04-05-2019, 10:14 AM | #23 |
Rep 1,448
I called my dealer's electronic shop and they recommended the Blackvue 900: https://www.blackvue.com/dr900s-2ch/
With a 64 card, the online price is $540 + installation fee of $150-250. Is the 750 adequate for someone who does not expect to post videos online? In order to get videos made when the car is parked, I suppose one use the car's Wifi to access the videos on my iPhone. What would AT&T charge me for one month of Wifi on the open road? So I just stumbled over blunder as I suppose the Wifi only works when the engine is running, right? Edited to say I wish I had seen this thread earlier, but the inconsistency of using subforums contributes to this confusion: https://g05.bimmerpost.com/forums/sh....php?t=1586693
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 Last edited by Xeno; 04-05-2019 at 08:01 PM.. |
04-05-2019, 07:28 PM | #24 |
Rep 164
Drives: 2019 BMW X5; 2017 Audi Q7
I asked my dealer today how much installing the Advance Car Eye 2.0. They quoted an estimate of $524 for labor only.
Has anyone installed this camera themselves? Also looking at the Thinkware FA200 and Blackvue DR590W and doing the install myself. |
04-08-2019, 12:27 PM | #25 | |
Rep 19
Drives: BMW 320d Luxury Line
20190404_180430DE.avi Format : AVI Format/Info : Audio Video Interleave File size : 150 MiB Duration : 1mn 0s Overall bit rate : 21.0 Mbps IsTruncated : Yes Video #1 ID : 0 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings : 2 Ref Frames Format settings, CABAC : No Format settings, ReFrames : 2 frames Format settings, GOP : M=3, N=15 Codec ID : H264 Duration : 1mn 0s Bit rate : 10.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.161 Stream size : 71.6 MiB (48%) Video #2 ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings : 2 Ref Frames Format settings, CABAC : No Format settings, ReFrames : 2 frames Format settings, GOP : M=3, N=15 Codec ID : H264 Duration : 1mn 0s Bit rate : 7 585 Kbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.122 Stream size : 54.2 MiB (36%) Audio ID : 2 Format : PCM Format settings : Little / Signed Codec ID : 1 Duration : 59s 998ms Bit rate mode : Constant Bit rate : 705.6 Kbps Channel(s) : 2 channels Sampling rate : 22.05 KHz Bit depth : 16 bits Stream size : 5.05 MiB (3%) Alignment : Aligned on interleaves Interleave, duration : 25 ms (0.75 video frame) |
Xeno315.00 |
04-08-2019, 12:27 PM | #26 |
Rep 19
Get either of those, don't go for the BMW dashcam.
04-08-2019, 12:46 PM | #27 |
Rep 164
04-08-2019, 02:48 PM | #28 | |
Rep 1,133
It's good to be bad
04-08-2019, 03:55 PM | #29 | |
Rep 1,448
I saw your thread but DIY was something I did in early years with simple cars and not something I wish to take on these days. In another forum, an owner of this camcorder said that if I wanted better security by using the parking mode the reality was that all kinds of things could set off the motion detector from trees to passing cars. He said his approach was to "use time-lapse and G-sensor (records if dashcam records an impact) as a compromise." What is your experience with the parking mode? Edited to say I could not find that price on Amazon today with the 128.
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 Last edited by Xeno; 04-08-2019 at 04:43 PM.. |
04-08-2019, 05:22 PM | #30 | ||
Rep 1,133
It's good to be bad
Xeno315.00 |
04-08-2019, 05:29 PM | #31 | |
Rep 1,448
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 Last edited by Xeno; 04-08-2019 at 05:55 PM.. |
skalberti614.00 |
04-16-2019, 06:11 AM | #32 |
Rep 17
BigSanj - sorry for the delay in getting back to you. I'm still trying to get to grips with it to be honest - initial findings are not good. Connectivity to the iPhone app is very very flaky (keeps dropping) when trying to view images. It also seems to be an art setting the sensitivity for the Radar and G sensors. Setting to the max sensitivity seems to quickly fill up your SD card. Also noted that when the SD Card is full you get a very annoying beep beep beep every 2 minutes ... an undocumented feature. I'm going to try it with an Android phone at the weekend and will report back.
04-16-2019, 06:21 AM | #33 |
Rep 3
Drives: 2015 X5 30d msport
BMW Drive Recorder
Anybody know anything about this option:
6DR BMW Drive Recorder Supposed to be a dashcam/drive recorder using the built in cameras of the G05. |
04-16-2019, 08:26 AM | #34 | |
Rep 1,448
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 |
04-16-2019, 08:27 AM | #35 |
Rep 1,448
Do you have a link?
04-16-2019, 09:53 AM | #36 |
91
Rep 306
04-16-2019, 09:53 AM | #37 |
Rep 3
04-16-2019, 09:56 AM | #38 |
Rep 1,448
So only on 7 period?
04-16-2019, 10:00 AM | #39 |
91
Rep 306
04-16-2019, 04:13 PM | #41 |
Rep 494
[QUOTE=Xeno;24627977]Which brand sd card did you buy? Can't be the Blackvue brand?
2019 BMW X5 40i Phytonic Blue/Tartufo
2016 BMW X3 35i M-Sport, Dinantronics (sold) 2012 BMW X3 28i (sold) |
04-16-2019, 08:26 PM | #43 |
91
Rep 306
