11-15-2019, 10:35 AM | #1 |
Rep 810
Bimmercode Expert mode cheat sheet?
Does anyone know where I can get an Advanced mode cheat sheet for Bimmercode?
For example, I was able to turn on Advanced Drive Assist in the Instrument cluster using the following: SICHT_ABSICHT_ENABLE aktiv CB_FZG_UMGEBUNG_FAS aktiv CB_PRESELECT_NAVI_ANSICHT_FZG_UMGEBUNG aktiv I've enabled the Alpina instrument cluster using standard mode in Bimmercode; under Instrument Cluster, but I want to turn off the permanent "Alpina" text in the Instrument cluster just below the driver monitor camera. I've seen others code the ///M symbol, so I'm sure there's a way to disable the Alpina text. Is it worthwhile e-mailing bimmercode support? |
11-15-2019, 03:58 PM | #2 |
Rep 5,448
It is simple, you go to expert mode in the ECU you want to code, in this case above the Kombi and then just search each of the items as their is a search at the top of bimmercode and set the item to aktiv, once you change all them, then just back out one screen and hit code. All the other items are in the G05 cheat sheet for esys.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
11-15-2019, 04:07 PM | #3 |
Rep 5,448
To be a little more specific, when you go to expert mode, go to section 3000 and then search and you will find the 3 assisted driving items you need to change.
For the Alpina text to not display, it is also in section 3000 change this LOGO_SCHRIFTZUG to kein_logo and that will be no logo Change LOGO_SCHRIFTZUG to m_logo and you will have the M logo There are about 20 choices for that setting in the list you will see, you can play around with whatever logo's you want. Also, if you want the startup logo when you get in the car to not be Alpina you can change this also in group 3000 STARTUP_EMBLEM to bmw_m Most things are in here, bimmercode cannot do expert mode for a lot of the modules, but all the Kombi stuff you can do, just find the stuff under the DKOMBI4 section and then the group ID is the section number in expert mode you will find the item under and then you can search or just find it in the list and change it to the indicate setting. https://github.com/packetpilot/bmw-f...s/jokinawa.xml
James_G0540i446.00 beermato101.50 |
11-16-2019, 08:00 AM | #4 | |
Rep 810
01-28-2020, 11:21 PM | #5 | |
Rep 202
Drives: 2023 BMW 760xi, 2024 BMW 530i
01-29-2020, 08:05 AM | #6 | ||
135
Rep 372
01-29-2020, 09:47 AM | #7 |
Rep 202
Gotcha. Thank you for that info
01-29-2020, 03:11 PM | #8 |
Rep 810
01-29-2020, 08:09 PM | #9 |
Rep 430
I am planning to take my car for a software update soon. I don't want the dealer to see the changes I have done through BimmerCode App. Is there a way I can reset everything that BimmerCode did to default values?
I did do the Drive Assist View change in the Expert mode to it and now need to reset it to default (and of course bring it back on after the software update if Bimmercode allows me to do it). |
01-29-2020, 08:23 PM | #10 | |
Rep 2,609
01-29-2020, 08:27 PM | #11 | |
Rep 430
What do you think, restoring each one at a time would work? I just don't want to Brick the car. LOL. |
01-29-2020, 08:33 PM | #12 | ||
Rep 2,609
01-29-2020, 08:39 PM | #13 | |
Rep 430
Here is the scenario... I did number of "A" changes using the iPhone and the Store App version. It did make a backup at that time in the iPhone. Then I did number of "B" changes using an iPAD and the TestFlight version. It did make a back up at that time in the iPAD. "A" changes were made before "B" changes. So, now if I connect my iPhone, will it recognize and allow me to restore the A changes back to default? Or should I do things in a particular order? I do have the backups but the problem is Store version and TestFlight version usage and two different devices being used. Thanks again. |
01-29-2020, 08:45 PM | #14 | |||
1053
Rep 1,952
01-29-2020, 08:51 PM | #15 | ||||
Rep 2,609
01-29-2020, 08:53 PM | #16 | ||
Rep 2,609
01-29-2020, 08:55 PM | #17 | |
Rep 430
I guess I am in trouble now.....Better take my car as is to the dealer but I think at least I want to remove two items back to default from it; 1. Alpina Dash (Lol a 40i and Alpina; sounds weird right) 2. Driving Assist View Thanks in advance guys for your help. |
01-29-2020, 08:59 PM | #18 | ||
1053
Rep 1,952
01-29-2020, 09:02 PM | #19 | |
Rep 430
I feel like I should give it a trial. BTW, I have 07/2019.50 version on it. I heard that I can get it updated to up to 11/2019.40. Do you think it worth trying it now or wait? If there is any changes to Drive Assist features like Lane Centering and proper stopping when in the Adaptive cruise in the city, I really want to give it an update. It just scares me to hell when it Beeps for help when it can't stop and cries for help when a car in front of it stops (normally). |
01-29-2020, 09:08 PM | #20 | ||
Rep 2,609
For the "worth upgrading to 11/2019.xx" discussion, maybe take that to the 11/2019.40 thread.
01-29-2020, 09:13 PM | #21 | |
Rep 430
I probably will have to UN-Program that area only in that case using the TestFlight version because its the one that I used to enable it. |
01-29-2020, 09:16 PM | #22 | |
Rep 430
Yep. That is correct. |
