12-08-2020, 11:52 PM | #178 | |
Rep 2,420
The last time I saw a gas station was in august and I have done 2200 Km and have 90% fuel left. If my trip is within my electric range I drive in electric individueel and if it exceeds my range in drive in adaptive like you do. It stays in electric mode longer in EI mode, in adaptive the ICE turns on easier. |
12-09-2020, 07:40 AM | #179 |
Rep 14
Can anyone in the US describe a bit how the charging works at different levels? I have read in the manual that you can set the charge amperage at lower than 16a (16a is the max, I believe). In fact, I believe that the vehicle comes with the charging amperage set to the lowest setting. In the lowest setting on a 110v, regular outlet, how long does it take the vehicle to charge? What are the different amperage settings (i.e., can you set it at any number below 16, or are there different options, like, 8, 12, etc.)?
I am looking to understand what to do if I plug in to a regular outlet that I find somewhere. There are a few places where I anticipate charging from a regular outdoor wall outlet. If I don't know anything about the outlet (say, for example, that its old or something?) should I set the amperage to a lower speed? I know a standard outlet is rated for 15 amps, but does anyone know if it is safer to set the charging below that rate? |
Rikkiokbye40.50 |
12-09-2020, 07:43 AM | #180 | |
Rep 502
Rikkiokbye40.50 |
12-09-2020, 07:52 AM | #181 |
Rep 2,420
That is correct, that is a situation when all electric isn't powerful enough. I still keep it in all electric if my highway trip is short enough. Just because I don't want the ICE to turn on just for half a minute and it is kind of a sport keeping it in electric only. But it is really to slow to merge. Once on highway speed it is ok.
Rikkiokbye40.50 |
12-09-2020, 08:49 PM | #182 | |
Rep 532
Finito8443.50 |
12-09-2020, 08:52 PM | #183 |
Rep 209
The electric range is as other's have said dependent on your drive (city vs hwy) and your driving habits. What are your avg speed and avg miles/kw?
I am consistantly getting 34-38, 2.1 miles /kw since i picked up the truck, along w/ avg speed of 41mph. |
12-09-2020, 09:35 PM | #184 |
Rep 6,806
There's no reason to drop the X5's max charging rate unless the place where you plug in is sharing its socket with other things. The EVSE you use will send a signal that says how much power in amps it can supply, and then the X5 will limit how much is draws from it to that maximum.
FWIW, the supplied device is 10A and it works just fine. At 10A, and 120vac, it could take nearly a day to refill a depleted X5 battery. If you needed it sooner, you'd probably want a larger unit. Using a 16A, 240 vac device, 6-7 hours usually recharges it fully. Power = volts * amps and the vehicle is limited to 3700W/hr, and way less if the EVSE can't handle it (the vehicle automatically adjusts to what's coming in). The internal wiring is limited by the amps, not the power, so that's why it's limited to 16A. FWIW, a 120-vac input is less efficient than a 240-vac one, so you'll waste some energy doing it at 120-vac rather than 240-vac...you'll lose more in heat than actual power put into the batteries. |
Mothetgoo6.50 Needsdecaf6599.00 |
12-12-2020, 01:45 PM | #186 |
Rep 2,420
Nice 👍. My max so far is 86 km. Your average speed is also quite low probably this is why you got so many miles. This is the kind of traffic that is ideal for a PHEV.
12-26-2020, 02:47 PM | #187 |
Rep 8,700
Drives: eVeRyOnE mAD!
happy to come across this page! i just picked up my 45e a week ago. my daily commute is ~20 miles round trip. i've not been able to get a full "tank" of battery since my first drive because i'm using the charger supplied with the vehicle and don't have 22+h in between work days to fully charge, so the ICE has kicked in some, but even then i'm already seeing more MPGe than the mpg on my previous 2015 supercharged Audi Q7. i've used ~15% of fuel whereas with my old Audi after one week of work commute, i've used ~35-40% of fuel.
i'm getting a 240V outlet installed next week, so i'm excited my daily commutes will be all-electric. i'm currently running HYBRID mode, but will likely switch to EI after the new charger install. so far, the most electric range i've seen my car display on a full charge is 34mi. it's currently stating 31mi @ 100%. i have no climatize settings programmed, though i do use heated seats and steering wheel with thermostat @ 69ºF. Last edited by nZtiZia; 12-26-2020 at 03:30 PM.. |
X5 45e1090.50 |
12-26-2020, 05:09 PM | #188 |
Rep 6,806
If you haven't already, go into the iDrive menu and change the charge rate from the (default) 6A to 16A (the max the vehicle can accept or try to pull). The X5 (and any other EV) won't try to pull more than the device says it has, but the one supplied is only a 10A device...might as well get it charged faster.
nZtiZia4656.00 |
12-29-2020, 10:35 AM | #189 |
Rep 8,700
just last night, the car's showing a 36-mile electric range after charging from 9% to 100%. could this be due to a "break in" period with the high voltage battery as others have postulated, adapting to a more efficient driving style, both?
12-29-2020, 05:17 PM | #190 |
Rep 6,806
Temperature, your driving style, how fast you go, what electrical loads like seat heaters, rear window defroster, cabin heating, fan speed, lights, etc. and how much stop and go versus highway all play into how far you can go in any vehicle, but more so with a hybrid. Cabin heating can't (at least initially) come from waste heat from the engine, as it doesn't turn that on during the conditioning in the X5 45e. That will all affect the ultimate range with the batteries.
The vehicle is heavy and regeneration will never recover 100% when you slow, so a steady speed is important. Going up a hill will drain more power than on the flat, and drag goes up rapidly as you go faster. As sold in the USA, the initial EV range is defaulted to 30-miles. It will revert to that if you get an OTA update as well. Whatever is currently says is a projection that the conditions will be EXACTY the same as they were, which is often not the case, but it is constantly monitoring what's going on, and updating the readou to account for changes. |
12-29-2020, 05:40 PM | #191 | |
Rep 3
Charge speed
12-29-2020, 05:43 PM | #192 |
Rep 3
Our experience - we've filled the tank once. We have about 1800 miles so far. The range we get is about 1,000 on a tank before we refill it with about 8-10 gallons (on the first one). On track for that or less gas on second tank. Generally average about 40 mph - and usual projected range is 36-43 miles in the USA - northeast where it's turned cold. Real electric range in the cold is probably closer to 30 - when warm weather over 40 - miles. No babying. Just drive it.
popper42.00 |
12-29-2020, 05:52 PM | #193 |
Rep 6,806
The EVSE sends out a pilot signal that indicates how much power it has. It's then up to the vehicle to not ever try to pull more than the EVSE says. This works with any EVSE. I don't remember the menu indicating the lower power only works with level 1, but that could be. But regardless, unless your EVSE is sharing its circuit with something, there's no practical reason to limit the charging rate, so setting it to maximum (16A) can only help.
nZtiZia4656.00 |
12-30-2020, 03:09 AM | #194 | |
Rep 804
This is in Europe. |
12-30-2020, 03:40 AM | #195 | ||
Rep 2,420
The predicted range on the dash doesn't help you. I just take these distances: For driving on the highway and cold temperatures it is around 60 km range all electric. For driving on 50-70 km/h roads I have seen 80-85 km on a single charge. Max 50 km/h 25 degrees. On average in my experience it is around 70 km. Cold temperatures really reduce the range. |
12-30-2020, 12:08 PM | #196 |
Rep 6,806
Cold temperatures, with all of the potential heating elements in the X5 (seats, armrests, cabin, rear window, mirrors) can really suck down the battery capacity. Preconditioning while on the EVSE prior to leaving can help. Short trips when it cools off in between are the worst, especially if you tell it to keep the HVAC on while you run an errand in the store.
The prediction is based on the previous miles, and assumes you're going to do exactly the same thing under exactly the same conditions...that rarely happens. Unlike an ICE, where heat is a waste product that has little to do with the efficiency of the engine, in a hybrid, without the engine running, any heat comes out of the batteries, so cold temperatures will have a more severe effect on your range. |
12-30-2020, 12:23 PM | #197 | |
Rep 804
I guess I should charge it up and hit to road and see if the range really is much better or if the car is just lying to me. |
12-30-2020, 12:31 PM | #198 | ||
Rep 2,420
60 km on highway 70 km 70-90 km/h roads 75 - 80 on 50 km/h roads All less when it's cold And it unexpected lower you still have the ICE Can they do a better job? Yes: just take the average since factory to calculate the range after charging and adjust while driving. Same fir the range on fuel. If you drive electric a lot it gradually increases to 1000 km and more. Once you turn the ICE it goes down rapidly. Better use the average mpg on fuel since factory to calculate the range on fuel. |
Bimmertaz4.50 |
