01-24-2020, 12:07 AM | #45 | |
Rep 272
I have installed esys but not sure about psdzdata thingy. |
01-24-2020, 12:20 AM | #46 | ||
Rep 2,609
There is a link to "latest" psdzdata lite in that first post. It is not actually quite latest, but it's usually pretty recent and should be good enough. These are not country-specific.
OzJedi107.00 |
01-24-2020, 12:22 AM | #47 | |
Rep 272
02-17-2020, 05:49 PM | #48 | ||
The Dark Knight
422
Rep 1,262
02-17-2020, 06:16 PM | #49 | |||
Rep 2,609
r33_RGSport12967.50 ifr1198.00 |
02-17-2020, 06:56 PM | #50 |
Rep 84
Hello,
I have high beam assist ... but it doesn't seem to do anything. Last weekend I did 250km of night driving in the countryside (outback Australia). Nearly blinded 2 or 3 oncoming drivers waiting for high beam assist to do something. I had to manually dip the lights after that. Is there an option I need to set in i-drive? |
02-17-2020, 07:00 PM | #51 | |
Rep 120
02-17-2020, 07:09 PM | #52 | |
Rep 1,457
Drives: 2023 iX xDrive50
02-17-2020, 07:13 PM | #53 |
13251
Rep 19,765
It sounds like he may not have them turned on. We have had a few other members in the past who didn't realize the option had to be activated separately from the auto headlights.
02-18-2020, 01:12 AM | #54 | |
Rep 84
Thanks! I'll try it again this weekend and report back. |
nvsocr755.00 |
02-25-2020, 11:30 PM | #55 |
Rep 84
So, big drive last weekend (wish BMW gave out frequent fliers for all the miles I'm doing in this car) and tested the High Beam Assist. Here are my thoughts:
Definitely a feature I'll use in remote and rural areas, but would be happier if there was a visual cue on the instrument cluster or HUD indicating the lights had dipped for oncoming traffic. |
02-25-2020, 11:41 PM | #56 | |
Rep 2,420
With heavier traffic indeed there is too much going on with the beams adjusting. But then it turns off. I have done some driving on dark mountain roads this week and it works really well. Really happy with the laser lights in these conditions. |
02-26-2020, 12:01 AM | #57 |
Rep 84
Yeah ... I didn't get the laser lights, but I'm REALLY happy with the adaptive LED headlights. Even the low beam has great depth. The adaptive headlights work very well on country roads. They seem to predict sweeping bends and cornering ... perhaps they're linked to navigation or something.
I drove through some moderate fog. The fog lights in the G05 aren't anywhere near as good as the old 530D M-Sport (E60). |
06-29-2020, 09:19 AM | #58 | |
12
Rep 44
I am so glad you mentioned that the ECUs will go back to stock settings. That saved me a lot of time and panic. |
LexxM31698.50 |
06-29-2020, 09:25 AM | #59 | ||
Rep 2,609
06-29-2020, 10:00 AM | #60 |
12
Rep 44
I would be more than happy to do it. Where do I check? Sorry. I am still trying to figure these things out.
06-29-2020, 10:02 AM | #61 | |
Rep 2,609
Mmilani11.50 |
11-01-2020, 10:11 PM | #63 |
12
Rep 44
getting anti dazzle back after software update
I followed the instructions here and anti dazzle worked perfectly for me.
my car just went for a software update. it is now on 2020.07. so I wanted to do this again and I noticed 5ap is not there anymore. how do I code this again? do I add 5AP and the code those ECUs and then remove it again and code? sorry if this sounds stupid. |
11-02-2020, 04:17 AM | #64 | |
1198
Rep 1,587
When your car was upgraded to i-step 07/2020 it programmed all applicable ECU then did a VO Code against your FA. As your FA does not have 5AP anymore then it will code as such. Have you tested if it's working or not? If it's not then its something i-step version related, and not specific to the VO Coding. |
Mmilani11.50 |
11-02-2020, 09:27 PM | #65 | ||
12
Rep 44
I will try to test it properly and report back. Thank you for the great help. |
11-15-2020, 07:07 PM | #66 | ||||
12
Rep 44
