12-27-2022, 11:42 AM | #46 | |
Rep 176
The batteries are in parallel. The only things that can change that is a safety disconnect and another disconnect at the front battery that is controlled by a controller. So parallel charging and parallel normal operation. You might catch on if I keep saying this but not likely. |
12-27-2022, 12:08 PM | #47 | |
13500
Rep 20,112
12-27-2022, 12:11 PM | #48 |
13500
Rep 20,112
Back when I did some testing on that it seemed like Eco Pro did not show the charging has often as the other modes, especially when coasting. I don't drive in Eco Pro so don't have a lot of experience with it. May be someone who does can chime in.
12-27-2022, 12:36 PM | #49 | |
Rep 176
12-27-2022, 01:23 PM | #50 | |
13500
Rep 20,112
As stated in the tech docs, the auxiliary battery is for running the electronics when the engine is in the start/stop state. It is not being used when the engine is running. There is a reason it is called an auxiliary battery. Just take a step back and think about it logically. We'll forget that BMW has said they aren't operating the same time and go with your situation that the two batteries are directly connected, whether that is even possible we won't worry about, and operating together as one battery. Why would they go through all of the trouble to do that when they could have just used a bigger battery?
12-27-2022, 01:50 PM | #51 | |
Rep 3,704
12-27-2022, 01:52 PM | #52 |
Rep 176
Success! You are now stating things that are mostly accurate.
You started out saying: The terminals in the front are for the rear battery. The secondary battery under the hood, AGM or Li depending on options, doesn't have terminals showing. (That statement is false) |
12-27-2022, 01:54 PM | #53 | |
13500
Rep 20,112
My statement is 100% accurate.
12-27-2022, 01:55 PM | #54 | |
Rep 176
12-27-2022, 01:56 PM | #55 | |
Rep 176
Sorry but I verified this on the car. Try looking and checking circuits on your car. |
12-27-2022, 01:56 PM | #56 | |
13500
Rep 20,112
12-27-2022, 01:59 PM | #58 |
Rep 176
Boy is biggest troll I've seen with many years on forums.
12-27-2022, 02:42 PM | #59 |
Rep 79
12-27-2022, 09:28 PM | #60 | |
Unapologetic Tool Hoarder
734
Rep 964
12-28-2022, 05:16 AM | #61 |
Rep 832
Based upon the schematic 4.1.2 on page 2 and in the absence of any blown fuses or SBT
-The main (rear) battery is always online and always providing power, ICE running or not. -Both batteries are connected in parallel (have to be otherwise you would have 24 volts spewing out if connected in series) when the auxiliary battery circuit is closed. -The auxiliary battery circuit, when instructed by the DME, is closed providing additional power if needed like stop-start mode, emergency electrical in the event the SBT circuit is open. Regards ETA: I ran out of popcorn Last edited by Tejas1836; 12-28-2022 at 05:17 AM.. Reason: ETA |
weinerbarn734.00 |
12-28-2022, 08:30 AM | #62 | |
13500
Rep 20,112
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50 Last edited by TurtleBoy; 12-28-2022 at 08:37 AM.. |
12-28-2022, 08:42 AM | #63 |
Rep 832
I think that both of you are right.
The auxiliary battery will provide emergency power for things like cellular SOS, flashers, probably door locks and windows...[in the event of a SBT open circuit] Last edited by Tejas1836; 12-28-2022 at 08:43 AM.. Reason: [] |
12-28-2022, 08:54 AM | #64 | |
13500
Rep 20,112
He is only correct on the point that he and I agreed on which was one also noted in the docs, that being that they were connected in parallel. As you have stated, he is not correct about how the auxiliary battery operates. Edit: It was an SIB concerning the system. Perhaps there is a special circuit for what you are describing. Maybe we'll run across more info. https://static.nhtsa.gov/odi/tsbs/20...66386-9999.pdf
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50 Last edited by TurtleBoy; 12-28-2022 at 09:07 AM.. |
12-29-2022, 04:42 PM | #66 |
Rep 1,206
