      11-08-2024, 10:12 AM   #23
bosstones
1269
Drives: o_0
Originally Posted by Yuille36 View Post
As these wheels with there honey-comb style design are a real pain to clean.
Yeah, those don't look any fun w/ all those short faces. One of Hyundai's Genesis SUVs has a similar but more unfortunate/complicated wheel design. Someone had it at work and my only thought was of what a PITA it would be to keep them clean.
If I don't have the time or patience for a contact cleaning, I've been using Sonax Beast and then just spraying the wheels down afterwards. It does a great job. I'm going to try foaming applications to see how that does and if it helps save product.
Pix are before, after water rinse (hose, not PW), Beast application, then after rinsing off the cleaner. It rained a little earlier in the week so they aren't as bad as usual but there is a little streaking from the rain runoff. By the time I'm done spraying down the 4th wheel, it's time to rinse the 1st. Not perfect, as you can see a spot where product didn't stick/clean (which was easily resolved during towel drying) but I'm very happy w0 the result for the effort. Might try Griots' heavy wheel cleaner as it is a little more economical.
      11-08-2024, 11:51 AM   #24
TboneS54
YNWA
TboneS54's Avatar
Drives: '04 M3 6MT, '11 M3 DCT, '22 X7
Griot's HD wheel cleaner is fantastic. Meg's ultimate, sonax also great. Haven't tried ethos or adam's. Would assume they're pretty similar with that iron removing chemistry.
That said, some areas may require light agitation. With no agitation or sponge or anything, there still is the faintest film of brake dust left behind. The wheel looks perfectly clean from 2 feet away, but I can get it perfectly clean by wiping the wheel with a mf applicator (auto-fiber).
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54
chris7197619.00
      11-09-2024, 07:41 AM   #25
Yuille36
Yuille36's Avatar
Drives: X5M, M3 ZCP 6MT, MB E63 AMG
2015 BMW X5M  [9.87]
2017 BMW/M3  [9.92]
If you can eliminate most of the brake dust, then you're in a great spot to begin with. And wheel cleaning isn't such as chore. And that is why I use carbon ceramic brake pads. Very light minimal brake dust.
For comparison, a couple weeks for me, is equivalent to two days for you. And if you wiped your finger on your wheels, it is black in comparison to mine, which is dusty.
I typically use Black Magic Bleche-Wite Tire Cleaner Spray or Sonax Wheel Cleaner on my wheels. I don't want something that is too aggressive, since my wheels are coated.
It is never taken for granted that a commitment to speed and acceleration must be matched with an equivalent ambition when it comes time to stop!
      11-09-2024, 09:25 AM   #26
rmedina
Drives: 2023 M340i
Originally Posted by dogocity View Post
I get a bottle of dawn powerwash, and remove 3/4 of the bottle.
I then fill the bottle with Adam's Polishes Iron Remover. Cleans great.
The iron remover is safe on paint.
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
It comes out as a foam?
      11-09-2024, 09:43 AM   #27
dogocity
dogocity's Avatar
Drives: M8, G.C. Comp
Yes. Not like using a foam gun, but it is foamy.
      11-11-2024, 10:01 PM   #28
stbm5
Drives: 2018 M5 DG
the ultimate solution: get matte black wheels!
      12-25-2024, 03:58 PM   #29
Randy Johnson
M340i
Randy Johnson's Avatar
Drives: BMW M340i
2021 BMW M340i  [9.90]
Originally Posted by USMC G2 View Post
Greetings,
First - get some brushes or make your own. The more you clean your wheels, the better you will get. I use Griot's Wheel Cleaner with a variety of brushes and hand micro fiber mits. Second, after (what I think) is a thorough cleaning...the next day, I use a ceramic rinseless wash to clean them again. This pretty much returns the wheels to original condition. And finally, yesterday I applied 303 Graphene Nano spray to my wheels for lasting protection - it was easy on and easy off, and leaves a helluva shine.
You'll get better the more you do it...(like everything else in life).
Semper Fi
Great tips.
Ps: you obviously don’t drive this garage queen. It’s way too clean. Just kidding man.
      12-26-2024, 07:08 AM   #30
jwmFcreek
96
Drives: Xm
Many great ideas sure better then mine .
1. I use Jimbo’s pure magic on the rims and barrels let soak
2. Good brush on the tires
3 . Jimbo’s formal dressing for the tires I like the black finish
4. Jimbos hard as shell ceramic spray because my BMW makes some dust
And easily wash with a hose after
      12-29-2024, 09:18 PM   #31
ScottyRyan2019
Licensed Professional Slacker
ScottyRyan2019's Avatar
Drives: 2024 M2 and 2025 i4 M50
  [9.25]
  [9.25]
2024 BMW M2  [9.50]
Changed pads to ISWEEP 1500, ceramic coated the wheels, and clean with a Armour wheel cleaner which is PH neutral. Piece-o-cake 👍
2024 M2 and 2023 Mazda CX-30
Vmaxx876.00
