05-03-2021, 10:09 PM | #1 |
18117
Rep 11,746
Drives: 2018 M4 Comp Indv
X5m Differs From M50i Because ...
Yeah so I keep reading "ZOMG X5M is so much better bro!" posts, but yet nobody can detail why.
-------------------------------------------------------- EDIT: SUMMARY OF DIFFERENCES HERE -------------------------------------------------------- "different parts" - really? Where is that documented? Not saying it's not true, just that nobody seems to have any tech details on this stuff which is odd for any M forum ... I've been driving an M3/4 for 15 years and there's always TONS of technical info on why the M3 engine is "bespoke" but with the F95/6 seems like a lot of vague references to totally-better-bro but no details. The M site, for example, lists 6 things, so let's get into it and then you expert owners can add to it: "M TwinPower Turbo V-8 engine" Includes four water pumps, six radiators, and a dedicated transmission cooler. How is that different than the M50i's "M TwinPower Turbo V-8 engine" & cooling? Any tech docs, links? 8-speed M STEPTRONIC automatic transmission How is that different than the M50i's "8-speed Sport Automatic transmission"? Any tech docs, links? M xDrive M xDrive ... Adjust between 4WD and 4WD Sport for a rear-biased, sportier drive. How is that different than the M50i's "xDrive all-wheel-drive system" Any tech docs, links? M Sport Differential ...transmits torque and continuously sets an optimal degree of lock between the rear wheels How is that different than the M50i's "M Sport Differential" Any tech docs, links? Adaptive M Suspension Professional precise steering response and high body rigidity with adjustable drive modes How is that different than the M50i's "Adaptive M Suspension Professional" offered in the DHP? Any tech docs, links? 6-piston front M compound brakes ventilated, drilled brake discs provide maximum cooling and endurance. This one I may know! The M50i's "M Sport Brakes" are, I think, 4-piston fronts and rotors are smaller but finding confirmation is hard Net-net: These vehicles seem to differ technically with the X5M having: (1.) More bracing Per Savage Geese but no details on what "more" is - docs? (2.) Slightly more horsepower from the same engine If you say "bespoke bro" then please point me to the docs (3.) Possible more cooling? Unconfirmed the cooling differs from M50i (4.) Larger brakes and rotors While kinda unconfirmed in that no docs, various descriptions of "m sport" vs "M compound" seem to indicate this. (5.) Possibly tunes of suspension, steering Both have "Adaptive M Suspension Professional" suspension, X5M lists "M-tuned electric power steering with M Servotronic" but no details if that's tuning, components, both, or none. The M50i also has IAS, i.e., rear wheel steering, whereas the X5M does not. School me up!
05-04-2021, 10:10 AM | #4 |
Rep 190
Does it really matter? Drive both, see which you like more.
Personally, I'd probably get an M50i because of the air suspension and more comfortable ride for my growing family. If my kids were older, I'd probably go full X5M. For my reasons, I wouldn't care about difference in parts. Just the difference in drive experience. |
Busa Dave72.00 |
05-04-2021, 10:15 AM | #5 | |
Rep 3,506
When they are running the N codes you will see blue parts bins for the V8. The reasoning for this is the parts in those bins are not the same as the parts entering the S code motors. There are some shared bins Yellow mostly bolts or bolt on attachments pulleys, sensors ect. Now when they have a S motor coming down (same for ALL S codes compared to N codes) they get the gray bins for parts (mostly internal parts, pistons, connecting rods, rings, valves, springs ect). They will also divert from the main assembly in some cases for manual assembly that the machine cannot do. From my understanding S motors use lighter, tighter tolerances, higher strength internals due to the nature of it being track focused build. Even the oil they put into the motor is different before it goes on to cold and hot testing. Also like stated before adding cooling ect are also apart of the mix. The bottom line is you are not being sold the M badge for a tune, its much further than that and it goes back to the developers from the M team who created that spec. They take what is used on the track and put it into the M series vehicles. The plant was awesome by the way and recommend anyone around Munich go check it out.
2022 M8 Comp Convertible
05-04-2021, 11:15 AM | #6 |
Rep 264
Since the M cars get parts from the BLUE bin, does that mean they are all boys?
2019 M5 Competition
2021 X6 xDrive40i M Sport 2018 Toyota RAV4 AWD 2008 Corolla S Souped Up - The Black Widow |
05-04-2021, 01:53 PM | #7 |
Rep 236
I don't get the OP's question. I don't think this is the case, but suppose the answer was that the parts for both cars were taken from the same bin but were "tuned" differently - would that make the two somehow the same in your mind?
05-04-2021, 02:16 PM | #8 |
Rep 3,506
HAHAHA Mine is a she so I'd say nope.
05-04-2021, 03:35 PM | #9 |
Rep 236
(Slightly old) article on engine differences: https://bimmerlife.com/2018/08/23/n6...and-evolution/.
Also this: https://www.caranddriver.com/feature...them-the-same/ |
05-04-2021, 06:53 PM | #10 | |
Rep 444
X5 Brake Summary |
05-04-2021, 07:58 PM | #11 | |||
Rep 732
The rest is mostly in plain view, such as the brake calipers, floating rotors, front & rear bumpers, seats, etc. - we could go on. With all due respect, my 11-year old nephew could pick out the differences between an F95 and G05 M50i, if this point is understood. Others are not so obvious, such as the M-specific dampers, iDrive software configuration. Quote:
The G80 also has a wealth of empirical data and media detailing the differences of the S58 motor & chassis dynamics when compared to an N58 & a G30 platform. BMW puts in more resources into marketing the M3/4 cars over others. I recall the lack of documentation outlining the differences between an M850 (which is a tremendous car in its own right) and an M8 Competition. As seen when I was trying to get an M8 back in Dec 2020.
'23 F93 M8 GC ZCP - HRE S101SC - Full Akrapovic - '15 Audi R8 4.2 S-Tronic (Past) YouTube '21 F96 X6M ZCP Akrapovic/MSS/BC Forged, 18 G30 M550i, '18 G01 X3 M40i, '15 F10 M5 ZCP HRE S101 #1 & #2/Akrapovic, 13 W204 C63 AMG - ADV1 5.01SL's |
pookiemalibu312.00 |
05-04-2021, 08:01 PM | #12 |
Rep 593
I dont know about m50i vs true M when it comes to X5/X6 models, but I had a m235i and have a m2, and they are completely different. Body panels, lights, drivetrain, everything is different down to the fuel door.
Marmugmotleocay1568.50 |
05-04-2021, 08:06 PM | #13 | |
18117
Rep 11,746
TL;DR ◆ The engines are extremely similar (same block, same materials, et al), even with the same torque (see pic below) ◆ However, the S63 has a few key upgraded components to account for higher horsepower (e.g., cylinder crown) ◆ And the S63's oil cooling (suction pump, outer oil sprayers) is significantly more robust to account for high-g lateral acceleration forces when tossing it around a track - this appears to be the core difference / improvement over the N63 for non-tuners. Thus the S63 is a better platform (stays cooler longer at the limit) for frequent track or high speed canyon runs, and after-market tuning ... here's why: My casual review of the tech docs, flipping between engines: The S63B44T4 engine is ... an advancement of the S63B44T0 engine and technically based on the N63TU2 engineEngine load diagram overlay - N63 in grey lines & text Kinda hard to read, but basically the engines have similar low-end performance, but the S63 winds out more 553 lb-ft@1800-5600; 600HP@5600-6700 ▸ 553 lb-ft@1800-4600; 523HP@5500 Clean up: Net-net: Extremely similar engines, with the S63 winding out just a bit more providing just that extra bit of fun. The S63 also has more track tolerance (though in the X5M the brakes may limit you pretty fast - see AutoTopNL autobahn review), and highly likely more tuning tolerance.
05-05-2021, 06:41 AM | #14 |
1231
Rep 1,918
Drives: 22 M8C Coupe, 21 X5MC
Ummm… just go drive them back to back like I did. Feeling is completely different. They feel so vastly different that it doesn't really matter how they got there.
The confidence and speeds you can take turns on X5M is just amazing. Front end grip is immediately noticeable. What you are trying to claim can be said of most modern M cars. Difference in actual parts are shrinking and engineering in feeling and performance is going up.
Previous
21 X5M MBB, 20 Evora GT, 20 C63S Coupe,19 X5 50i, 18 Giulia QV, 18 M5, 17 Evora 400, 18 LX570, 17 GT350,18 M4 Comp,17 R8 V10 ,17 M3 Comp,17 GT350,16 Escalade Plat ESV, 16 570S,16 911 GTS,15 M5, 15 LX570, 13 M5,13 Viper,14 Cayman S,13 M3,13 S4,10 RX8,12 A4,10 G37, 04 Mini Cooper S, 08 Scion TC, 06 Altima V6, 05 Altima, 01 Altima, 00 Altima, 94 Explorer, 92 Toyota Pickup, 98 Altima |
05-05-2021, 07:58 AM | #15 |
Rep 196
Yeah weirdly they did not release an f95/6 specific doc- but certainly the engine is the same code as the f90 and a lot of the described brakes/suspension/mounts/bracing/etc in the f90 technical manual appear to have been done the f95. This whole narrative should similarly apply to the f90 vs g30 if you dont think the changes are sufficient enough to warrant a a new chassis code. I will say the differences in the f90 comp vs regular appear to be more pronounced than f95 comp vs regular. Due to lack technical document I think there are still some debates about what those differences actually are.
05-05-2021, 08:01 AM | #16 | |
Rep 430
05-05-2021, 06:54 PM | #17 | |
Rep 3,919
IF you know your CA well and he/she has a connection at BMW Corporate, it's available. |
05-05-2021, 10:31 PM | #19 |
Rep 426
I tried but nobody posted anything. As for myself, I dont have access
https://g05.bimmerpost.com/forums/sh....php?t=1784527 |
05-05-2021, 11:12 PM | #20 |
Rep 3,919
05-06-2021, 07:41 PM | #21 |
Rep 273
Avoided posting on this thread initially. But my $.02.
in sum: You could have told me the massaging seats in the M50i came with a happy-ending and I'd still be in an F95 (Lord Willing). It looks, sounds and drives better (to me) and it's easily discernible to true Bimmer fans that it's another level of a car. Sure it's got the same engine or whatever but all the technical stats don't really matter (except horsepower and such -- to me). The (non-literal) ///M Competition Badge does though. I considered both cars when shopping. My local dealer had an M50i with a similar spec to what I liked and I was close to pulling the trigger. Ultimately, I ended up going with an F95. It came purely down to aesthetic for me. Well that and being the BAMF with an X5MC. Plus I wanted the Sakhir Orange interior, seats and mirror caps. Overall, IMHO, just a better looking and feeling car. I like waking the neighbors when it cranks up. Call me vain. Call me conceited. Call me pretentious. The monikers all fit and I'm not ashamed at all. I worked hard to get to a point where I'm blessed enough to afford the car I wanted so I got it. The F95 is just an overall better car. Period. Full stop. M50i owners can try as they might to say it's the same car less the extra horsepower, seats and moldings. Once BMWNA agrees I'll retract my previous statements.
_____________
PookieMalibu Res Ipsa Loquitur |
cubanbimmer3310.00 mnewnam269.50 |
05-06-2021, 08:49 PM | #22 |
Rep 79
I drove both and felt that the "M" was better suited to me and my wife. She liked the difference in the seats to the handling as well. She is not a motor head but it was her preference.
As posted above there are specific differences. Up to you personal preferences to choose. Kind of like the new Ram 1500 I just bought this week. Yes I feel the TRX version is worth the difference. Not to mention it is a true beast.
2021 Mineral White X5 M
155ND907.00 |
