02-02-2023, 05:12 AM | #221 |
Rep 481
So far, I haven't had the issue anymore since I made the change. That is very good news, after almost 3 years!!!! But now I'm wondering, what happens when the HV battery runs out? To what mode will the car switch? I asume the default/hybrid was there for a reason right?
02-02-2023, 06:30 AM | #222 | |
Rep 8,767
Drives: eVeRyOnE mAD!
02-02-2023, 06:36 AM | #223 | |
Rep 481
1) The default drive mode configured in iDrive. 2) The default (fallback) drive mode of the car (only configured through coding). Default is Hybrid, can be coded to EI. So with 1 we noticed when putting it on EI by default, it sometimes still starts up in hybrid (comfort access related). But when changing 2, the fallback mode of the car will be EI instead of Hybrid. So when it fails to load the configured user preferred drive mode (1), it will load the coded fallback default which is coded to EI. |
02-02-2023, 06:42 AM | #224 | |
Rep 8,767
02-08-2023, 02:13 PM | #226 | |
Rep 481
02-08-2023, 03:56 PM | #227 | |
Rep 8,767
volodp199.50 |
02-09-2023, 06:20 AM | #228 |
Rep 481
Agreed that it's a workaround. I tried the official route (been to the dealer many times for this issue as you can read in this thread), but that path has shut down since BMW DE simply responded they acknowledge the problem, but don't have any priority in fixing it. So for me, this solves my issue. With regards to coding, you can try someone in your area to help you with that, or just buy an ENET cable/dongle, buy the Bimmercode app, and do it yourself. There are many walkthroughs available how to code. I do the coding with an ENET cable <> ethernet/lightning converter <> iPhone. Works very fast/simple/reliable. It's something that can be fixed in less than 5 minutes.
nZtiZia4711.50 |
02-09-2023, 06:35 AM | #229 | |
Rep 8,767
ikheetleon218.50 |
02-22-2023, 10:13 AM | #230 |
Rep 8,767
ikheetleon
so I coded the 0x15 in BimmerCode yesterday, but twice I’ve returned to the vehicle in Comfort suspension level I enabled EI as default with Sport suspension level. while the vehicle starts up in EI, why is it ‘falling back’ to Comfort level suspension when my EI settings have Sport level chosen? |
02-22-2023, 11:20 AM | #231 | |
Rep 481
I’ve never switched to hybrid at startup after the coding change btw, so still very happy with the solution/workaround. |
02-23-2023, 04:15 PM | #232 | ||
Rep 8,767
note that I always park in Load suspension level. before coding 0x15, the frequency of random rising to Comfort suspension level (thus, Hybrid drive mode) was far less frequent. after coding it, i frequently found the vehicle at Sport suspension level (my default EI suspension level) shortly after parking. it ‘fell back’ to my default EI drive mode way too frequently to the order of 99%, thus rising from Load to Sport level. under 0x11, it stayed in Load level 99% of the time after parking and only randomly rising to Comfort level (Hybrid drive mode) 1% of time. I’ll stay with the default 0x11 code as the vehicle staying in Load level is more important to me |
ikheetleon218.50 |
