      05-01-2021, 10:58 PM   #45
prototyp
Drives: '19 X3 M40i
Originally Posted by AndroidRobot View Post
This one is 26oz and pretty large as you can see. The door pockets swallow it (pun intended)
also see pic of where I put the felt tape
That's proper felt-taping. Reminds me of my E90, I think by the time I was done chasing down each of the annoying little rattles I had gone through most of the interior assemblies. Was tight and quiet even at 100k tho.
2019 X3M40i DGM/black vernasca, 2T4, 2VF, ZPX, ZPP, ZDA, DWS06+, etc, etc. Since July'19.
2021 X540i MSport CBM/black merino, 337, ZMP, ZPP, ZPK, etc. Since Dec'20.
2006 330i SGM/black, ZSP, ZPP, 217, HuberOps, M Splits, K Lines, AS 3 on EC-7. Sep'08-July'19.
AGONXF30270.50
      05-05-2021, 03:20 PM   #46
jamespscott
12
Drives: BMW X5 G05
Follow Up Video
So I've made a video but I didn't eliminate the noise completely. I had to make a further adjustment after I stopped the video but it illustrates the process and you can hear the improvement.
I've had to make this adjustment every few days, each time making an incremental wind (out) because my office car park is a multi-storey so the car chassis flexes putting pressure on the tailgate. I also open and close my boot eights times per day which contributes to the misalignment.
What I've since learned is that there is only so far you can adjust the boot stop before it becomes counter productive. This is because the further you wind out the boot stop, the less stable it becomes and subsequently starts to contribute to the movement of the tailgate (generating the noise).
A better approach at this point is to wind in the boot stop until it stops wobbling and then apply electrical tape to the boot catch that presses against the boot stop. I'm going to monitor this and see how often I have to make adjustments (add tape).
I'll add a link to the video and post a picture of the tape.
Appreciate 5
      05-06-2021, 03:01 PM   #47
stockli81
Drives: 2021 X5 M50i
Originally Posted by Tokke View Post
Does your car have shadowline trim? If had a lot of interior creaks in my g01 that is was convinced of that they were coming from plastic trim in the interior. I spent a lot of time trying to silence it with no succes. After further investigation I realized that the shadowline trim also is a source of cabin noise from places were the trim is in contact with rubber seals or different pieces of shadowline trim. I gave the rubbers some gummipflege treatment combined with a silicone spray tour. My car has been silent for 2 days
I hope now it stays like this...
where did you spray all of this?
      05-20-2021, 02:03 AM   #48
Mark430
Drives: 430d
Can you please specify what type of a key and which size did you use for adjusting those boot stops?
      05-23-2021, 09:46 AM   #49
jamespscott
12
Drives: BMW X5 G05
It is a 12 point socket, 20mm. Electrical tape is a better approach as the more you adjust boot stops, the more they wobble and contribute to the noise.
      06-02-2021, 12:17 PM   #50
BrummyGit
United Kingdom
75
Drives: BMW X5 xDrive45e M Sport
Originally Posted by wanderlustX5 View Post
Although the X5 is sheer driving pleasure, The trunk of X5 is filled with cheap plastic I feel. There has been a rattle from the rear of my car at speeds above 60 on rough aggregated roads. I took to dealership, they kept for a day and couldn't even test drive it. So brought it back. Browsed forum. Seems like some people have been having this issue. Some have suggested applying black scotch tape over rear seat latch. Before doing that, I gently tapped everything in the trunk and found the push button to release and lock the cargo cover is creating that rattle or that plastic grill next to it (see photo). Any suggestions what can I do about it? I would hate to take it to dealer and waste 2-3 days for them to figure out. Thanks
My November 2020 built 45e currently has a similar wedge of paper in the cover release button. At the moment it seems to be the source of my annoying rattle but I need a little more time to be certain before I ask BMW to fix it.
      06-07-2021, 08:22 AM   #51
Mark430
Drives: 430d
Maybe we should try it this way. I am waiting for a 20 mm key to arrive and than I'll try it. Probably the right way is to wind boot stops in and not out.
Appreciate 3
      06-07-2021, 08:45 AM   #52
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7266
Drives: Audi BMW Ferrari LR MB
You can do it by hand.
      06-07-2021, 10:24 AM   #53
BrummyGit
United Kingdom
75
Just checked my car - I have movement and can recreate a very similar noise by pressing the tailgate over the right hand rubber stop.
My car is in for another warranty matter tomorrow so I will ask them to include this adjustment.
      06-07-2021, 11:45 AM   #54
Mark430
Drives: 430d
How? I tried but no way I can turn it by hand. It's to tight.
      06-07-2021, 04:16 PM   #55
iconoclast
iconoclast's Avatar
7266
Odd. I am able to adjust mine by hand and on previous X5 as well. Just twist the top portion and you will feel notches. Count the notches as you turn so you can match the opposite side.
      06-07-2021, 04:22 PM   #56
BrummyGit
United Kingdom
75
When I found mine today I noticed that the left hand side of my car is free to turn by hand, however the right hand side seems to be fully screwed down tight and I can't turn it by hand - almost as though it was never adjusted in the factory.
I wonder if it's always the same side that's been missed?
iconoclast7265.50
      06-16-2021, 03:45 AM   #57
Mark430
Drives: 430d
Hi, have you finally solved the issue by using that electrical tape? Did the sound reappear?
      07-27-2021, 11:20 PM   #58
skyliner10004
Drives: 2020 x5
i had a creaking from the trunk area and did this method of tightening down (the paper was originally very tight on both sides, would rip if i pulled) the rubber nub until the paper pulled out easily. Its hard to gauge how loose/tight would eliminate the creak, but i'll be going for a test drive tomorrow and reporting back
      12-31-2022, 05:48 AM   #59
Joe-BMW33
Joe-BMW33's Avatar
7338
Drives: '18 M550i|'21 X5|'03 540i
2013 VW Tiguan  [0.00]
2015 Infiniti QX60  [0.00]
2021 BMW X5  [0.00]
2003 BMW 540i  [0.00]
2018 BMW M550  [10.00]
Following
      02-09-2023, 12:12 AM   #60
DwainA
Drives: BMW X5 45e
Following too!
      03-09-2023, 08:07 PM   #61
BobT2019X5
Drives: 2019 BMW X5
My 2019 X5 has interior rattles that drive me crazy. There are at least two. One from the rear at the other is hard to tell. They are heard on surface streets and not so much at freeway speeds. The are high pitched, almost a vibration.They sound like they are exposed and not muffled by a dash or seat. The car only has 16,000 miles on it and has always been garaged and washed by hand. It is in perfect condition, except for the rattles. I am lost as to what to do. It is, no doubt out of warranty for this kind of thing. I did call the dealer once and left a message but did not hear back. This is not acceptable for a car of that caliber.
