04-26-2024, 07:27 PM | #1 |
Rep 50
RFT wear on M60
In anticipation of my M60i arriving next month, I tried my best at searching but couldn’t find any clear numbers about how the RFTs on the 20 inch rims wear (would have preferred the 22s, but Jersey… and not wanting to run a dedicated winter set)
Will they go 25-30k miles and be acceptable at a lease turn in or should I just swap out run flats and then put them back on at lease turn in? |
04-26-2024, 10:02 PM | #2 |
Rep 1,162
Can't help on the 20s, but my M50 on the 22s got it's second set o rearf tires somewhere around 18-20k miles, and the fronts when I bought it with 22k on it. The 22s may come with a vastly different compound, but I suspect not and that you'll be on your second set of tires by 30k and possibly close to needing your 3rd set depending on how you drive..
At the end of the day it's a 500-600hp medium size SUV. It eats some rubber. |
04-27-2024, 12:33 AM | #3 |
Rep 231
After 9,000 miles on 21” RFT summer tires they’re at 7/32 - so I’d expect to need to replace them by 20,000 miles or so. We’ll see what they’re like in the fall.
20” Winter run flats at about the same mileage are at about the same tread depth. Given that I drove about 2200 miles this winter, they should get to five years about 15k before replacement is warranted. |
04-27-2024, 09:01 AM | #4 |
Rep 1,215
I suspect you can get 20--25k miles out of the 20's. In the past I have swapped the RFT's for non-RFT's at about 15k miles and then put them back on prior to lease turn in. Make sure you have space to store them and that you have a space saver spare.
2024 X5M60i-- Skyscraper/Ivory
2020 Cayenne replaced by ^^ 2017 X5 35d--still in my diesel phase 2015 GL 350--diesel burner/highway queen 2013 Audi S6--a beast in it's day |
04-27-2024, 09:38 AM | #5 | |
Rep 8,867
Drives: eVeRyOnE mAD!
04-27-2024, 12:04 PM | #6 | |
Rep 3,413
Keep in mind my X5 is a 40i, not an M60. So, your tire wear will be less if you are doing it right. |
04-27-2024, 12:11 PM | #7 | |
244
Rep 375
04-27-2024, 12:21 PM | #8 |
Rep 50
04-27-2024, 12:40 PM | #9 |
Rep 3,413
04-27-2024, 10:10 PM | #10 |
21
Rep 34
I can’t wait to put these scorpions on. In searching the forums, I’ve found several people talking up these tires. I can’t bring myself to scrap my brand new run-flats though, it’s too wasteful.
04-29-2024, 09:59 AM | #11 |
Rep 62
Our M60 came with the Continental RFT’s on the 21” M915 wheels. We got 13k miles before they were worn out. Replaced with Pirelli PZ4’s. Like them much better.
1975 3.0Si E3 Jade Green
1985 535i E28 Schwarz 2002 M5 E39 Carbon Blue 2016 M4 Convertible F83 Alpine White 2020 M5 Competition F90 Donington Grey |
bubbajk41.00 |
04-30-2024, 08:17 AM | #14 |
Rep 139
You'll need at least 4/32" tread depth for acceptable lease return. Depending on your driving style/conditions, I'd say it's possible but more the exception than the rule. You could end up having to replace all tires near the end of the lease. I always budget a set of tires into my 3 yr lease and just enjoy the car and not worry about tire wear.
