10-03-2023, 01:52 PM | #67 | |
1228
Rep 1,350
I think you are refering to how these cars smell when you check them out at car shows/cruises. Absolutely unmistakable smell. Supposed to be caused by some type of mold or whatever than gets into the underside of seats, carpeting, etc. You can sometimes smell it 10 feet away. |
Car-Addicted7048.00 |
10-03-2023, 01:54 PM | #68 |
Rep 169
Drives: BMW X5 xDrive40i
Of course. My grandfather and dad had sone classics. When I smell that, good memories.
10-03-2023, 02:00 PM | #70 |
Rep 134
Yesterday I had an aberration and visited my local JLR franchise where I played around with the new PHEV Range Rover Sport. At a £30k premium for a similar spec to the 50e it would need to be special (IMHO it isn't).
However, the haptic feedback on the control screen was revelatory and now I have haptic envy - this is my contribution the 'everything that's wrong...' |
10-03-2023, 02:09 PM | #71 | |
Rep 1,302
10-03-2023, 02:32 PM | #72 |
Rep 6,805
FWIW, since pretty much all buttons in a BMW are mounted on circuit boards, and feed their input into a chip that then sends a serial message to the computer...eliminating buttons would not decrease the number or wires in a harness by much, if any (it's not a one-for-one relationship)...switching to a touchscreen might eliminate a circuit board, though. Big screens are not inexpensive, so getting rid of a button panel may not save much, if any...
SwissBeemer301.00 |
10-03-2023, 05:31 PM | #73 | |
Rep 4,335
Drives: 2020 M850i Coupe
That said I'm old (57) but I've spent 30-years in technology so it took me all of a hour tops to dial-in her profile with what she wanted plus the additional features with iD8. However, 10+ years of my career included UX (user experience) design in both the digital world along with physical products. That's where iD7 vs iD8 abysmally fails. Do I like hard buttons? Absolutely as they are a single press to get the desired outcome. Can I live without them? Absolutely but the iD8 and iD8.5 UI change is still lackluster from a UX point of view. Steve Jobs was infamous in his opinion on UX customer input panels, etc. It made sense as some ground breaking products had no equivalent within the market so as he stated the consumer doesn't know what they want. That's not the case with touch screen anything as it's a forgone conclusion in today's consumer world. However, we're not talking about navigating a UX touchscreen in the comfort of one's home or workplace but rather driving a 2 ton vehicle down the road. The laws of physics with that amount of mass in motion and the driver doing multiple actions on a touch screen UI to the equivalent of a single button push and focus back on driving is a recipe for disaster. |
10-03-2023, 05:34 PM | #74 | |
Rep 4,335
Statistics state outside of DUI, speeding and running a red light the top contender for accidents is distractive driving. Text messaging as already called out a huge factor in that. Throw in a multiple step UI to make a simple change with the attention off the road and it too likely becomes a factor. |
10-03-2023, 06:45 PM | #75 | |
1228
Rep 1,350
Personally I find no need to tap around on the screen for anything. My climate is set to 72* on automatic mode in SYNC. Sport/Comfort/Eco are buttons on the console. I could very well be missing something or other features. The LCD screen can be addressed if needed at the next red light or stop sign. |
10-03-2023, 06:56 PM | #76 |
Rep 6,805
I rarely change things around after starting a drive. I might attempt a search using the nav, but much of that can be accomplished using voice commands and that utility also applies to most other mundane things like changing the temperature, or engaging the seat heaters and many other things.
bloozemanAZ4268.50 cdhowell127.50 |
10-03-2023, 07:16 PM | #78 | |
Rep 4,335
Why the head scratcher? Even with hard buttons on the iD7 in my M850i I've never touched them for turning on the heated seats, steering wheel, console and door rest nor the cooling ventilation for the seats in hot weather. The reason being is on iD7 there is a climate control app that one can configure to automatically do what you want based on temperature ranges (low - heat and hot - cooling). Originally I thought BMW just buried this in either the seat app or the climate controls settings. Nope absolutely non-existent. For the record given my wife drives in Eco Pro (a button now vs pulling backwards on the drive mode lever in the 2017) the other head scratcher is by default in Eco (or ECO Pro) the HUD is consumed by a pulsating blue chrystal/diamond. When she told me that the map navigation was not showing up in the HUD after I told her it would as a benefit of the new tech vs her iD6 which was limited to turns only in the HUD I was perplexed. Yep, turns out one needs to defeat the driving mode displayed in the HUD as otherwise the Eco modes give you a useless chrystal/diamond. I had tested in comfort after the initial configuration so I was clueless to what she was saying until I took the 40i on a quick drive with NAV engaged. 5 minutes or less to stop the stupidity of BMWs UX designers that thought it was a good idea. 👍 |
Wilson1201.50 |
10-03-2023, 07:26 PM | #79 | |
Rep 4,335
For NAV I always use the app and send it to the car. I do have the finger "fist pump" gesture control though set to navigate home for a quick easy action to help navigate me home from an unfamiliar part of town. Primarily to the major highways or roads of familiarity and then turn off the NAV. I was perplexed it wasn't a readily available gesture setting in iD8 but figured out how to do so in the 40i as well. |
10-03-2023, 07:31 PM | #80 | |
Rep 549
tooloud10766.50 |
10-03-2023, 08:06 PM | #82 |
13266
Rep 19,785
That is not an actual vehicle, it is a concept photo. The GV80 is a standard SUV.
10-03-2023, 08:21 PM | #83 |
Rep 1,147
I test drove a fully loaded GV80 twice and almost pulled the trigger. Very nicely appointed SUV. In the end I wanted a V8 before they become obsolete and I’m very pleased with my M60i. I spend my days enjoying all of its greatness and accept the very few minor annoyances which come with any vehicle.
2024 X5M60i-- Skyscraper/Ivory
2020 Cayenne replaced by ^^ 2017 X5 35d--still in my diesel phase 2015 GL 350--diesel burner/highway queen 2013 Audi S6--a beast in it's day |
10-03-2023, 08:40 PM | #84 | ||
Rep 849
https://www.genesis.com/worldwide/en...ighlights.html
M3 - X5 - 911 - Miata - Raptor - Edge
10-03-2023, 08:45 PM | #85 |
146
Rep 337
Mixitt372.00 |
10-03-2023, 08:52 PM | #86 |
13266
Rep 19,785
Perhaps it has been introduced in Korea but it is a concept/NA in the US.
10-03-2023, 09:23 PM | #87 | |
Rep 4,335
https://www.bimmerpost.com/forums/sh...php?p=30498183 Key being step #1 defeat Logic7 as it is garbage just like all HKs in the past. Step #2 is set the bass and treble flat then match the EQ pic. I've been errant on updating the thread with the specific EQ "clicks" per frequency band but hey life and work gets in the way. 👍 |
JerZBMerLife139.00 |
10-04-2023, 02:16 AM | #88 |
301
Rep 382
