10-18-2022, 02:58 PM | #375 |
18
Rep 46
Can I get a quote for a 12 / 15 set up with correct lugs
Also a quote for an arctic white F95 painted rear spoiler With total price shipped to Langley, B.C. Canada V1M 4G3 |
r33_RGSport13053.00 |
10-18-2022, 08:00 PM | #376 |
13053
Rep 18,756
PM'ed.
11-03-2022, 08:48 PM | #378 |
Rep 2,080
Quote on 13mm or 15mm front and 20mm rear. Any options on lower springs? Like eibach pro kit
11-04-2022, 09:03 AM | #379 |
Rep 2,080
Updates? You sleep to much man.lol
What do you recommend for front? 13mm or 15mm with 20mm on rear? m50i on 21s. Setup above with lower springs. Send me the option of the H&R you have. Ship to 34117
11-04-2022, 09:45 AM | #380 | ||
13053
Rep 18,756
You are like asking question in the middle of a room with a bunch of people who are busy talking to others. I am out for biggest aftermarket trade show in the US. PM coming anyway.
11-04-2022, 10:38 AM | #381 |
Rep 2,080
reply send
11-04-2022, 10:39 AM | #382 |
Rep 3,042
Drives: 2022 BMW X5
waiting for another 2-3 weeks to put H&Rs from Ben (in my case 12mm & 15mm) I would rather go about 20mm on the back but can not because of studs I'm using, they allowing 15mm max.
Ben are you at SEMA? if you are have fun
11-04-2022, 11:44 AM | #383 |
13053
Rep 18,756
Yes, I am at SEMA.
boneca2027.00 |
11-05-2022, 03:37 PM | #384 |
Rep 10
Drives: BMW X5 M50i
Hi, I'm new to spacers. I know PCD = Pitch Circle Diameter & CB = Center bore.
But what is DRA? As in "25MM Spacer 5/112 PCD 66.5 CB DRA Rear Axle Only" I'm looking at a 9.5" square winter wheel setup and I think a 25mm spacer will bring the rear back into the 10.5" position of my OEM summer wheels. |
11-05-2022, 10:54 PM | #385 |
Rep 31
AECDY
silverstar335 r33_RGSport Spacer advice needed: I have a 2020 X5 m50i w/ air suspension running 742M wheels on 22in Pirelli P-Zero All Seasons. Seeking aggressive setup that doesn't look out of place/goofy. Highly considering lowering w/ sport springs in the near future. Should I go with 15/20? 18/25? AECDY recently mentioned 22.5 / 30 ! I normally drive in comfort mode but also obviously enjoy sport mode which changes the ride height in certain conditions. Thanks for your input! Pics would be great also! Located in zip 28032 (NC) for shipping Ben! |
11-06-2022, 06:24 AM | #386 | |
299
Rep 352
Pictures are at loading height (I am on air suspension). |
r33_RGSport13053.00 Mrc8886.00 |
11-06-2022, 06:28 AM | #387 | |
Rep 1,340
11-06-2022, 06:30 AM | #388 | |
299
Rep 352
DR are the ones that you hold with longer bolts. Same bolts hold wheels and spacers. Usually anything over 20mm would be DRA |
r33_RGSport13053.00 G05X53.50 |
11-06-2022, 09:19 AM | #389 | ||
13053
Rep 18,756
In BMW case, DRA is available on any spacer thicker than 20mm where it is bolted to the wheel hub with supplied lug bolts, then your wheel to the spacer. Quote:
PM me with the size that you want and I'll give you a quote.
11-06-2022, 10:36 PM | #391 |
13053
Rep 18,756
No sure if the Bolt size and thread pitch are the same.
Also the center bore design most likely is different between Audi and BMW. My rule of mods, anything that can risk a life of my passenger and/or me, I wouldn't save money on. If I want to save money, I won't mod it.
nZtiZia4737.50 |
11-07-2022, 05:25 PM | #392 |
Rep 31
AECDY
What wheel bolts did you use with your 18mm H&R spacers? The H&R 50mm bolts? H&R is telling me to run 15mm spacers I need 43mm bolts. To run 18mm spacers I need 46mm spacers. H&R only sells bolts in 43mm & 50mm. Also I am looking for H&R part number 3055664 (15mm spacer in silver); and everything is out of stock until the first week in December. I already have 20mm spacers in the rear in silver; so I need them to match. Thanks for your help on this! I really appreciate it! |
11-07-2022, 05:52 PM | #393 | |
Rep 2,070
11-07-2022, 06:30 PM | #394 | |
299
Rep 352
He is the expert 😀 |
11-07-2022, 06:42 PM | #395 |
13053
Rep 18,756
Thank you guys for the kind words.
11-09-2022, 11:21 PM | #396 |
25
Rep 46
What spaces would you recommend for my winter setup? Looking for flush, but not Mexi-flush.
I'll be installing a set of 748M with the Grabber AT/3 setup on my 45e. |
