09-13-2024, 07:43 AM | #23 | |
Rep 10
1/4 flexible but you can try even smaller. |
g05x5b584.00 |
09-23-2024, 08:45 AM | #24 | |
Rep 2
02-04-2025, 09:40 AM | #25 | |
Rep 426
So what I learned? The TCs are fundamentally unchanged since mid 2000s, EVEN with slight Magna Steir modifications! IT DOES NOT MATTER. It is as much an issue as Prop shafts were on the X series and NHTSA forced BMW to replace and offer a 10 year extensions. Arc- friend bought an XC90, 45,000 kms, asked me to check it, i immediately felt an oddity at the rear, Volvo diagnosed the Haldex TC failing, replaced. So the key issue there is too much power through the driveline, and esp, too much weight for the TC! the G05 is 5500 lbs, the TCs are nearly the same as the E53, when the cars were 4300 lbs (so 1200 lbs less) with way less powerful engines and a far slower TC management. What kills a TC? Driving, and esp fun driving. TC having to keep up with 300 400 500 Hp and high torque. Even the calm day smile grin driving. Launch controls. Sport + red light launches. POWER THROUGH TURNS. "the driver is actively applying acceleration while turning, maintaining speed and momentum through the corner instead of significantly slowing down, often requiring good handling and control to navigate the turn safely". Or in the case of the G05, just an average turn above recommended limit? Because these cars, esp any with Adaptive M, enable us to take turns 20-30, 40 km faster than a Honda or Toyota SUV, the TC is wearing at an accelerated rate. Some suspect G force actually press the differentials and wear it while it tries to keep front rear balance. The true solution, is, of course, less power, straight front wheels, pedal to metal so the TC retains its rear bias. but for all X drive systems, the TC works the most in turns, the sharper the corner, the more spirited, the more it burns itself. Oils does not matter. In some cases, the plastic actuator used to strip itself, causing slip. Anyhow. What else? Any doughnuts. Plowing through snow, sliding through snow. any Traction Control flash lights = TC is dying faster. Spotted my perfect g05. tanzanite Blue, dark tartufo leather, owner PPFed the car and added 20 " to his M Performance (my preference). 50,000 kms, 2021. Within minutes, on eco (where I test the TC behavior in any turn, I felt the judder. On most partially snowed roads you would assume it ice or road imperfections but I chose a clean flat portion. Judder. I knew it. Notified the dealership, as they got warranty until july 2025, I had to let it go even if the promised to look or replace it. So, the true problem is BMW not solving it, and duping clients to assume oils or a new car makes it easier. Perhaps, redesigning the TC makes no geometric/driveline sense, there is no room. Make it of the hardest Alloys possible maybe be a high production cost for Magna Steir/BMW. If it costs them 3000$ to redesign it to work 15 years, they do not want that. They pay 500 $ to the factory and now bill 7000 $ CAD new installed. Those lucky enough to drive gently, perhaps, the non M optioned cars, may be luckier. But, when we hear statistics of 10 20 30 40,000 miles TC failures, the garage reality I was told, is that is a high recurrence but some people do not even bother fixing it, accepting the judders. Ballpark, TC failure rates, esp on M perf variants, must go over 50% above 70-80,000 kms ,a nd likely 90% or more at 100,000 miles IF driven as the car was designed. So there is no modus operandi to safeguard your TC- just blind hope luck and prayer for a beautiful 5500 lbs G05, more with family, to not fry its TC. it is as predictable as air suspension issues. The true solution, seems to be a class action, to scare BMW similarly to the N63 or prop shaft issue. Unfortunately, it may be of limited NHTSA- as it is not an accident risk. But definitely a US Consumer Goods complaint. For that one, you can file. The owner's mitigation is simple- avoid tight spirited turns (inside lane in intersections), let that Civic beat you, avoid pedal to metal events, and change the oil. Send the oil for analysis and that should be very very informative. And it is relative. Perhaps an average sedan speed turn in the G05 may be too much. Note that Porsche also admitted to this issue, and its cars are 2000 lbs lighter? 3000 in some cases? |
02-04-2025, 05:39 PM | #26 | |
![]() 1230
Rep 1,023
What comparable vehicles are this much lighter?
Two is One and One is None
03-21-2025, 06:52 PM | #27 |
![]() ![]() ![]() 497
Rep 510
Drives: 11 128i | 21 X5 40i
I changed the transfer case fluid in my X5 last weekend, got 550mL out and put that back in. This was my first time using ISTA and while I did watch some videos beforehand, I don't think I did the process exactly as intended.
My question for those who have used ISTA, when you get to the step after it turns the engine on and shuts it off, then says to perform the service, did you leave the laptop/ISTA connected and change the fluid with the dash switched on? Or did you disconnect ISTA, turn off the dash, then perform the service and then reconnect everything? I didn't have my battery charger hooked up so I didn't want to leave ISTA connected and the dash on. But I'm thinking that when I shut down ISTA it closed the chamber on the transfer case instead of leaving it open for the service.
11 128i slicktop
19 Alltrack S 21 X5 40iX Msport |
