      06-10-2021, 07:23 PM   #1
GBB2
GBB2
Drives: BMW X5 G05
2019 Base Front Brakes
Does anyone know if there are any special requirements to replace the front brake pads (non-M)? i.e. Any special procedures before compressing the piston? TIA
      06-19-2021, 04:30 PM   #2
GBB2
GBB2
Drives: BMW X5 G05
So I ended up ordering the Powerstop Z23 Carbon fiber ceramic (base) front brake pads and installed them today. Pretty much like replacing any other brake pads. Remove caliper/compress pistons & install new pads. I spent more time polishing the rotor hub and cleaning the calipers than actually swapping the pads. After install I did set the parking brake before touching the brake pedal and starting the car. Brakes feel good, much less grabby than the stock pads.... smoother stopping. FYI car had just a little over 27k miles..mostly city driving.
      06-19-2021, 05:00 PM   #3
Gone Fishing
Gone Fishing's Avatar
Drives: BMW X5 xDrive 40i
Thanks for the update, let us know after a few thousand mile how they feel
      07-04-2022, 01:39 PM   #4
johnronin
Drives: F90 and G05
How do you take off the metal brackets holding the pads in the calipers?
      08-29-2022, 04:11 PM   #5
Bking60
Drives: BMW X5 2019
Those are just anti rattle springs. Take a picture first because even though they pop off with some needle nose pliers (safety glasses) they are confusing to get back on sometimes since they go back under spring tension.
