      06-19-2024, 09:50 PM   #23
FiveOTree
Drives: 2021 X5 M50i
Got it installed today. Will post pictures soon. No welding necessary for SS if you're ok using the clamps provided.
This was NOT a direct bolt on though and required quite a bit of work for the install which wasn't clear when buying from GCA. A shop is HIGHLY recommended.
      06-20-2024, 10:25 AM   #24
IL X5 M60i
IL X5 M60i's Avatar
15
Drives: 2025 X5 M60i
Please post sound clips with pics!
      06-25-2024, 06:44 PM   #25
FrozenM60i
FrozenM60i's Avatar
Drives: 2024 X5 M60i
2024 BMW X5 M60i  [10.00]
Mine was supposed to be installed today and I had more issues. The 2 front pieces that GCA welded flanges on didn’t fit, they weren’t welded at the proper angle. Lessons learned on this exhaust: titanium is not something most exhaust shops will weld unless it’s a more custom performance shop and the install gets really pricy. I think at this point I’m going to return the titanium and have them ship the SS system so my shop can properly fit and do a full weld install. The control box is another thing the exhaust shop won’t touch and need to take it to another shop to get that installed as the exhaust shop doesn’t want to deal with the splicing into and accessory wire in the trunk.
dubsesd6833.00
matowi728.00
      06-26-2024, 05:14 AM   #26
dubsesd
#dubspec
dubsesd's Avatar
6833
Drives: G05 X5/ 2016 F80 M3 INDVL
i went with Dahler oem plug and play setup with downpipes and valve controller. ill be installing soon so ill give my review. i also have the eventuri intake coming so i might install them seperatley because the intake makes a glorious noise as well
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow
instagram: @ dubsesd
      06-27-2024, 11:40 PM   #27
FiveOTree
Here's a video link. I still need to install the control box but that should be pretty easy as the rear has a fuse box. I'm going to see if it has a second 12v that I can use or if I'll need to splice into the rear 12v.
https://youtube.com/shorts/26nA4PmSeiI?feature=share
With having it on for a few days now here are my initial thoughts:
What I like with valves open:
-Deep sound (surprisingly a lot of this can be controlled within idrive with engine sound by controlling the drop of RPMs causing the burble)
-Reasonably quiet when in comfort/eco as it shifts so quickly.
-Downshifts in Sport Plus went from little burbles to something closer to thunder (it was the first thing that came to mind)
What I don't like with the valves open:
-It can be a little raspy at a higher RPMs when shifting.
What I like with the valves closed:
-EXTREMLEY quiet at start up
What I don't like with the valves closed:
-Almost, too quiet...
Here's a pic of the back end with the carbon tips. They stick out a bit farther than I want and this is EVEN AFTER I CUT THEM BACK...
BSfmAZ287.50
      06-28-2024, 04:30 PM   #28
chicagofan00
chicagofan00's Avatar
Sounds good but the amount those tips stick out is unacceptable in my opinion. Clearly these guys did not do any test fitting of the product during the design amd development phase and instead just did back of the napkin math/sketches…
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green
Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple
BSfmAZ287.50
      06-28-2024, 10:10 PM   #29
FiveOTree
I have to agree. In total I had to make 6 cuts for the fitment. AND... There were 2 shorty pipes left over that weren't used....
I'm hoping to work with them to get new L pipes so they don't stick out as much. I'm going to be cutting the ends of the exhaust tips to sink it back another half inch but that will be as far back as it can go because the exhaust tip starts to hit the bend in the pipe...
      06-28-2024, 10:13 PM   #30
chicagofan00
Wow, what a mess. Hopefully they’ll work with you on it.
      06-28-2024, 11:53 PM   #31
FiveOTree
Grabbed a few more sound clips.
From Inside 3/4 throttle to 60MPH:
https://youtube.com/shorts/nkJMnYMPMvM?feature=share
From Inside Sport Plus w/ Engine Sound on Sporty. Deep Burbles
https://youtube.com/shorts/gCkTazoPOnQ?feature=share
Appreciate 4
matowi728.00
chicagofan0019975.00
BSfmAZ287.50
      06-29-2024, 03:15 AM   #32
matowi
matowi's Avatar
Poland
728
Drives: '24 X5 M60i
2024 X5 M60i  [9.50]
Make sure to post sound clips, once installed, pls
Have: '24 G05 M60i
Had: '15 F10 535d; '21 G11 740d
dubsesd6833.00
      06-29-2024, 08:42 PM   #33
pbrad074
Drives: X5
Hi,
I'm new to the forum and owner of a BMW.
I have a 2020 X5 M Sport, and looking to see if there is a way to baffle the exhaust so that it is not so loud when I start it.
The problem I have is that I live in suburbia and leave for work at 5:30am. The X5 isn't extremely loud, but loud enough. The neighbours haven't complained yet, but it is only time 😁.
Any thoughts on how I reduce the startup decibels?
Thanks,
Peter
      07-03-2024, 05:11 PM   #34
hufington
hufington's Avatar
Drives: 2022 X5 m50i
+1
My setup with 4" quad tailpipes sticks out at least 1 1/2" less.
2022 BMW X5 m50i
2024 MB S580
2025 RR SV Edition 1 on order
'18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3
      07-03-2024, 08:51 PM   #35
PNWM50I
PNWM50I's Avatar
580
Drives: 21' x5 M50i
This sound is pretty good. Better than the night runner setup for my ears.
      07-10-2024, 12:01 PM   #36
dubsesd
#dubspec
dubsesd's Avatar
6833
i just installed the Dahler stage 3 system.
-catless secondary downpipes
-new catback system
-2 new valves and remote
simple install all plug and play. no cutting, splicing wires and full control of valves with either the remote or one of your garage door buttons on the mirror. short clip i took but ill get better once soon
https://youtube.com/shorts/geMtquKv1...Rnx4DJxVV1g2gY
      07-10-2024, 12:05 PM   #37
PNWM50I
PNWM50I's Avatar
580
Drives: 21' x5 M50i
-new catback system
dahler has a rich deep tone.
      07-25-2024, 10:59 AM   #38
SVM60
Drives: BMW x5 M60i
I purchased the SS valved system from GCA, which was sold as a "bolt on" system. This is not the case, the flanges needed to be welded on, alignment issues, pipes had to be cut down. This install took 10.5 hours at a BMW specialist shop. We reached out to GCA to question how they advertise this as a bolt on which is misleading, they offered 250$ credit back which covers an hour of install.
As of yet i am quite unimpressed with the sound quality, it does not sound much different than stock for the 5k + cost of purchase and install. Currently looking into other options to improve upon the sound (downpipe, valve override etc). I dont want to flash tune the vehicle as its a lease.
Any insight or advice to improving this would be appreciated as im quite novice mechanically.
Overall not impressed with GCA, would not recommend this product, i would wait for more R+D to be done by some of the bigger outfits to make this vehicle sound as it should.
      07-25-2024, 11:44 AM   #39
dubsesd
#dubspec
dubsesd's Avatar
6833
i installed my Dahler downpipes and exhaust at my local shop in 2.5 hours. all bolt on and even came with new valves and adjustbale hangers. everything mounted in oem locations too.
Tags
cat back, exhaust, m60i, titanium
