03-23-2024, 08:21 PM | #1 |
28
Rep 42
Car not using side mirror turn signal
Hi everyone,
I have noticed something interesting, my 2021 40i side mirrors turn signals don’t turn on when I’m pressing the stalks. The LED’s definitely work because they blink when I’m locking the car but not when turning on the hazard or the turn signals. I don’t know if it was coded like this in the factory but if anyone has any ideas let me know! |
03-23-2024, 09:12 PM | #2 |
Rep 8,700
Drives: eVeRyOnE mAD!
never heard of this before. something's wrong given both sides don't blink when activating the stalk. get it checked out
03-24-2024, 09:58 AM | #3 |
Rep 7,487
Just to verify…you’re not referring to the blind spot warning arrow integrated into the mirror glass as your turn signal LEDs, right? The turn signal is incorporated into the back side of mirror housing…so when you’re inside the vehicle…the turn indicator LED on the side mirror housing is not that visible since it’s facing away from the those inside the cabin.
#2 is the blind spot warning arrow: #2 is the turn indicator:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-24-2024 at 10:10 AM.. |
JA-0628.00 |
03-24-2024, 10:15 AM | #4 | |
Rep 8,700
03-24-2024, 10:59 AM | #5 | |
28
Rep 42
I’m gonna make an update with pictures so it might be easier. |
03-24-2024, 11:07 AM | #6 |
28
Rep 42
Update!
After gently smashing the left mirror I got the LED to work, but nothing for the right one…. I’m noticing a lot of condensation in both LED’s, not as much as in the headlights but still. Could it have cause the LED to burn out? I’m gonna set up an appointment to have them fixed. It’s probably just bad luck to have one with such poor lifetime… |
03-24-2024, 12:04 PM | #7 | |
Rep 4,337
If you prefer to leave it as is so the dealer can verify the failure, that's fine too. |
volodp198.00 |
03-24-2024, 12:54 PM | #8 | |
28
Rep 42
03-24-2024, 01:00 PM | #9 | |
Rep 8,700
take a video to show the actual sequence of the issue in the off-chance they both start working again |
03-24-2024, 03:06 PM | #10 | |
Rep 4,337
04-02-2024, 05:23 PM | #12 | |
28
Rep 42
Marty in NY2723.00 |
04-03-2024, 07:31 AM | #13 | |
Rep 4,337
JA-0628.00 |
04-03-2024, 11:10 AM | #15 |
28
Rep 42
It might have been a good thing I wasn’t able to make the right one to work. At least they were able to see on their own it isn’t working. They were looking for physical damages to it at first but couldn’t find anything. Then, they saw the fault also appear on the computer so that’s why they are going for warranty.
04-03-2024, 11:12 AM | #16 | |
28
Rep 42
04-04-2024, 12:09 AM | #17 |
Rep 6
I don't see them flashing at all on the video. I thought they might be pointing towards the side but I saw a different video where the flashing is clearly visible from the front.
