06-13-2024, 03:10 PM | #1 |
Rep 1
Drives: 2022 840i XDrive Gran Coupe
Windshield rain coatings??
I searched around but didn't find what I'm looking for....
What products are you guys using on your front windshields for better water repellency in the rain. Like Rain X but for adults. ![]() Ceramic coating? PPF on the windshield? Just very clean windows? Others? Thanks |
06-13-2024, 04:18 PM | #2 |
YNWA
![]() 1218
Rep 926
I take my coating applicator and "wipe off" towel and use them to wipe the glass at the end of coating the whole car. Then, later, "recharge" type sio2 products are used throughout the year to maintain protection/water behavior. As waterless/rinseless or drying aid type of applications.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54 |
Chemnav45.50 |
06-13-2024, 05:46 PM | #3 |
![]() ![]() ![]() ![]() ![]() 1192
Rep 720
Never again. I applied Rain X once. It caused any humidity to stick to the windshield along with anything else in the air. It was awful. Nothing would remove it, either. It was so bad that I had the windshield replaced.
06-13-2024, 07:25 PM | #4 |
![]() 4275
Rep 4,460
Rain-X sucks. Difficult to apply and doesn't last. I use Glaco Ultra by Soft99. It was originally designed for aircraft windshields. Very easy to apply and lasts very long.
Westside Guy7566.50 |
06-13-2024, 07:33 PM | #5 |
![]() ![]() ![]() 11553
Rep 7,192
Drives: 2018 M2 AW DCT
One word. Don’t. It messes up the intermittent wipers.
BMWCCA member Puget Sound Chapter
06-13-2024, 07:51 PM | #7 |
![]() 1228
Rep 2,449
I've used RainX for 40+ years without issues - the "real" stuff, not the windshield/glass cleaner, following the instructions. Tried AquaPel once with poor results. Got some free samples of Griot's ceramic glass cleaner - doesn't work as well as RainX. Adam's H2O Guard & Gloss works well on paint, glass & trim - not as good as RainX.
https://www.youtube.com/watch?v=Y9iR...el=ProjectFarm
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
06-13-2024, 09:49 PM | #8 |
![]() 2329
Rep 1,921
I ceramic coated my windshield and I top it off with Gtechniq C2V3 a few times a year. On a previous vehicle I used Wolf's Ceramic Glass Sealant. It works incredibly well and I highly recommend it.
06-13-2024, 10:59 PM | #9 |
Loves me some MHD!
![]() 1922
Rep 1,760
Same here. Apply correctly and it works great.
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla . . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg |
06-14-2024, 02:25 AM | #10 |
![]() ![]() ![]() ![]() ![]() 810
Rep 821
There is some coating on my windshield. Water either beads off or clumps around drivers vision line and wipers seem to float above it. Thinking about some kind of cutting compound to deal to it. Never had an issue with cars before with just simple glass cleaner.
06-14-2024, 06:51 AM | #12 |
Primo Generalissimo
![]() 5087
Rep 4,223
Drives: All of them
Garage List 2024 Ford Bronco Ra ... [10.00]
2018 Porsche 911 GTS [10.00] 2023 BMW M2 [9.25] 2022 Ford F-250 Tremor [8.50] |
Glaco is what everyone is raving about now. I will be ordering some to check it out myself.
06-14-2024, 06:52 AM | #13 | |
![]() 99
Rep 115
Application process is easy: (1) clean and dry windows using any method (paper towels, newspaper, Mr. Clean Magic Eraser), (2) apply RainX with a clean, dry paper towel; I usually apply it twice to make sure I didn't miss any areas, (3) get a couple paper towels wet and wipe the entire window with them, and (4) dry the window with more paper towels. I used to avoid the very top-center of the windshield where the rain sensor is, but all the newer sensors do a better job so I just apply RainX directly over them now. Definitely avoid the RainX product you add to the windshield wiper fluid - I've heard nothing good about that stuff. |
John in VA1228.00 |
06-14-2024, 07:49 AM | #14 |
15681
Rep 3,974
As soon as this video starts you're going to want to hit mute, then skip to the end where he gives the stats. This guy is beyond annoying, like Doug Demuro but in a different way because it's rapid-fire-until-you-choke info, but he does good tests.
06-14-2024, 07:50 AM | #15 |
![]() 68
Rep 132
Adams glass sealant has worked great for me. I've tested different ceramic coatings on windshields and they work well- but tend to bead water on the windshield and don't "release" them off the windshield as quickly as a dedicated glass sealant- so there is a difference. With Adams glass sealant the beads fly off the windshield at ~45mph keeping the windshield free
06-14-2024, 09:01 PM | #16 |
![]() ![]() 35
Rep 50
I'm the same as you other old timers, probably about 40 years usage or so. I will disagree with the comment about the RainX concentrate you add into the fluid container. I found that product probably 10 years ago, and have used it in the wife's car and mine. It's lasted so long since it's concentrated that I just had to search around to find my second bottle. I find that it is works like a "topper" and just boosts the performance of the wipe on product. At highway speeds there is no need to use the wipers because the water just rolls off the top of the windshield. On the one car with rain sensing wipers, it doesn't affect their operation at all.
06-14-2024, 09:34 PM | #17 |
Thaumaturge
187
Rep 220
I use Aquapel. But I have found that if I buy it from Amazon or eBay it's counterfeit so I buy it direct from PGW in Pittsburg. It lasts way longer than RainX and works great if you apply it to a clean windshield.
///Rich |
06-14-2024, 09:54 PM | #18 |
![]() ![]() 1595
Rep 2,218
Same here, no issues with Rain X for many years.
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (show car) |
06-15-2024, 01:39 AM | #19 |
![]() 167
Rep 181
CarPro Ceriglass with a CarPro 5 inch rayon pad followed by FlyBy30.
Its cheap at $22.00 for 50ml and works the way I want it to. I usually do a once a year treatment and it holds up, It does not like Elixir on top of it. Anything funky I use as a topper that hits the glass is easily removed with Eraser |
06-15-2024, 08:46 AM | #20 |
![]() 99
Rep 115
Great review - thanks for sharing! I've never seen such a thorough testing of the products. Good to know that there are options, but I'm going to stick with RainX because it's cheap, easy, and fairly effective. This is what he said about RainX in the conclusions: "If you are trying to make every dollar count and it's about performance and price, the RainX is a clear winner. At a price of $10 for 7 ounces, which is less than half the price of the top three brands, it still performed extremely well." I'll just have to remember to reapply it a little more often than any of the pricier three leaders (Gtechniq, Aquapel, and Gyeon, in that order).
Here are the final scores: |
jkoral1152.50 |
06-15-2024, 02:07 PM | #21 |
![]() 1269
Rep 1,610
I've been curious about it as well. Please share your thoughts when able.
- Jeff
bosstones' flickr |
06-15-2024, 02:18 PM | #22 |
![]() ![]() ![]() 359
Rep 391
Carpro Clarify PH₂OBIC. So far it’s been great and I’ve been using with no sealant as I ran out of Wolf’s. Easy on off application and smells good. Lol
2013 E92 M3 |Space Grey | Fox Red | Manual
1999 E36 M3 |Hellrot Red | Black | Manual IG: @moya_M3 |
