023, 09:34 PM   #5
vitipr
Vitipr
vitipr's Avatar
171
Drives: BMW M3
Good numbers! You mixing 93 and e85? How much more or less of E85 gal you need to get 30-35e? Not sure how big is our fuel tank either.
      09-21-2023, 07:00 AM   #6
AwesomeM3
AwesomeM3's Avatar
Drives: F95 X5MC
2015 BMW X5 M  [10.00]
2020 BMW X5M Compet ...  [0.00]
2008 M3  [10.00]
2020 F95 X5M with CarBahn Stage 1 Performance Controller: 0-60 in 3.14 seconds (with 1 ft rollout) and 3.32 seconds without.
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
      09-21-2023, 07:45 AM   #7
onfireX5
Drives: F90M5,F85X5M
3.29 without 3.08 with rollout on a nasty hot 84F 4199 ft DA day. With GTS Black RaceChip on pump 93
r33_RGSport12971.00
      09-21-2023, 09:39 AM   #8
cobramite
1228
Drives: '24 X6 M60i, '22 Macan GTS
This will get you where you want to be:
https://www.morepowertuning.com/emix
Figure about 5 gallons e85 and the remainder 93 octane per X5/X6 tankfull as a ballpark proportion for 93 octane based e30.
Keep in mind that most "e85" pumps are delivering less than 85% ethanol.
LloydP83.50
      09-28-2023, 08:02 AM   #9
VETTEPRO
248
Added some E85. Without testing it, I'd say it was E25 total. It was earlier in the morning so it was s a bit cooler.
It ran 3.01 with rollout and 3.24 without.
The E makes a noticeable difference.
WWW.AACORVETTE.COM
      09-28-2023, 08:39 AM   #10
Alan l.
Alan l.'s Avatar
5453
Drives: 2020 F95 X5M Competition
are you guys having issues with your low pressure fuel pump that's in the tank by running ethanol daily?
I've been browsing the M5 forums lately mainly to see what issues those guys are having with this drivetrain figuring they are pushing more mods and limits so its a good indication of the weak points of this car.
Seems like the low pressure fuel pump in the tank even with stock fuels is a problem and more so for those running ethanol. Common indication that the LPFP is starting to go is when the car stalls after starting or stumbles as it tries to settle to idle rpms. I just changed mine out last night and surprisingly its pretty straight forward. Kies Motorsport has a good youtube video showing how its done on a 3 series. Not exactly the same but it gives you an idea of how to remove the plugs and hoses. Helps to have very little gas in the tank. My car showed 40 miles left and there was still a good amount of gas in the tank when I opened it up.
My car didn't stall but i started noticing it would stumble during idling sometimes and almost stalls during warm starts before it corrects itself. M5 guys reported the car drove better after getting a new pump so I'm going to see if my car feels any different after the swap.
Alan
      09-29-2023, 07:32 PM   #11
weinerbarn
weinerbarn's Avatar
734
Alan
Interested in this as well since my next move is to go E85 or Flex Fuel tune.
      09-30-2023, 09:17 AM   #12
Wtfitzvi
Wtfitzvi's Avatar
Drives: ...
https://youtu.be/xbMDXdHAkOE?si=nmzXcMSnj1nD_OXU
Only mods were Dinan intakes and race chip.
This run was done with a man almost full tank of gas and 200+ lb passenger
CURRENT: 97 E36 | 15 Huracan 610-4 | 18 F80 Competition | 22 F95 Competition | 24 G80 Competition | 23 Escalade | 24 Civic Type R
r33_RGSport12971.00
