      07-24-2023, 10:26 AM   #1
Eagle1788
Drives: 911 4S Cabriolet, Cadillac CTS
Failed Front Differential at 55k
Have overall been pleased with my 2020 BMW X5 M50i. However, at 55k miles I bring it in for a noise and I'm told the front differential needs to be replaced at $9K! BMW only offering 4k in assistance leaving me with a 5k bill on what I consider a premature part failure. I shouldn't have to be spending that kind of money to repair what is allegedly a solidly built luxury vehicle. Makes me want to never invest in a BMW ever again.
      07-24-2023, 12:12 PM   #2
Tejas1836
Tejas1836's Avatar
996
Drives: 2023 X5MC Workmaster 75
Yeah, that should be good-willed. My brother had a ~6 year old Camry with about 90K miles on it and the transmission went out. Toyota put a new trans' in it for no cost and they wanted the old trans' sent back to Japan so they could inspect it.
Two is One and One is None
      07-24-2023, 12:16 PM   #3
chefwong
Drives: X5
Sounds like BMW NA is good willing the part cost - and the labor is super inflated on the dealer side ? Just curious. OE tire sizes on OE wheels ?
X6ix GTA142.00
      07-26-2023, 08:39 AM   #4
Eagle1788
Yes, both are OE.
eluded3041.50
      07-26-2023, 09:12 AM   #5
chefwong
Drives: X5
You know there are threads that come and go about diff and tc's....
Dindn't read much on them but presumed anywhere from driving like a hoon or wrong sizes, etc
Never have taken a deep dive cause after 4 years, they're gone
      08-10-2023, 12:53 PM   #6
Two4me
Two4me's Avatar
26
Drives: M240i, X5 xDrive50i, MX-5
Ours did the same. I blame the fluid and BMW's refusal to do fluid changes on them as they insist it's "good for life"
We had it covered under an extended warranty contract though, so it was their loss.
      08-15-2023, 04:26 PM   #7
jmansfield
Drives: 2020 X5M50i
Unhappy Exactly same car and same failure at 52500 miles
I am working through the same exact issue, just barely past the 50k mile warranty for power train. Waiting to see about assistance from BMW for cost coverage of the $9000 estimate. I have babied this vehicle, can’t believe it’s got an issue like this!
      08-16-2023, 05:30 PM   #8
chefwong
Drives: X5
Been doing a brief read and I concluded it appeared to be mainly a 2019 issue - and possibly wrong/not up spec fluid in the TC.
Hence the tsb was fluid change 1st and if the problem didn't go away, then replace...
So far, on the most recent reply, I think this is the 1st one mentioned a chassis past 2019
      10-19-2023, 10:31 PM   #9
Bking60
Drives: BMW X5 2019
TC?
The front differential uses a different oil than the TC so not connected.
My notes show 83-22-2-413-511 for front differential which is G2 75W85 with a GL5 rating. One pint bottles, holds two. X5M might be different fluid.
      11-03-2023, 08:31 AM   #10
Raytown Pete
Drives: BMW X6 M50i , BMW 2021 X7 M50i
Just had the front diff go out on my '21 X6, dealer called to say 10 hour job and would be covered under warranty..
      11-10-2023, 09:16 AM   #11
Alan l.
Alan l.'s Avatar
5450
Drives: 2020 F95 X5M Competition
What symptoms did you guys have when the came up? I take it everyone was running OE tires/wheels but was there any instance where tires weren't replaces in pairs or sets?
Makes me wonder if i should bring my 2020 X5M in and have the dealer just do the fluids (pay out of pocket) on the diffs and transfer case as a precaution. Interested to see of the parts are exactly the same between the M's and the normal X5s. You would think the added stress of having more power would cause this to pop up more frequent on the M models.
Alan
      11-20-2023, 05:01 PM   #12
Bauwer
9
Drives: X5 M50i
Just had a leak in my 2020 X5 M50i (40k miles) - turns out my front differential is broken and currently getting worse as the car is driven.
Costing me $6.1k at a German Auto Shop and not BMW...
eluded3041.50
      12-06-2023, 06:25 PM   #13
Alan l.
Alan l.'s Avatar
5450
Ouch..... no warranty?
      12-06-2023, 06:54 PM   #14
DontGetPassedOnTheRight
DontGetPassedOnTheRight's Avatar
15
Drives: G05 X5
BMW NA is not what it used to be. Hope your problem is clearly covered under warranty or go kick rocks.
2020 X5 40i (current)
2020 330i
1998 528i
eluded3041.50
      12-09-2023, 01:42 AM   #15
Bauwer
9
Drives: X5 M50i
No warranty - smh
      12-12-2023, 01:18 AM   #16
leejim
Drives: 2019 X4M40i & 2012 X535d
Oil change / service intervals!
Hi, I got a new X4 M40i in 2019. I asked about oil changes was told car will tell you ? So as I have another car ( X5) the X4 doesn't do high mileage. So at 10k kilometers ( we are in metrics in NZ ) I asked when were they going to change the oil & filter etc? 30,000k I was told ? I said that's far to long it would be 3 yrs at least! So I asked for it to be changed and would pay for it to be done. I was told no! BMW say 30k.
So I changed it myself, carefully using a genuine BMW filter and the oil they recommend. I have done this twice now and I have had only 2 of the free services ? Strangely now the free servicing is over there appears a Lube sticker on the windscreen with the change interval 10,000 kilometers? When the car comes out of warranty July next year I will make the rules. Only had 2 warranty items done in 43,000 kilometers , a new coolant bottle as the original one leaked at one of the fittings and only 1 month ago the driver assist ( what ever you call it that corrects the steering when you drift over the white lines ) that motor had to be replaced on the LF wheel.
      12-21-2023, 01:30 AM   #17
eelnoraa
Drives: G05 X5
in what way does the front diff is broken? front and rear diff in BMW is just open diff, right? Torque vectoring is done by torque braking. If this is the case, open diff is a very simple device, really nothing to break. Is it just leaking?
2022 G05 B58/PHEV
+ a few very old BMWs
Tags
front differential, premature part failure
