11-22-2020, 07:16 PM | #1 |
Rep 422
Winter setup question
Does anyone know if the 467M wheel from the F15 X5 with 255/5019 snow tires will fit the G05 X5 with the M caliper brakes?
The G05 X5 will be fitted with 22" wheels from the factory. Thank you in advance. |
11-22-2020, 07:27 PM | #2 |
Rep 2,609
No. There has been a bolt pattern change from Fxx to Gxx transition. No other parameter matters to figure out when that's the case.
11-22-2020, 08:02 PM | #3 | |
Rep 422
Looks like I'm looking for a new set of winter wheels. Is 19" the minimum to clear the M calipers or 20" wheels? |
11-22-2020, 09:27 PM | #4 | ||
Rep 2,609
12-16-2020, 09:40 AM | #5 |
Rep 422
The search for winter wheels continue
764M Front Wheels: 9Jx20 ET28 Rear Wheels: 10Jx20 ET39 Would this work if I get 4 of the rear wheels with 275/4520 tires? Any issue with the offset? Last edited by lknbimmers; 12-16-2020 at 09:55 AM.. |
12-16-2020, 12:57 PM | #6 | |
Rep 2,609
This site is helpful, although if you're exploring your own rims, you should learn to do calculations and measurement manually yourself. https://www.wheel-size.com/calc/
