11-19-2020, 11:55 AM | #1 |
Rep 158
Code PDC Emergency Braking?
Is it possible to code emergency braking during parking in a 2019 G05? I have two options in the PDC menu on my 2021 G07 for emergency braking when risk of collision is detected in the rear or on the sides during parking. I don't have these options in my G05, although both vehicles are running 07/2020.54 software.
Would prefer to use BimmerCode Expert Mode to code this if possible. |
11-19-2020, 12:37 PM | #2 |
1197
Rep 1,587
We never got final confirmation but I posted some coding in the G05 cheat codes thread:
https://g05.bimmerpost.com/forums/sh...&postcount=261 These seemed to be the key codes, although I never saw confirmation from anuj452: https://g05.bimmerpost.com/forums/sh...&postcount=268 |
11-19-2020, 07:48 PM | #3 | |
Rep 158
11-20-2020, 07:51 AM | #4 |
Rep 5,447
It works fine and has been confirmed by a number of people, it is only 3 things to change, look up aPCD in this sheet https://docs.google.com/spreadsheets...gid=1785860634
Not sure if bimmercode can code it, gave up long ago and switched to esysx just so I could code this, but maybe it can now - it was the acsm module they didn't allow expert mode in and didn't have the option without expert mode. I have had it on for about 4-5 months, works pretty well, it is a bit abrupt, feels like you hit something but just slams on the brakes hard. It maybe 2 times has refused to pass through my 10 foot wide garage door for some reason and you have to turn off with the button to get it to continue even though it isn't near anything. Active PDC with Brake Intervention ACSM 1B2D a_pdc Aktiv ACSM 1B2D a_pdc_fp Aktiv HU_MGU 3E52 ACTIVE_PDC Aktiv
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
mrichione96.00 |
11-22-2020, 03:52 PM | #5 | |
2019 X5 40i
115
Rep 226
@ifr I can confirm the codes worked
2019 X5 40i (Mar-2019 Build)
iDrive ver -- 03/2022.30 |
ifr1196.50 |
