      01-18-2024, 02:53 PM   #1
scottminor
scottminor's Avatar
Drives: 2019 BMW X5 xdrive50i M Sport
Exhaust mod
Is this a stock xpipe? I didn’t think they came from the factory that way.
T3PO97.50
      01-18-2024, 03:04 PM   #2
KLCC
80
Drives: x40i BMW individual
That looks like a stock mid section resonator for the v8.
      01-18-2024, 05:20 PM   #3
scottminor
scottminor's Avatar
Is it hollow on the inside or is it restricted?
      01-18-2024, 09:22 PM   #4
Bottom16
Bottom16's Avatar
Drives: 2019 BMW X5 xDrive50i
Here is a pic of the inside of the resonator from an M50i. It’s pretty much straight through with some light baffling surrounding it. Hope this helps.
Cheers!
      01-19-2024, 08:54 AM   #5
scottminor
scottminor's Avatar
I tried the fuse pull last night for the valves but I don’t think it worked. The cold start on the 50 is amazing. I am guessing I need to disconnect the servos as well.
      01-19-2024, 12:52 PM   #6
T3PO
Drives: X5
That looks exactly like the stock resonator on the M60.
      01-20-2024, 11:50 AM   #7
scottminor
scottminor's Avatar
It’s also an xpipe as well correct?
      01-20-2024, 05:09 PM   #8
T3PO
Drives: X5
Based on the image above and how it looked when I had it on a lift, I do not believe it is an x pipe, looks to be straight through or maybe an H pipe.
RedATX1.50
      01-29-2024, 10:35 PM   #9
scottminor
scottminor's Avatar
Do you have an angle view of that resonator to see what it looks like in the middle?
      02-01-2024, 10:56 PM   #10
scottminor
scottminor's Avatar
Is that aftermarket? Mine looks like the one posted first
      02-02-2024, 06:36 AM   #11
SoFLo_X5
SoFLo_X5's Avatar
14
Drives: BMW X5 M50i
Originally Posted by Idemo View Post
M50i x pipe
Did you have this made or did you buy this somewhere? Have you installed it yet? If so, how does it sound?
2022 X5 M50i
      02-15-2024, 09:33 AM   #12
scottminor
scottminor's Avatar
In researching this X and H pipe option and looking at the factory resonator, it looks like there is a common air space shared inside the resonator. Has anyone done any dump testing for a before and after measurement for just adding an X or H pipe with the factory resonator in place?
