09-21-2020, 09:59 AM | #310 |
Rep 419
For driving assistance, not via coding, you can disable features that you want via "Configure Individual" and use the Intelligent Safety button to use your individual settings, turn everything on, or disable everything completely. I like this better so can switch back and forth with a press of a button.
2019 X5 40i M-Sport
07/2020.54 -> 11/2020.50 -> 03/2021.50 -> 07/2021.85 [All OTAs] |
09-23-2020, 02:57 AM | #311 |
Rep 66
Is it possible to add emergency stop on flank to 2019 G05 i-step 07/2020?
I saw it in 2020 F85 i-step 03/2020. And can we add the RED (M version) colour scheme to the head unit? |
09-23-2020, 01:21 PM | #312 | |
265
Rep 345
Drives: 2019 X5 40i M
https://g05.bimmerpost.com/forums/sh....php?t=1758184 Please note the hardware for flank breaking was not included until the 2020 MY. Accordingly, the 2019s cannot code that feature, they can only code for reverse.
2019 X5 X40iM
09-23-2020, 02:49 PM | #314 | |
265
Rep 345
Do you have some closer information about that hardware? Can the existing hardware be easy upgraded? And what about coding M colour scheme to hu_mgu?[/QUOTE] No idea on hardware. Not sure what you are referring to for red color but the M Dash layout and Alpina layouts are on my sheet.
2019 X5 X40iM
09-24-2020, 01:06 AM | #315 | ||
Rep 66
Not sure what you are referring to for red color but the M Dash layout and Alpina layouts are on my sheet.[/QUOTE] You can probably see on pictures higher that all selections in menus and checkboxes are marked red instead of orange (as on all standard versions of G05). I made this pictures on 2020 X5M F95. When coding M-dash it would be great to have the same colour scheme on the head unit as well. |
11-22-2020, 03:53 PM | #316 | |
2019 X5 40i
115
Rep 226
Confirming the below codes work as expected
2019 X5 40i (Mar-2019 Build)
iDrive ver -- 03/2022.30 |
12-22-2020, 06:58 PM | #317 | |
2019 X5 40i
115
Rep 226
After I updated the software to 07/2020.80 version today I noted that the default values for below was already set to aktiv in latest software
ACSM5 -- [1B2D] a_pdc: aktiv [01] a_pdc_fp: aktiv [01] I only have to update this one HU_MGU -- [3E52] ACTIVE_PDC: aktiv [01] -- Default : nicht aktiv [00] Note : This time I did not get any error messages for Parking Assistant malfunction Quote:
12-22-2020, 07:05 PM | #318 |
2019 X5 40i
115
Rep 226
Does anyone know what improvement will we expect to see on eTJA+ with this coding ?
Improve eTJA+ --> SAS3 -- 42C1 -- C_HOO_Vorhanden
12-22-2020, 10:21 PM | #319 | ||
135
Rep 372
12-23-2020, 08:55 AM | #320 | |
1197
Rep 1,587
I seem to recall he said that the prompt to use Assisted Drive Plus appeared earlier than previously. |
anuj452115.00 |
12-23-2020, 08:56 AM | #321 | |
1197
Rep 1,587
12-23-2020, 04:17 PM | #322 |
2019 X5 40i
115
Rep 226
Thanks ifr
I did have to do most of my coding again, however I did see few codes did not change and this was one of them. As you mentioned, it is quite possible that OTA update may not have programmed ACSM module
02-05-2021, 06:28 AM | #323 | |
Rep 451
Drives: 2017 X5 & 2020 X5
VEHICLE_COLOUR You can also change the trim settings ie M Sport X Line in the drop down list in TRIM_LINE
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive |
02-15-2021, 01:22 PM | #324 | |
Rep 2,609
02-15-2021, 03:37 PM | #325 |
///M SubDriver
1835
Rep 2,783
Drives: 2017 M3, 2020 X7 40i
Excellent summary for any coding software platform! I was recently reading the other post on this topic using BimmerCode. Now, if only there were a way, via coding, to change the menu in iDrive to match your new custom colors. Great job !
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
02-17-2021, 02:20 PM | #326 | ||
Rep 243
03-14-2021, 12:51 PM | #327 |
Self-Deprecating Narcissist
7266
Rep 6,561
I cannot find the answer by searching but perhaps someone on here may assist... If equipped with laser light are you able to disable the amber corner lights?
03-14-2021, 07:01 PM | #328 |
Rep 8,364
03-15-2021, 08:02 AM | #329 |
7266
Rep 6,561
Yes. I was finally able to get it done but lost the sliding RPM gauge by speedo when coding ///M cluster.
For anyone interested amber delete coding is: Set both FLM's: LMM1_Data: Wert_12
03-15-2021, 09:07 AM | #330 |
Rep 4,668
Thanks for all the effort. I'm going to try the cheat codes this time around. I just received the 11/2020 update. The ambient lighting coding has been a lot of fun.
