      07-31-2020, 11:15 AM   #1
bforbrian
bforbrian's Avatar
791
Drives: 2020 BMW X5 x40i
Clearing the 'Replace Battery' Message
Unfortunately, I've fallen prey to the 'Replace Battery' message after having PPF installed on my X5 (which took about 1 week). I'm sure the battery is functioning just fine and that this is just a software issue.
My question is, how do you clear the message in Diagnostic Mode? I've read that someone was able to do this, but the message just came back. I wanted to try and clear the message and see if it goes away for good for my vehicle.
Any help appreciated!
      08-02-2020, 02:24 AM   #2
James_G0540i
Australia
473
Drives: 2021 X5 G05 40i M Sport
There is an App called BimmerLink (related to BimmerCode), and this allows you to install a new battery and/or clear any battery errors.
      08-02-2020, 07:15 AM   #3
zhangyi17
zhangyi17's Avatar
292
Drives: BMW X5
Why installing PPF cause this battery error message? Do they need to disengage the battery?
I have an appointment to install PPF on mine in September. Hope my installer knows about this potential issue and how to fix it.....
      08-02-2020, 09:10 AM   #4
TurtleBoy
TurtleBoy's Avatar
17894
Drives: 2019 X5 40i,2021 M340i
Quite a few folks have gotten that message after tinting/ppf presumably due to the installers keeping the doors open for a long time/constantly opening them. Some folks have even taken it back to the dealer and gotten a new battery. I believe some said the message went away after awhile with the battery being back to fully charged.
      08-02-2020, 10:32 AM   #5
bforbrian
bforbrian's Avatar
791
Rather than leaving the doors open (I checked my app when they were installing it, and after a day's worth of work they always closed all doors, hood, and trunk), the issue may be that they leave the key inside and do not lock the car, leaving the system running. I would suggest to your installer that they close all doors, hood, and trunk, and take the key out of the vehicle and lock it. This may not be possible depending on what they were working on when closing the shop.
      08-02-2020, 11:00 AM   #6
bforbrian
bforbrian's Avatar
791
That 60+ page thread regarding Bimmercode is daunting.... do you know which adapter will allow me to clear this message, in addition to all the other common codes users use?
      08-02-2020, 11:03 AM   #7
TurtleBoy
TurtleBoy's Avatar
17894
Here is the list of supported adapters. I, and many others here, use the OBDLink MX+ Bluetooth and it works well for coding and I assume it will for clearing codes also.
https://www.bimmercode.app/adapters/
      08-04-2020, 05:26 PM   #8
bforbrian
bforbrian's Avatar
791
I didn't see a particular command on Bimmercode that says to clear codes (I'm using OBD), but I did change the auto start-stop code, and it cleared all codes after, then the replace battery message returned......
I'm trying hard not to bring it into the dealer if you haven't noticed!
      08-04-2020, 06:39 PM   #9
1coolF15D2017
Drives: 2020 X5 G05
Bimmerlink will clear the error. You just need to purchase the app, since you have already a working adapter with Bimmercode. No need for additional adapter.
      08-04-2020, 07:39 PM   #10
bforbrian
bforbrian's Avatar
791
Now I'm $62 in.... Bimmerlink better clear it!
      08-04-2020, 09:34 PM   #11
bforbrian
bforbrian's Avatar
791
Nope, could not figure out how to clear the code with either Bimmercocde or Bimmerlink. I'm convinced that there is no way to clear the 'Replace Battery' message unless the dealer physically changes the battery, even though the battery is fine...
      08-05-2020, 03:16 AM   #12
BigHunk
///M
BigHunk's Avatar
285
Drives: X5M , iX , S1000XR
You're in for a new battery, msg is coming back because something happened inside of battery, when drained low.
If your warranty is less than one year old, dealer should replace it at no charge.
not rich enough to buy cheap
      08-06-2020, 10:08 AM   #13
jimmy1533
Drives: bmw 530li
Re-register battery
ifr1212.50
      08-06-2020, 10:23 AM   #14
bforbrian
bforbrian's Avatar
791
Originally Posted by jimmy1533 View Post
Re-register battery
Tried that using Bimmerlink.....
      08-06-2020, 10:26 AM   #15
bforbrian
bforbrian's Avatar
791
My last resort is to fully charge the battery using a NOCO battery tender. I'm thinking that even with driving, the battery may not be 100% charged. If this tender can charge to 100%, perhaps it can clear the message. If not, off to the dealer I go because I have tried everything!
      08-11-2020, 04:36 AM   #16
babyghost
babyghost's Avatar
95
Drives: 2020 X5 M50i
I'm having the same problem after my car was wrapped. Please report back if charging the battery solves the issue.
      08-11-2020, 12:09 PM   #17
Alan l.
Alan l.'s Avatar
5944
Drives: 2020 F95 X5M Competition
Try picking up a ctek 5.0 battery tender to see if it can bring the battery up to spec. Several of us have this unit and works on the X5. It took mine almost 2 days to go into trickle charge mode.
      08-15-2020, 11:32 PM   #18
bforbrian
bforbrian's Avatar
791
Currently I have a NOCO Genius 5 hooked up to the battery at my parents' where I have access to a driveway and plug-in outlet. It will be charging for about 14-hours. When I left, 3 of 4 bars were lit up. I'll report back tomorrow to see if the juice indicator is full and whether the message went away!
      08-16-2020, 08:55 PM   #19
bforbrian
bforbrian's Avatar
791
Battery was fully charged per the NOCO Genius 5, and the message was STILL there. Off to the dealer I go....
      09-27-2020, 07:01 PM   #20
bforbrian
bforbrian's Avatar
791
Update: went to the dealer yesterday and they confirmed that the battery was defective. They replaced it and the message finally went away...
TurtleBoy17893.50
      05-10-2024, 11:05 AM   #21
Mesh
Drives: X6 2024
Hi.
I know this thread is old. But hey i got same your issue with ppf shop.
Since it’s your fault. Did they charge you for the new battery ?
My car is just new 2024 and not sure if the battery is defective so fast.
      05-10-2024, 11:20 AM   #22
bforbrian
bforbrian's Avatar
791
Originally Posted by Mesh View Post
Hi.
They never determined that it was my fault. I think they've seen other battery issues in the past, so the dealer covered it under warranty.
