08-14-2010, 11:54 AM | #1 |
Administrator
40911
Rep 21,240
G-POWER M5 Hurricane hits 231mph / 372kmh speed record
Featured on BIMMERPOST HOMEPAGE.
From G-POWER: 372 km/h - The World's Fastest Sedan G-POWER HURRICANE RR based on the BMW M5 G-POWER M5 HURRICANE RR
Following up on the G-POWER M5 HURRICANE RS powered by a G-POWER twin-supercharger engine with 750 hp/551 kW, which has set the record for the ‘world's fastest sedan' at 367,4 km/h in early 2010, G-POWER did it again. But this time with 372 km/h! With this target in mind, the development for the new evolutionary HURRICANE RR with 800 hp began. A few weeks ago, the air is tight with tension when the G-POWER engineers give their "go" for the M5 HURRICANE RR to manage the ultimate test: High Speed. It takes only a few minutes to change the standard 20 inch G-POWER forged wheels to 19 inch ones. The wheels, especially fitted with Michelin Pilot Sport tires that Michelin are certified for top speeds of more than 370 km/h. The HURRICANE RR is ready to go, the test track as well. Apart from the swop of the wheels the HURRICANE RR is completely standard and relies predominantly on its power of the bi-supercharger engine. And just a few laps later it is done. The analysis of the engineers states a top speed of 372,1 km/h. World record! Once again... To achieve this extreme performance, the twin supercharger system of the high-revving V10 has been redesigned. The two superchargers named ASA T1-313 have been replaced by larger ASA T1-316 units. They are both driven by a belt and do provide each cylinder bank with supercharged air. This means more space for the supercharged air by up to 25 percent. The air volume being transported by these modified superchargers is able to generate a theoretical power output of more than 900 hp. The pre-compressed air from the superchargers is cooled for a maximum power output. A complicated aluminium casting - painted in G-POWER orange - replaces the standard air box on top of the engine, and its direct inlet is responsible for the spontaneous response characteristics which give the G-POWER motor its incomparable response and also much more torque. The inner workings of the 10-cylinder, four-valve engine are optimised by light, precisely balanced MAHLE high-performance forged pistons with lower compression and increased mechanical strength. As the standard connecting rods and piston pins were equally not up to the considerably increased forces, here too, recourse was had to special parts. An optimized mapping of the engine electronics also contributes to the increased power output of 800 hp / 588 kW, available between 7,500 and 8,000 rpm. The engine delivers its peak of torque of 800 Nm at 5,000 rpm. But the G-POWER HURRICANE RR does not only set new performance standards for top speed. With an acceleration of just 4.35 seconds from nought to 100 km/h, 9.5 seconds up to 200 km/h and 25,8 seconds up to 300 km/h the two-ton sedan is also leading his class. The G-POWER technology is available for all current M5 and M6 models. The G-POWER SK III bi-supercharger engine conversion with 750 hp / 551 kW starts at 56,000 Euros (net). In addition to the most powerful BMW engine ever being fitted to a street-legal BMW M5 a new aerodynamic for maximum efficiency was key. The HURRICANE RR is equipped with the G-POWER "HIGHLINE" body kit. In addition to provide the necessary downforce the body kit is also designed to provide significant more air flow to cool the engine. The body kit consists of front and rear skirts and spoilers, doors render and the rear spoiler. Two tons of weight and a top speed of 372.1 km/h naturally require extreme demands on the tires, being fitted on special G-POWER forged wheels. Our technology partner Michelin provided high-performance Pilot Sport tires in the dimensions 255/35 ZR 19 at the front axle and 305/30 ZR 19 at the rear axle for this reason. For every day use the G-POWER HURRICANE RR runs on 20-inch Silverstone CLUBSPORT wheels with the dimensions 245/35 ZR 20 and 285/30 ZR 20 front and rear. Even more contributions to the HURRICANE RR's high-speed talents are coming from a G-POWER high-performance brake system and the height-adjustable G-POWER RS coilover suspension that is adjustable for both compression and rebound in nine settings. The interior of the record car features a tachometer reading up to 400 km/h, clear-coated carbon-fiber panels for the dashboard, center console and door panels. An ergonomically shaped G-POWER sports steering wheel with especially perforated Kjerba Nappa leather is completing this package. The G-POWER HURRICANE RR can be ordered as a complete car starting at 251,100 Euros. Any current M5 model - sedan or station wagon - can also be equipped with the individual G-POWER components of the world record holder.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
08-14-2010, 02:51 PM | #4 |
28
Rep 310
2007 SG/Black e90 335i - Gone
2010 JB/Black e82 135i M-Sport - Gone 2013 JB/Black e90 335i M-Sport - Gone 2016 MBM f30 320i - Gone 2015 BSM/Black f15 X5 xDrive50i M-Sport - Current |
08-14-2010, 03:02 PM | #6 |
517
Rep 18,858
08-14-2010, 03:10 PM | #8 |
Rep 1,457
There is nothing interesting about it. It is a heavy powerhouse, and weight is rather important to achieve good 0-60 times.
08-14-2010, 03:28 PM | #11 |
16
Rep 329
without the bodykit and the wheels one would never suspect that this car is something special...what a sleeper!
not a fan of the bodykit though...the stock bumper and exhaust looks better...and most aftermarket bodyparts as well! |
08-14-2010, 03:29 PM | #12 |
16
Rep 329
08-14-2010, 04:36 PM | #14 |
Digger
207
Rep 2,619
Was thinking the same thing, that body kit is so
2009 E92 M3 /// Melbourne Red /// Fox Red /// M DKG
Full Innotech Exhaust - DINAN Intake - IND Engine Bay Appearance - IND Hand Stitched Boot Covers - and much more.... |
08-14-2010, 04:39 PM | #15 |
king kong in the trunk...
44
Rep 169
Hmm...even with 800 HP, 231mph seems a bit suspect, especially since the M5 doesn't have fantastic aerodynamics. I'll have to chip in and say "Video or it didn't happen." Besides, it's coming from the G-power folks. Had it come from Top Gear or InsideLine, then I'd probably have more confidence in the claim.
Some of my test drives: http://www.youtube.com/user/crooner12
08-14-2010, 04:54 PM | #17 |
Administrator
40911
Rep 21,240
That's the older G-Power Hurricane RS, which had 750hp and top speed of 228mph / 367.4kmh. But, really at this power and speeds we're splitting hairs
08-14-2010, 05:59 PM | #18 |
'Murica
48
Rep 596
Drives: 2006 E90 330i
that is f***ing sick!! and those look almost identical to the wheels we will see on the new f10 m5
Web developer at @ Apartments.com, digital media director, budding entrepreneur, technology guru and marketing nut with an affliction for the finer things in life.
I blog at http://ddigangi.com |
08-14-2010, 06:02 PM | #19 |
46
Rep 1,681
That's a badass M5. I have to agree on the body though, stock looks better.
2006 JB 330i/ZPP/ZSP/I-Drive/Heated Seats/L7/Blacklines/19" Gunmetal V710's on Vredestein Ultrac Sessantas/BMS PBX/Red MFD Scoops/Matte black grilles/Matte black Amber Gone 2.0s/BSW center midrange speaker/35% tint/Black and white roundels
08-14-2010, 06:03 PM | #20 |
633
Rep 24,685
Drives: '04 330i ZHP
WOW
08-14-2010, 07:12 PM | #22 |
A^M=G is nothing w/o the Power of ///M
171
Rep 1,816
Y does the hope page say same top speed as a McLaren F1? The F1 could hit over 241mph
Indianapolis Red BMW ///M5
