      01-29-2019, 06:09 AM   #111
SCA
SCA's Avatar
Drives: Multiple BMWs
Updated 01.29.19. See attachment
      01-29-2019, 10:52 AM   #112
robby818
Drives: M2
Yes! Worked. My X5 now remembers my last auto start stop setting. I am using the veepeak adapter.
      01-29-2019, 11:09 AM   #113
batm4n
Drives: 2019 4.0
Do you get any error messages or warnings on the dash when you program it?
      01-29-2019, 11:12 AM   #114
robby818
Drives: M2
Only after programming is complete. The normal chassis error message.
Before you code remember to do this step:
Turn on the ignition in the car or start diagnostic mode in G Series cars (press the start button in the car three times in quick succession without pushing the brake or clutch pedal).
      01-29-2019, 01:23 PM   #115
ScottMZ3
Drives: 2018 Camaro ZL1, 2019 X5 40i
Yeah!! I have the Veepeak adapter as well! Will have to try this tonight.
- Scott
Current Cars: 2019 X5 xDrive40i M-Sport, 2018 Camaro ZL1
Past BMWs: '16 528i, '00 M-Coupe, '14 X1 sDrive28i, '00 740iL, '02 325i, '99 M-Coupe, '00 323Ci, '79 323i, '83 320i
mnewnam269.50
Almaretto2374.00
      01-29-2019, 01:49 PM   #116
vinnymac
157
Drives: 2024 X5 50e
I just ordered the VeePeak adapter. I need to code some things on my X5 40i and my wife's X3 M40i. Can't wait to try it.
      01-29-2019, 02:09 PM   #117
First BMW
Drives: X5 on order
Can you share a link of which Veepeak adapter? Thanks and what all can we do to the X5 with this?
      01-29-2019, 02:26 PM   #118
denniss
denniss's Avatar
392
Drives: BMW
https://www.amazon.com/Veepeak-Scann.../dp/B00WPW6BAE
maybe this ?
2022 x4mc (gone)
2019 X5 40i M-Sport (gone)
2016 X5 35i M-Sport (gone)
      01-29-2019, 02:51 PM   #119
SCA
SCA's Avatar
http://www.bimmercodeapp.com/adapter/
      01-29-2019, 02:52 PM   #120
robby818
Drives: M2
I used this one.
Veepeak OBDCheck BLE OBD2 Bluetooth Scanner Auto OBD II Diagnostic Tool Compatible with iOS & Android, Bluetooth 4.0 Car Check Engine Light Code Reade https://www.amazon.com/dp/B073XKQQQW..._j46Zp3A3INbmZ
The configurable settings are extremely limited. I think start stop is the only thing that can be changed right now. No doubt that more options will be available in time
      01-29-2019, 03:08 PM   #121
vinnymac
157
Drives: 2024 X5 50e
This one...
https://www.amazon.com/Veepeak-OBDCh...403a356b82a4e8
      01-29-2019, 03:52 PM   #122
First BMW
Drives: X5 on order
Thank you for the info
      01-29-2019, 04:17 PM   #123
bigdaveindubai
208
Drives: 2018 540i
Ordered!
2018 540i
2019 X5 xDrive40i
2012 Boss 302 #2147
2017 Shelby GT350
2017 F250 KR
      01-29-2019, 09:39 PM   #124
ScottMZ3
It worked!! Used my Veepeak adapter with an iPhone. No issues at all. Put the car in diagnostic mode as suggested (3 quick presses of the start button without foot on brake).
- Scott
      01-30-2019, 01:56 AM   #125
tajny
Poland
Drives: G05
Hi, where is this conector exactly located? Under steering wheel? Do I have to remove any part to get to it?
      01-30-2019, 09:31 AM   #126
maze446
Drives: 2019 X5 50i
It's on the underside of the dash on the left side down by the dead pedal / footrest. Nothing to remove. If you stick your head down there you can see it.
      01-30-2019, 11:44 AM   #127
cygnusecks
cygnusecks's Avatar
Drives: X5 (G05)
Is coding still limited to certain OBD2 adapters? I have the Kiwi adapter.
      01-30-2019, 11:52 AM   #128
First BMW
Drives: X5 on order
yours should work
      01-30-2019, 11:54 AM   #129
cygnusecks
cygnusecks's Avatar
Drives: X5 (G05)
yours should work
Thanks! Will give it a go this weekend.
      01-30-2019, 02:23 PM   #130
ssadri
ssadri's Avatar
Drives: 2022 BMW 540xi M-Performance
Has anyone been able to test the "Black panel instrument cluster coding"? if so, what does it allow you to change/add/remove/code?
      01-30-2019, 02:55 PM   #131
ScottMZ3
The only coding option available on the G05 right now is the Start/Stop feature. Hopefully more will be available soon.
- Scott
ssadri68.50
      01-30-2019, 05:37 PM   #132
incubatewhisky
25
Drives: 2019 BMX X5 (G05)
Originally Posted by incubatewhisky View Post
Originally Posted by maze446 View Post
I have both UniCarScan and Veepeak and neither of them work for me in coding Auto Start Stop off. When I go to read the ECU where the ASS toggle should be it keeps giving me an error that it can't be read.
Same for me I got the UniCarScan in the mail yesterday, and it failed to load the Engine Control Unit module (the car was in debug mode).
FWIW the most recent bimmercode app update solved my issues quoted above from last week. I can now code to remember Auto Start/Start setting after turning the car off.
TechCTU763.00
