03-09-2023, 11:19 AM | #23 |
981
Rep 1,560
Using the upper button on the end of the turn signal stalk to scroll through the options for different dash displays. One of them has the current gear displayed prominently.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
RickObe93.00 |
03-09-2023, 02:21 PM | #24 |
Rep 10
I think we should also use the setting to turn off music when stop button is pressed. This way we will be attentive to any beeps/chimes when P is not pressed and the door is opened. I will do that today myself.
03-09-2023, 06:34 PM | #25 |
Rep 213
Where is that setting hiding?
X5 xDrive 45e 2023 / Mineral White / Tartufo / Anthracite-Brown Poplar
03-09-2023, 07:28 PM | #26 |
13274
Rep 19,798
That is a good question, we have never seen a setting like that as far as I know. The closest is turning of the electronics when the door is opened.
03-10-2023, 04:20 AM | #27 | |
Rep 213
The thing I've not been able to figure out is that while most of the time my music/podcast stops when I open the door, on occasion it does not. Media source is iPhone bluetooth without CarPlay. Annoying when it's a podcast and I end up missing the time it kept playing. I haven't been able to figure out what conditions cause it to continue (even though the car has turned off (dropped out of ready mode)).
03-10-2023, 06:50 AM | #28 | ||
Rep 8,698
Drives: eVeRyOnE mAD!
03-10-2023, 07:16 AM | #29 | |
Rep 298
03-10-2023, 09:22 AM | #30 | |
13274
Rep 19,798
RickObe93.00 |
03-10-2023, 10:13 AM | #31 |
Rep 804
I have Auto Hold enabled most of the time. When I park the car, I use brakes to stop and Auto Hold engages. Then I unbuckle the seat belt, open the door, and the parking brake is automatically engaged. I step out, close the door, lock the car and the car shuts down. There's no way it could roll away. I never touch the gear selector, parking brake, or the start/stop button.
03-10-2023, 11:30 AM | #32 | |
Rep 539
My car probably chimed when I opened the door with N engaged, but my car chimes all the time and it's the same chime whether the temperature is 37 degrees or someone's about to smash into me. Good suggestion about the display of the current gear. For something so important the default isn't prominent enough. I will change that ASAP. |
playswcars3633.50 |
03-10-2023, 12:54 PM | #33 | |
Rep 176
03-10-2023, 01:07 PM | #34 |
Rep 804
03-10-2023, 03:29 PM | #36 |
Rep 114
I was skeptical of the autohold setting, and thought it would be annoying in situations where I didn't want to come to a full stop. But It's good about not engaging until the vehicle is fully stationary, and acts like the hill hold feature I had on a prior Audi. I love that I can take my foot off the brake at longer stop lights without having to shift gears, and the incidental safety advantage of it flipping on the parking break automatically when you exit the car is just icing on the cake. I never plan to turn it off.
biterror517.00 theblackfalcon25.00 |
03-10-2023, 06:18 PM | #37 |
817
Rep 1,785
Until recently most floor mounted automatic transmission were placed in Park by moving the shifter forward. The current BMW setup requires the push of a button instead. Moving the shifter forward puts the transmission in Reverse. Hmmm?
03-10-2023, 08:41 PM | #38 |
Rep 19
This exact thing happened to my dad. He swore he put it into park and got out of the vehicle which sat in place long enough for him to walk to the gate to open it up (He was dropping off his RV). The X5 started rolling behind him and it smashed him against the chain link fence. He was lucky he had his phone in him because he couldn't get it off of him and no one is permanently at the lot.
When I got there I jumped in and it was in neutral not park. Got the vehicle moved off of him and by that time the ambulance was there and took him to the hospital where he needed surgery on a massive hemoglobin that formed on his leg. |
03-11-2023, 03:58 AM | #39 | |
Rep 8,698
i mentioned this in another thread that the color of the PARK indication on the instrument cluster determines which brake is engaged: a green PARK indicates Auto Hold is holding the vehicle using the disc brakes while a red PARK indicates the parking brake is holding the vehicle. when you say the parking brake is automatically engaged, can you confirm it’s a red PARK on the cluster and the red LED on the parking brake switch is lit? I couldn’t replicate your scenario above; Auto Hold held my vehicle, and the parking brake didn’t automatically engage (red LED on the parking brake switch wasn’t lit). |
03-11-2023, 04:46 AM | #40 |
Rep 213
Do you recall where that setting is located. I don't recall seeing it when I went thru every setting during setup.
03-11-2023, 04:57 AM | #41 | |
Rep 213
When I'm at a stoplight and want to take my foot off the brake, I just manually engage the parking brake. When it's time to go, light pressure on the accelerator automatically releases it. That's essentially just like auto-hold but without the automatic engagement at each stop.
aMIC31.00 |
03-11-2023, 05:27 AM | #42 | |
Rep 804
nZtiZia4655.00 |
03-11-2023, 05:57 AM | #43 | |
Rep 1,236
I was given a new 3 series while my X5 was in service. The new Autohold would not engage with light brake pressure even when the car is in complete stop. You have to depress the brake pedal further, even slightly, for the Autohold to engage. This is quite similar to my previous Mercedes which did not have an autohold button. |
03-11-2023, 09:51 PM | #44 | |
Rep 114
I can confirm, my autohold works this way if you hit the power off button while in drive but at a full stop. This is how I shut my car down when arriving in my garage every night. |
