      11-18-2020, 10:10 PM   #1
dtronics
dtronics's Avatar
381
Drives: G80 /// M50i /// 964 C2
Style 808M on M50i
Does anyone know if the 21” 808M wheels will fit on the M50i? I currently have 22’s and I’d like to run a 21” winter setup instead of 20’s. Thanks!
      11-19-2020, 11:28 AM   #2
scotchy
210
Drives: 2020 X5 M50i
Originally Posted by dtronics View Post
Does anyone know if the 21" 808M wheels will fit on the M50i? I currently have 22's and I'd like to run a 21" winter setup instead of 20's. Thanks!
Will they fit, yes, but much more aggressive fit. They'll stick out considerably more than stock which will look great but may not be desirable for winter if slinging rocks/debris up on your paint. You can punch in the numbers on the link to see how they'll sit.
https://www.1010tires.com/Tools/Whee...et-Calculator#
Edited to add correct 22" specs.
I think you end up pushing the front out 19mm more than the stock 22", and the rear if you go square setup or staggered 12mm more.
This will fit but the rear will look more tucked than the front.
      11-20-2020, 10:24 AM   #3
dtronics
dtronics's Avatar
381
scotchy thanks for taking the time not only to respond but also posting the diagrams, much appreciated! I would probably go with the square setup 10.5Jx21 ET31 which would extend 12mm's as you pointed out. I'm thinking that if the rear is tucked too much, I can add a small spacer.
Curious to see if anyone has pictured of F95 wheels on a G05? Ideally the 808M's. I'm kind of a stickler for fitment so any visuals would be very helpful!
scotchy210.00
