06-28-2019, 09:42 AM | #1 |
Rep 62
Rough Transmission
The tranny on my 40i Sport is not running smooth. When it changes from 1st to 2nd and 2nd to 3rd under normal acceleration it changes rough. Under moderate to hard acceleration it feels normal. Also when slowing down and the gears come down is very noticeable like if it was a manual tranny and you can feel the car holding down.
This is my third X5 and never felt anything like this on my previous ones or any other car I have driven. The dealers says is normal because the tranny has been improved over the F15 one which I think is totally BS....no one improves for the worse. I was wondering if anyone has experienced this kind of behavior with their tranny's? |
06-28-2019, 09:48 AM | #2 |
Rep 3,499
No not normal at all, the only time I can feel a shift is in sport or sport +. Take it to another dealer.
2022 M8 Comp Convertible
06-28-2019, 09:54 AM | #3 | |
Big Beaver Smile
2101
Rep 3,790
Mine is smooth as silk no matter how I accelerate except sport or sport+, then you feel it a bit more.
06-28-2019, 09:58 AM | #4 |
Rep 668
Agree the acceleration roughness is not normal — upshifts for me are very smooth. However, I do notice that the downshifts when slowing down to a stop are noticeable and a little annoying.
06-28-2019, 10:22 AM | #5 |
Rep 602
06-28-2019, 01:09 PM | #6 |
Rep 902
ask them to test drive another one on the lot with you and tell them to replicate the same thing! total BS, we dont feel much if any at acceleration or slowing down
10-03-2019, 09:00 PM | #8 |
Rep 6
Has anyone found a resolution to rough acceleration and de-acceleration? I have a rough (jerky) acceleration problem that is random and pretty annoying. One day it will drive relatively smooth (with a normally short range drive), another day, it will be really jerky with a gentle acceleration, such as at a traffic light accelerating behind someone. It gets worse in ECO mode. I've noticed it was pretty smooth after a software update for some period of time, but it eventually started to return. I can't really reproduce it for the dealer due to it being so unpredictable. I drove a loaner car (same model, year, same total mileage of around 900 mi) on the same route for a day without any problems.
saloum0.00 |
10-04-2019, 08:37 AM | #9 |
Rep 506
Jerky acceleration isn't right. There are a lot of things that can cause jerky acceleration. I assume that when the dealer had the car, they found no error codes? If you can't reproduce it, I don't know how you will get it fixed.
I'd suggest logging each time it occurs in a notebook. Include time, duration, speed, conditions, and your description of the roughness and anything else you think might be significant. Then go back to the dealer with the log, and maybe you can get the dealer to fix it. You will probably have to be persistent. |
10-05-2019, 01:49 PM | #10 | |
Rep 6
10-27-2019, 12:26 PM | #11 | |
Rep 2
10-27-2019, 04:25 PM | #12 |
Rep 805
There is something up with the transmission in odd cases. If I’m in sport mode and come off a freeway slowing down, then accelerate hard on a turn the X5 kind of lunges on and off. I’ve had this happen a few times on hard accelerations coming off high gears. It’s an odd end case, otherwise it is smooth.
10-28-2019, 03:57 PM | #13 | |
Rep 2
11-06-2019, 05:54 AM | #14 |
Rep 2
Hello
50i (NOT M50I) I have same problem Small speed. 3-2-1 boom How to solve the problem? The update did not help. The dealer does not see the problem. Especially noticeable when switching 3-2-1 |
01-27-2020, 04:48 PM | #15 |
Rep 7
hi
i have a new bmw X5 g05(bulid) in november 2019 and i am having the same problem with the rough/jerking gear changing at low speed. (on comfort mode setting ) is there and update on this problem? thanks |
02-01-2020, 06:04 PM | #16 |
Rep 6
Here is my personal observation of the problem. I have ~4000 miles on my 2019 X5 x40i. All my observations are coming from information collected from a 4K DVR and a relatively fast GPS receiver for speed measurements, and a fast and sensitive accelerometer/motion processing unit in my vehicle (a cell phone accelerometer is too slow to register this kind of problem).
First, it is not really a physical transmission problem (at least not that I have noticed yet). I would call it a “bug” or gremlin inside the Front Collision system and Parking Distance Control system, and in the Automatic Emergency Braking system. This bug is causing improper information processing from KAFAS and ultrasonic sensors, and possibly the front/side radar sensor (but I can not support the last part of this statement, because my vehicle does not have it), causing a short period of de-acceleration (approximately in the range of 0.1-0.3 second). This de-acceleration itself is just a beginning of the problem. The adaptive transmission algorithm is learning this improper behavior and making it much worse. I know a some people on this forum also reported a jerky de-acceleration in traffic, jerky cornering at low speed, and absurd behavior of the Auto Start/Stop system in near-stop conditions or having the engine randomly engage when perpendicular traffic is crossing ahead. It is likely some of these problems have the same root and caused by same gremlin. The reason why this problem is so random is because it involves so many factors: the Driver Assist package your car has, the presence of the traffic in your daily commute, type of the traffic, consistency of the traffic conditions in your total commute, distances between your car and those front of you and the cars on the side of you, the speed of your vehicle, the speed of other cars around you, and also depends greatly on your style of driving. The reason I am saying this is because the time frame for this problem to manifest is very short. I my case this occurs when I accelerate slowly, the speed of the vehicle is less than 20 mph, and there are cars around of the vehicle. Based on the data collected from my GPS and accelerometer the “JERK/JOLT” appears in between the gear switches, and not with the gear switches as I had thought originally. After the problem was learned by the adaptive transmission algorithm, the car can develop this behavior even in the absence of some of these factors and may, for example, start doing it several times in a row during acceleration. Unfortunately no dealer nor BMW NA seem to really care or are not capable of fixing the problem in my experience! A SOLUTION, although short term, to this problem is to the reset of the Adaptive Transmission. It is not fixing the root of the problem and will not gives you long term relief, in my experience, unless you are generally alone on the road. But at least it is better than to live with the great wall of silence and complete incompetence in regards to this issue from BMW NA and some of their dealerships. |
02-01-2020, 07:39 PM | #17 |
Rep 201
Drives: BMW X5
For the first 10000 miles, the extended warranty should be available at the same price as new. It might be a good investment. You can get it from any dealer. Ask for their best price. Then ask if a rebate is available.
02-03-2020, 07:53 AM | #18 |
Rep 766
Smooth on acceleration. Some jerkiness on downshifts when decelerating no matter what drive mode I'm in. It's slightly annoying.
2020 M340i xDrive, Portimao Blue
2019 X5 xDrive 40i, Mineral White 2006 S2000, Berlina Black (Track car) |
02-27-2020, 09:23 PM | #19 |
Rep 66
Having the same rough downshift randomly when driving slow. Anyone find a solution to this? Should I be concerned about the tranny going bad in the long run?
02-29-2020, 06:28 AM | #20 | |
21
Rep 45
By turning off all front collision and pdc systems for a while would it improve behaviour? I'm not having problems but maybe worth a try for those who are having trouble... |
09-28-2020, 12:54 PM | #21 |
Rep 431
I'm having this issue with my X7 just wondered if anyone is still suffering this or found any fix ?
X7 40i - Mineral White - Merino Coffee - Lots of toys
