04-15-2024, 04:52 PM | #1 |
Rep 80
Pro Tip: You must enable climate control for remote start
LCI: It's in the climate control menu. After enabling this it informs me having climate control running with remote start is actually illegal in some states. I never knew this was a thing.
Otherwise remote start works fine but it just blows hot air in Florida until you get in the car and press the start button. Kind of useless for my use case. I thought it was broken. I'm not sure why this is a thing but maybe it has something to do with idling and camping out on public highways with a van, or maybe an environmentalist thing. Just kind of bizarre that you can remote start by default but it won't run the AC. |
04-15-2024, 04:56 PM | #2 |
Rep 1,107
Same for Pre-LCI.
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (car-show car) |
04-15-2024, 05:57 PM | #3 |
Rep 8,712
Drives: eVeRyOnE mAD!
tscharf when activating Remote Start, it should cool down the cabin with AC.
what are your HVAC settings before exiting? how much time are you letting elapse between activating RS and getting in the vehicle? |
04-15-2024, 06:31 PM | #4 |
Rep 80
I got in the car after remote starts and it was just running the climate control fans, but the AC was not on. (No AC animation in the temperature area and plenty hot after 10 minutes).
I searched the menu system and found the screens below. My vehicle is not a PHEV. I just tested it and the AC turned on this time after I enabled this. |
04-15-2024, 07:37 PM | #5 | |
Rep 164
Drives: 2024 BMW X5 M60i
04-16-2024, 04:44 PM | #6 |
Rep 6,814
Another couple of reasons it’s illegal some places to leave a vehicle idling is pollution and noise. Modern engines do not generally benefit from a long idle prior to starting off unless you expect to need maximum performance. Otherwise, taking it fairly gentle until it starts to warm is all that’s required. Obviously, it’s nice to get into a comfortable cabin, and that’s really the only good reason to use it. You get zero MPG while it’s sitting there idling.
Also note, that that option tends to be shut off each time there’s an OTA software update. Most of the stuff is ‘remembered’, but it seems that aspect may not be, or hasn’t been. Maybe newer updates records that information, but I’ve not seen it. FWIW, where I live, the anti-idling ordinances only apply to trucks. |
04-17-2024, 10:23 AM | #7 |
Rep 29
In Illinois, it is illegal to idle an unattended vehicle, but they exempted remote start (as long as it's locked). Also, there is no fine amount. That's the law essentially saying, "please don't do this."
The tougher anti-idling ordinance is for large diesels only. I know an older man in rural Wisconsin who every day drives around his property puttering with stuff and eventually falls asleep in his idling truck. His wife got him a Prius. |
