03-11-2019, 04:48 PM | #23 | ||
Rep 411
The dealer's technician drove the car just now and agrees that is where the rattle is coming from. The suspect the spring of the cargo cover push button is loose. They will replace that entire unit on right side. They've ordered from factory in SC and will let me know when it's here. |
03-11-2019, 04:53 PM | #24 | |
Rep 5,295
03-11-2019, 05:43 PM | #25 | |||
Rep 6,121
03-11-2019, 05:44 PM | #26 | ||
Rep 6,121
03-11-2019, 06:29 PM | #27 |
Rep 5,295
03-11-2019, 06:40 PM | #28 |
Rep 6,121
I throw my Yeti in there usually, and yes they're sufficiently large which is awesome!
03-11-2019, 10:21 PM | #29 | |
Rep 6,121
also see pic of where I put the felt tape
03-12-2019, 06:55 AM | #30 |
Big Beaver Smile
2101
Rep 3,790
I'm extremely detail oriented with my cars, but even I draw the line on accessorizing them with water bottles
11-13-2019, 10:03 AM | #31 |
Rep 2,247
2019 G05 X5 with a rattle/rumble/knock from the right rear at low speed/over uneven road.
Looked around whole entire truck and couldn’t find anything loose whatsoever at all. Knocking on the panels doesn’t even result in anything loose sounding from within. Wrapped the right rear seat back latch with electrical tape and secured the right rear seatback de-latch button by wedging thin cardboard into the edge of same. Any updates anyone? Is there a fix for this yet? What's weird is that it can sort of be heard just by starting up the truck in very cold weather, without even moving / being in motion yet; just by starting it up. Thank you very much. |
01-05-2020, 04:18 PM | #32 |
Rep 96
I think I found the source of my creak. The hatch glass!
When I press gently on the glass from the inside out, I can easily replicate but only on the passenger side. I'm going to schedule an appointment to take it in and will reply back when I know the fix. I assume they will have to remove the glass and reseat it, probably a one use item and I'll get new glass. |
01-05-2020, 07:58 PM | #33 | |
135
Rep 372
02-01-2020, 09:45 AM | #35 |
238
Rep 319
Drives: 2024 X5 M60i, 2020 RRS SE, 201
Some of you have read my post regarding the rear passenger area creaking which seems to originate from beneath the rear bench seat. My vehicle was at the dealer for 28 days, and I just got it back a few weeks ago. It was good on my drive home and I was elated. It seemed to be good for another day or two. But as things typically go, it returned to its full creaking symphony which occurs when accelerating or braking and with body flex. The slower I accelerate the more pronounced the creak is because it is more drawn out. They supposedly fixed some bad welds? But i think maybe they just used some duct tape on the panels as it didn't hold up. I have another appointment in a couple weeks. Hopefully it'll get fixed permanently and within no more than a few days...
Best of luck for all those out there with this issue. I posted my service invoice on my thread regarding this issue if anyone is interested.
RADMJK
2024 BMW X5 M60i Brooklyn Gray Metallic 2020 Range Rover Sport SE White 2017 BMW 530i xDrive Black 2005 BMW Z4 2.5i Jet Black |
02-02-2020, 02:54 PM | #36 | |
Rep 121
I hope now it stays like this... |
02-02-2020, 03:14 PM | #37 | |
238
Rep 319
RADMJK
05-28-2020, 11:51 AM | #38 |
Rep 2
rattle and creaks from the boot of my BMW X5 (G05)
I have been facing an irritating problem from my new BMW X5, i have only completed 1300km and have an irritating creaking sound and rattle from the boot while driving at low speed and over small bumps.
any suggestions on how to fix this issue!? Please help! |
05-28-2020, 02:01 PM | #39 | |
238
Rep 319
Good Luck!
RADMJK
04-30-2021, 12:56 PM | #41 |
12
Rep 3
X5 Tailgate Creaking Noise
Hi everyone,
I have a creaking noise on my BMW X5 G05. Picked it up last week with 8,000 miles on the clock and within a week of ownership, the noise began. The noise is in the tailgate and happens when I drive over bumps, drive up or down hills, accelerate, decelerate and anytime the car flexes. I had the same issue with my X5 F15 which I had in the dealership 9 times for. Sometimes they couldn't hear it but most times they applied a fix which lasted a week or two. Sometimes they had to order parts in. When the warranty expired and they started charging me for the work I got rid of it and bought a G05. I can't believe the noise is back. I had no idea this is such a common issue in many different models of BMW old and new. Anyway, I've managed to resolve the noise in my G05. I've adjusted the boot stops - I'm not sure if that is what they are called but they are rubber stops that can be adjusted back and forth to make sure the top tailgate sits in the correct position. I initially started following a video on YouTube where a guy places a strip of paper on the boot stop and closes the tailgate. If the paper can be pulled out without ripping and with some resistance, then the noise should disappear - this only helped reduced the noise for me not get rid. In actual fact, it needed to be adjusted until the paper ripped. This process helped me actually identify the noise from the outside of the car and adjust the boot stops to the correct position to eliminate the nose. With the tailgate closed, I pushed down on the tailgate underneath where the glass meets the bodywork above the rear lights, which made the creaking noise. I then adjusted the boot stop for each side, closed the tailgate and pushed down on the same points to check the noise level. I repeated this until I could no longer hear the creaking noise, then I took it for a drive and the noise was gone. I think I will have to do a video demonstrating the process. |
04-30-2021, 05:30 PM | #42 |
Rep 6,728
Sometimes, the rubber bump stops are actually installed with a coarse thread, so you can adjust the pressure by turning them...that may be all it would take. If it's rubber on metal, there are conditioners you can put on the rubber components which does two things, helps to preserve it while keeping it nice and black, and lets it slide a little without noises.
05-01-2021, 01:36 AM | #43 | ||
Rep 2,614
05-01-2021, 06:57 AM | #44 | |
PANIC!
478
Rep 823
I would like to see that video. I have a noise somewhere in the cabin as well. It's kind of hard to pinpoint the source location as car acoustics are notorious for being misleading. It seems to be more on the passenger side, towards the rear...somewhere.
