03-21-2021, 03:34 PM | #221 |
Rep 236
Ive had the 22 contis fitted since I got the car in sept 19. I have to say they are not noisy at all.I have the dampers fitted and the air suspension and the ride is very comfortable. No noticeable noise at any speed and Ive had it through a full range of speeds shall we say. There has to be something else causing it.
03-24-2021, 02:12 AM | #223 | |
Rep 114
Go smaller or deal with it seems like the only options.
2021 X5 40i M-Sport
2018 X3 M40i 2015 X5 35i M-Sport +DHP 2011 X5 50i Sport Activity |
03-24-2021, 09:09 AM | #224 |
Rep 236
No, I don’t have the acoustic windows. Just never found my 22 very noisy. The 20 winter wheels/ tyres I have on at the moment, which will come off soon , are no quieter than the 22inch
03-27-2021, 06:38 AM | #226 | |
Rep 2,656
Many find no difference in ride comfort between 20 and 22 inch wheels on the X5. But I do. I guess it's hard to explain. |
volodp199.50 |
05-01-2021, 11:11 AM | #228 |
Rep 25
05-01-2021, 11:55 AM | #229 |
Ultimate Driver
863
Rep 916
I had the 22 Continental’s which I just replaced because I went with a new wheel/tire combo. The Continental’s were night and day more quiet then the Nitto’s that replaced them. If there was any noise that came from the Continental’s it would be on a ribbed concrete highway and even that wasn’t bad.
05-30-2021, 09:11 AM | #230 |
Rep 19
I’m experiencing this problem on a brand new x5 40d in the UK. Seems very affected by road surface. I have the dampers already fitted and tyres are Pirelli P Zero. Dealer has suggested driving it a bit more as it only has 500 miles on now. Not confident from reading this thread that it will make any difference although I am going to try reducing pressure from 36 psi down to 32 psi which would bring it in line with the non eco setting. What I find strange is it appears to becoming from the passenger side (left) which I’m wondering if it indicates a duff tyre? Anyone feel like it comes from one side ? Has anyone tried changing tyres and noticed any difference? Has anyone managed to solve this?
06-23-2021, 07:07 AM | #231 |
Rep 20
This is one of the most useful threads i have seen.
Adding my experience; X5 45e here, delivered 12/2020. Accoustic glass all around. Originally: no damper. Started with Hankook winter tires 265/50R19. Huming noise around 60-70 mph. Changed tires to GY Ultragrip SCT (silent technology). Huming noise gone entirely, very silent overall (still no damper). Come summer i switched to 20” rims. 275/45R20 all around GY AS3 SUV tires. Strong humming noise. Switched back to 19” rims and Michelin PS4 SUV tires. Humming still there, but much more subdued. Purchased and installed damper, switched back to the 20” summer setup with the GY AS3 tires. Humming much more subdued with the damper now. So i stuck with this setup. I wonder, though, if a summer SCT (silent technology) tire would make all the humming go away entirely just like it did for the winter setup. Anyone with experience on summer tires with sikent technology? In practice the silent technology (inside foam) reduces noise/vibration in the low freq (~200 Hz) range. Overall tire noise is not much reduced, but maybe this is exactly the freq range that causes harmonics hence noise in the suspension region. B. |
07-03-2021, 11:21 AM | #232 | |
Rep 117
Thanks |
07-07-2021, 06:31 AM | #233 |
Rep 117
Just emailed Continental Tyres this is the response I got....
The PC6’s on the X5 M50i are relatively quiet on smooth surfaces and will remain so provided they are well maintained (pressures, wheel alignment and rotations). However due to their size, geometry and very stiff construction, on coarse surfaces road noise is readily transmitted through the tyre case and into the cabin via the wheels, suspension, chassis and floor-pan. What this tyre size in combination with a stiff construction does offer, is the dynamic performance level that BMW require for their M division cars. Obviously the dynamic performance offered by the X5 M50i is remarkable. I think it most likely that BMW do not believe coarse road noise performance to be of great importance for the majority of X5 M50i customers and consequently steer tyre development strongly in the direction of handling. Long story short, I have no reason to believe the noise you’re experiencing is abnormal for this vehicle and tyre combination and is not being caused by some anomaly in the manufacture of the tyres themselves and am therefore unable to warrant these tyres. |
07-07-2021, 06:33 AM | #234 | |
Rep 117
Did it make much difference? |
07-07-2021, 04:11 PM | #235 |
Rep 11
Drives: 2021 X5 Xdrive 40i MSport
P Zero summer on my 40i has the harmonic sound for sure. Dampeners installed from factory and tire pressure changes minimal effect. I see that the all-season version has the foam technology to reduce noise...wonder if the performance difference would be worth it??
07-07-2021, 08:51 PM | #236 | |
Rep 403
07-25-2021, 07:15 AM | #237 |
Rep 117
Talking to a guy about this. He's put foam around the inside rims of his E70 and the racecar
In Australia the Perilli PNCS nor Conti-silent is available. I'm going to try as I have nothing to loose. Can't see why it won't work |
08-25-2021, 01:06 PM | #238 |
Rep 10
I have a 2019 xDrive40i M-Sport with 22's...Just replaced the stock summer Continental PC6s with the Pirelli All Seasons with the PNCS foam and am finding the new tires to be SIGNIFICANTLY louder with regards to the "drumming" noise on rough concrete and asphalt. I have the dampers installed from the factory.
I STILL noticed the "drumming" noise with my old Conti PC6s, but it was MUCH quieter and I felt it was an acceptable level. The new Pirellis "drumming" is unacceptably loud...but they shouldn't be because of the PNCS foam. The reason I found this thread is because there was such a night and day difference in the "drumming" loudness with the new Pirellis from my old Contis that I needed to figure out what was going on! It seems the dampeners are not "the magic fix." ...and now I'm thinking the tires are not largely to blame, either. My noise seems to be coming from the front...not the back at all...and upon further inspection, I discovered a metal "wafer" rim around the back of the front rotors only (see pics of what my finger is pointing to). This is the "Splash Shield" Part Number 34-10-6-871-904 If you reach in and flick it with your finger towards you like you're saying "come here".....you get that very distinct hollow drum sound we are talking about. As I mentioned, my rear wheels do not have this same style of splash shield wafer around the back of the rotors and I hear no noise from the back at all. I am wondering if the tire change this morning tightened or loosened this wafer to "ding" at a different harmonic frequency? Could THIS be what is causing the noise we don't like? To triage, I flicked the tire and heard it "ding." Then flicked the tire while holding the shield, and no "ding." Thoughts? I'm going to try to experiment with weighted clips on these to see if the sound is dampened at all. Last edited by pilotboy172; 08-27-2021 at 08:44 AM.. |
08-27-2021, 08:53 AM | #239 | |
Rep 10
Not successful. I placed two clamps on the shields and confirmed that, with the clamps on, flicking the shields did not produce the hollow sound. However, after driving around with the clamps on, I still heard the hollow drumming in the cabin. I believe someone before described it like the echo sound of one of those rubber inflated dodgeballs hitting the floor. ...and it seems to only happen on concrete roads, including those freeways with the micro grooves parallel to the flow of traffic, and rough asphalt roads...basically anywhere there is a bump of any kind or size. It starts around 30mph (50kph) and continues at a similar level above that speed. I was doing some more research and it appears Audi A8s have a similar issue found in their thread here. According to the Audi thread (which discusses 20" wheels), this may be a strut issue? Some in that thread had their struts worked on and it seemed to help the issue. Which would go along the theory that tires may not be the sole culprit...especially since I heard this with both my old AND new tires. I have a service appointment scheduled for next Tuesday at my BMW dealer...but I'm afraid they are going to blame the tires/22" wheels. Last edited by pilotboy172; 08-27-2021 at 09:03 AM.. |
08-28-2021, 08:05 PM | #241 |
Rep 9
Have a 2021 X5 m sport without air suspension and 22 inch wheels. I have the same issue as OP. It’s so bad my door panels started squeaking and rattling. Made an appointment with bmw it is extremely annoying. Only have 6500 miles. Maybe it’s the tires or suspension not sure but hopefully bmw can fix this. It’s annoying having to turn up the radio because my interior is rattling and squeaking constantly.
08-28-2021, 08:24 PM | #242 |
Rep 715
I have a 2021 x5 Msport without air and with the 22s and Continental Tires with 3k miles and I barely notice any road noise. I would say the ride quality is 8/10 for me.
