      03-30-2009, 03:47 PM   #23
TwinTurboXI
160
Drives: 2011 135i
Bod Pod is basically the best.
      03-30-2009, 04:02 PM   #24
DougLikesBMW
Fapmin
DougLikesBMW's Avatar
402
Drives: '03 E46 330Ci
Originally Posted by omgitselainee View Post
I concur. I'm usually in the low to mid teen's no muscles here obviosuly
oh hai
      03-30-2009, 04:23 PM   #25
jaiman
Drives: very fast
Originally Posted by blue-coupe View Post
Well, since it seems that BMI is bunk, what is a good measure?
BTW, when my trainer took mine, he used some gizmo that ran an electrical current through me, measuring resistance. I would assume that this device can account for muscle mass vs fatty mass.
That device should measure body fat percentage which is a much better indicator of fitness than BMI. There no reason to run an electical current through you to measure BMI. You get that with a scale, tape measure and calculator.
      03-30-2009, 07:01 PM   #26
Year's_End
Year's_End's Avatar
Drives: 2020 Shelby GT350
BMI is pointless without getting a body fat percentage to go along with it.
Go to a gym and get a reading.
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT
Current: '20 Shelby GT350|6MT
      03-30-2009, 09:36 PM   #27
kabalm18
My car drones and I LOVE IT!!!
kabalm18's Avatar
Drives: 1M & F10 535xi
Who gives a shit...go look in a mirror!
      03-31-2009, 10:45 AM   #28
MrHarris
yodog
MrHarris's Avatar
Drives: '86 Corolla
2009 BMW  [10.00]
70
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle
Special Thanks: Gintani | OETuning | eAs
      03-31-2009, 11:14 AM   #29
blue-coupe
Drives: 1999 Z3 Coupe
I would usually agree with you, but I've been working out for a while, and it helps to change things up every once-in-a-while. I figured a BMI reduction goal would be a good change of pace.
      01-06-2010, 12:45 AM   #30
Stanky19
Friends don't let friends early apex!
Stanky19's Avatar
Drives: "The Turbo Schnitzel"
2007 E92 335I  [0.00]
Originally Posted by yomama69 View Post
~24 consistently. BMI is misleading though because it can calculate you as being overweight if you're muscular.
word. i can't float when in a pool yet my bmi says i'm 24.17............
07 Space Gray E92 335i "Turbo Schnitzel"
Wavetrack LSD, KW V3, M3 Aluminum Arms, E93 M3 Front Sway Bar, Dinan Toe Link, Catless DP's, AE Quad Exhaust, DCI, Vishnu PWM Meth, Vishnu V2.5 440whp/460wtq (stock cats)
      01-06-2010, 12:52 AM   #31
osteome
osteome's Avatar
Drives: 2020 X5
Originally Posted by Eazy-e View Post
Some people have heavier bones
My wife says I have a heavy bone.....
2022 M4 Competition ConvertibleDravit / Tartufo Full / Carbon Fiber Exterior...loaded
2020 X5:MW/Coffee Extended Merino, M Sport, B&W....loaded
2007 X3: Sapphire Black / Black loaded 6 speed
Gone: M3 E93 Silverstone II over Bamboo
      01-06-2010, 01:31 PM   #32
Spec 1
Faster in the Corners
Spec 1's Avatar
Drives: '91 E30, '05 ZX6-R, '06 300C
Originally Posted by earlyapex View Post
I think we found the scrawny/nerdy guy. BMI couldn't be more idiotic. I'm in good shape, run/bike/lift 4 to 5 times a week and have consistently measured at 10% body fat via various methods.
Several years ago, I worked out for 3 hours a day for six months and ran a half marathon in an hour and a half. I had like 3% or 4% bodyfat and weighed 182lbs.
I weigh 195lbs and am 5'11". According to the midpoint of the BMI (22), I should be 157lbs.
Perhaps you should re-read my post. I said it works fine for "the majority of people". That in no way applies to everyone. As well, BMI should be taken as another factor of your health, not the end result. I'm relatively lean, but I'm not a "scrawny/nerdy guy". Thanks for the vote of conifdence
I'm 6'0" (ok, 5'11.5") at 172 lbs and my BMI reads 23.32 currently. "Healthy" is between 20.7-27.8, so 24.4 is more a median than 22, fwiw.
If you're ripped or have a muscular build, then BMI won't be as accurate. It is however fine for, again, the majority of folk. Keep rocking those workouts
'91 M42 E30 - All sorts of goodies.
      01-06-2010, 02:21 PM   #33
SUB-ZERO
SUB-ZERO's Avatar
294
Drives: 2018 M2 + Spur, DB11, F12, X5
People are right about BMI not being totally accurate. Some people have heavier bones or a lot of muscle.(muscle weighs more then fat)
It all depends how you calculate it. If you use the tradional tape measure method, it will most likely be off.
A more accurate method is using calipers. Also, you can measure BMI electronically to be more accurate.
-SZ
      01-07-2010, 08:25 AM   #34
bolinp78
G35 convertee
bolinp78's Avatar
69
Drives: 2008 335i (AW)
      01-07-2010, 11:28 AM   #35
Stanky19
Stanky19's Avatar
i think the 22 bmi number comes from wii fit users.......
(now see if they own up)
