      02-25-2020, 06:41 PM   #23
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
Originally Posted by randybobandy View Post
They need to start a BMW Camp for adults...kind of like space camp for kids!
Done:
- PCD
- https://ude.bmwusa.com/
- https://www.mantripping.com/mancatio...alifornia.html
      02-26-2020, 07:55 AM   #24
eagle_bmw
Drives: 2019 BMW X5 40i
I know this is probably common knowledge on here, but I just discovered the kick down feature after reading through the manual again. Hands down the most underrated feature. With people driving like lunatics, and now allow you to merge...this feature is crazy. I’ve been using it quite a bit over the past couple days.
Do you guys prefer this, or something else...like paddle shifters or switching to Manual mode? Really hope I don’t screw anything up using this!
I came across this M4 video, FF to @10.25, and I wonder if this is available in the x5 (I'm away so can't try it)
Basically he did a kickdown then downshift once. It will switch to the lowest appropriate gear.
2019 X5 40i M-Sport
07/2020.54 -> 11/2020.50 -> 03/2021.50 -> 07/2021.85 [All OTAs]
thereef5101165.00
      02-26-2020, 08:10 AM   #25
randybobandy
Rick James
randybobandy's Avatar
305
Drives: 2020 BMW M340i xDrive
eagle_bmw ...that's one of the better explanations of it. It's just a subtle difference from downshifting via paddles/manual mode. I think the advantage is for people who drive in Adaptive. Yes, the vehicle adjusts based off the conditions, but using the kick down feature is a lazy man's way of blasting past traffic. I really like it on merging and passing.
I think I may have worded this post to seem like is was magic and hidden. Nope. Just another way to get the most out of the vehicle without paddle shifting or going into manual mode. Once again, the vehicle will typically be "smarter" than the driver when it comes to certain things. I should've prefaced the post for all my peeps rocking the Adaptive life-style. Now, it BMW would just let me start up in Adaptive and turn off ASS without coding...I would be in heaven.
eagle_bmw182.50
thereef5101165.00
      02-27-2020, 05:34 AM   #26
X5_CC
X5_CC's Avatar
289
Drives: X5 40i
I think really the benefit of kickdown switches over using the paddles is that kickdown causes a shift to the lowest gear possible.
Example of cruising in 7th or 8th gear at maybe 40 mph (not sure how fast you have to cruise to be in 8th) and you suddenly want to pass someone or get to speed quickly. Kickdown switch would drop it to second gear straight away, while paddles would require you to shift down sequentially through all the gears before you get to the lowest possible gear.
      02-27-2020, 07:46 AM   #27
BBDDVV
Belgium
11
Drives: G31 530e
Oh, did they remove/change some of the paddles behavior compared to what they do in the F15?
https://f15.bimmerpost.com/forums/sh...23&postcount=3
      02-27-2020, 08:03 AM   #28
eagle_bmw
Thanks. This is good to know. I'd be interesting to try it with different modes to compare responses.
For continuous manual mode it looks like the x5 has the same behavior as the M4 video that I posted, at least based on the driver's manual. I have to try this as well 😃
2019 X5 40i M-Sport
      02-27-2020, 08:18 AM   #29
X5_CC
X5_CC's Avatar
289
Drives: X5 40i
https://f15.bimmerpost.com/forums/sh...38;postcount=3
That's interesting.. I'll have to try that.
Seems a little redundant to pull the paddle when you're probably gonna floor it anyway and hit the kickdown switch which accomplishes the same thing. Not sure why that doesn't work in the M car in the video posted above.
      02-27-2020, 08:38 AM   #30
thereef510
thereef510's Avatar
Drives: '16 X5 35i, '20 X5 40i
wait it doesn't start out in adaptive every time??? I have to set that? here I thought I was driving in adaptive these past two weeks. wtf, how can you tell which driving mode you're in?
      02-27-2020, 09:53 AM   #31
VTENGR
1053
Drives: 2020 X5 M50i
If you're in manual shift mode, in the upper gears (7 or 8) the kickdown switch wont' automatically downshift. At least that's my understanding from watching the demo on the M4 in the video above. Kickdown will only downshift if you're in automatic mode.
      02-27-2020, 09:53 AM   #32
VTENGR
1053
bottom right hand corner of the gauge cluster wills how what mode you're in.
thereef5101165.00
      02-27-2020, 10:20 AM   #33
thereef510
thereef510's Avatar
do you happen to remember how to enable that on-screen notification that pops up whenever you switch driving modes? I remember I disabled it but I don't remember which menu it was disabled in
      02-27-2020, 10:22 AM   #34
VTENGR
1053
Are you talking about the center infotainment screen? I didn't even know you could disable it! I'm going to look into that and see.
      02-27-2020, 11:01 AM   #35
thereef510
thereef510's Avatar
you can definitely disable it and I did so in our F15 because I was sick of the car broadcasting my driving mode to any passenger. I'm pretty sure I disabled it on the G05 as well, but I'm still fumbling my way around all the menus they have in this one.
      02-27-2020, 11:05 AM   #36
VTENGR
1053
Keep me posted because I get annoyed by the animation and was just recently wondering if there's a way to disable it. I just flipped through idrive just now to look for a setting but couldn't find one.
      02-27-2020, 11:11 AM   #37
thereef510
thereef510's Avatar
Found it: Car -> Settings -> General Settings -> Pop-ups -> Driver Experience Control (enable/disable)
I enabled it for now, but I just found where it says "comfort" in the instrument cluster and I'll be sure to check that every time I drive and make sure it's set to adaptive so I may go back and disable the pop up for the main iDrive screen because I think its tacky to broadcast it like that.
on another note, this passage here seems to suggest we can set a driving mode and assign it to our profile and it'll stay like that?
      02-27-2020, 11:34 AM   #38
VTENGR
1053
Thanks! That's the first place I looked, but I must of glanced over that since it was the very first option.
The individual modes get saved to your profile, but they don't get set to a default. These are if you want to customize the configurations for SPORT and ECO modes. Both of those modes have an Individual option where you can tweak the throttle response, suspension, steering, etc.
The only way to change the default start mode is via coding. Apparently Bimmercode's new iOS version that has yet to be released will allow this. Currently the only way is via Esys using a Token.
      02-27-2020, 11:37 AM   #39
eagle_bmw
Correct, only on auto mode. I just tried in both comfort and adaptive and both works with just a kickdown.
I also tried it in manual mode, as per the manual I posted above. I was moving at 50 mph, set to M8, kickdown and immediately pull the left paddle shifter and it switched to M2. Put a smile to my face 😁
2019 X5 40i M-Sport
thereef5101165.00
      02-27-2020, 11:50 AM   #40
randybobandy
Rick James
305
Adaptive should be the default! Also, let me turn off ASS without coding! How can it be good for your car when it shuts off then on when I’m trying to pull into a spot or at a stop sign for 5 seconds. The person who developed this concept for the automobile world should be punched square in the nuts.
thereef5101165.00
      02-27-2020, 11:55 AM   #41
VTENGR
1053
I agree with Adaptive being the default - not sure why they don't allow you to choose - thank god ECO is not the default!!
WRT ASS - My last car did not have it, when I would get loaners, I hated it. When I took my X5 home, I left it on and said to myself if I still hate it after a month, then I'll turn it off. A month later, I don't hardly notice it anymore.
      02-27-2020, 12:05 PM   #42
randybobandy
Rick James
305
It’s part of my pre-space launch sequence...lock doors, turn on adaptive, turn off ASS, then prepare for take off.
RVAGuy167.00
      02-27-2020, 12:33 PM   #43
thereef510
thereef510's Avatar
you can set ASS to off in the F15 and it'll stay that way, idk why they reverted it back to on as default in this new iteration. there should at least be a 3 second gap after you stop before ASS kicks in or some pop up option for you to disable ASS for a while (a long line of cars at a 4 way stop; light about to change to green). I like the concept but it could be implemented a lot better than it currently is. Right now ASS mostly stresses me out.
      02-27-2020, 12:36 PM   #44
thereef510
thereef510's Avatar
why do you lock the doors? You can set it to lock and unlock automatically after the cars moving at like 5mph or something
