      12-23-2020, 10:05 AM   #1
Noneya
Drives: '21 X5MC, '14 X1 35i M sport
2021 X5MC  [0.00]
SiriusXM stopped working
Figured I'd ask here first since I won't be able to take it to dealer anyway until next year.
My SiriusXM channels have disappeared, and when I go to the right panel and click subscribe it shows a blank radio ID. Has anyone seen this before? I tried restarting iDrive a couple of times to no effect, so I'm guessing it's a hardware issue.
The other radios - FM, bluetooth, wifi - all work normally.
      12-23-2020, 10:20 AM   #2
Paladin1
Paladin1's Avatar
Drives: 2022 iX xDrive50, DGM
If the other radios work the problem is likely Sirius. Good idea to contact them and verify radio ID and account.
      12-23-2020, 11:03 AM   #3
Noneya
2021 X5MC  [0.00]
Everything looks fine when logging in to Sirius, the car radio ID however is not shown in the car as I mentioned in OP - it is blank, so it appears to be a car problem of some sort.
      12-23-2020, 11:44 AM   #4
Paladin1
Paladin1's Avatar
You might try this:
https://care.siriusxm.com/retailrefr...#/refreshradio
Or just give Sirius a call to sort it out. If they can't, you know it's a car problem. Little time lost, and I'd certainly try that before I left my car at the dealer. If you contact your dealer and get a "duh," you still don't know if it's a car problem or a vendor problem.
      12-24-2020, 10:02 AM   #5
Noneya
2021 X5MC  [0.00]
You might try this:
Thanks - I tried that to no effect.
      01-05-2021, 09:16 PM   #6
BlueX5
Drives: Bmw x5 2021
Did you get this resolved? Mine is doing the same thing
      01-05-2021, 10:01 PM   #7
Noneya
2021 X5MC  [0.00]
No, I haven't had time to take it to dealer. Likely will wait until 6k service. Please let me know if you get a resolution before I do, and I'll update this thread once I do.
      01-06-2021, 12:12 AM   #8
roughyear
Drives: 2021 X5 M Sport
I wonder if you have the same problem I was having.. when you're on the XM radio, are you able to see all the channels but no sound from the speakers, Or just Channel 1 displays?
In my situation, all the XM channels would display, and I could see the graph of the volume/synthesizer moving up/down like it was playing, but had no sound coming from the speakers, though AM/FM and bluetooth from my phone would play just fine through the speakers. Basically, after about 4 hours at the Stealership, the last thing they did was disconnect the battery for a few minutes and reconnected, which somehow magically allowed XM to finally work properly.
      01-06-2021, 09:45 AM   #9
Noneya
2021 X5MC  [0.00]
No, I have 0 channels, and no SiriusXM ID. It's as if there is no XM antenna in the car.
      01-26-2021, 04:32 PM   #10
zonefive1
Drives: BMW X5
I had the same issue... I fixed it by "resetting" the radio system. Hold in the volume knob button for 30 seconds. Give it a try...
      01-27-2021, 11:09 AM   #11
timmahh
ghey
timmahh's Avatar
Drives: Viertürigen Fahrzeugs
My SiriusXM did not show at all, so perhaps you have a similar issue. I could see it as a source in the list of sources to show, but I could never actually use it as an audio source.
Dealer had to fix it, seems like a a module update or some reset, as they did not upgrade the vehicle itself (remains on xx.2019).
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
      03-02-2021, 10:29 AM   #12
Noneya
2021 X5MC  [0.00]
Finally took it to the dealer who said they needed to reset software due to some recall. I didn't care enough to try understanding the details.
      03-25-2021, 09:54 AM   #13
Stewball1
Drives: BMW X3
Just had the problem yesterday. Thank you so much for the fix. Worked perfectly. Saved a trip to the dealer and hours of waiting
