11-22-2020, 10:46 AM | #1 |
Rep 637
Rattle in front doors X5MC
Hi,
I have this issue on rough street and sometimes when I startup and exhaust make some vibrations. Some, probably small cable, rattles in both front doors, right one are slightly bit worse/noisier. If I turn on radio I barely hear it but If if drive without it and its longer distance/or with cold harder tires, it bothers me. It really depends on surface I drive on. I am planning probably to solve it with bmw, its expensive car. Btw my 5er had it also but only left door - I didnt solve it because I have been worried that service make it worse by demounting things on and in doors, crakcs something etc.. Do you have experience with it also? Regards |
05-02-2022, 07:02 PM | #2 | |
Rep 4
Any updates? I took delivery on an X5 45e April 18th,2022. Here I DFW Texas.. Doors were tight, to the point where you have to close it hard enough to stay closed or latch. 😁👍 It would constantly be left open\ajar and I would have to stop and close the doors, etc.. However, after a week or so, only 400miles so far, I came across a rough surface that causes minor vibration. It's a mixmaster and is meant to be smooth, but the vibration developed due to harmonics with the road surface. Since then I can confirm both front doors have a kazoo type noise, like rattling rice paper in the wind, when I come across higher speeds and or rough surface. I tested this also upon closing the front doors, to hear if I can reproduce this paper rattle sound. It is repeatable. Wonder if this is something I have to live with or is there a fix. I have owned e39 540's, e70 diesels, n55s, e93 n54, etc. My very 1st brand new g05 45e, and this is what I come across. Kinda shocking and not knowing how to approach this. Thanks. Anyone? 😁🙏 |
05-02-2022, 07:22 PM | #3 | |
Rep 1,250
Easy fix I found here, get some 1" PPF tape and go over the top of the door jambs. |
