      03-20-2020, 05:29 AM   #155
ifr
ifr's Avatar
United Kingdom
1197
Drives: Tesla MY LR AWD
Originally Posted by jose260gti View Post
Is it possible to code the G05 with e-sys 3.27.1 and luncher pro 2.8.2?
No
      03-28-2020, 06:31 AM   #156
Xmel`
Drives: BMW X5 G05
Hi LexxM3. Did you check something about ASD?
Thanks in advance
      03-28-2020, 10:50 AM   #157
LexxM3
LexxM3's Avatar
1698
Drives: E46M3, G05X5
2019 X5  [0.00]
Thanks in advance
I am not completely sure what the question is, but yes, ASD can be coded off, even in latest Bimmercode (iOS v3.5) on G05 now.
      03-28-2020, 02:17 PM   #158
007bandido
Switzerland
Drives: 2019 G05 30D M
Hello,
Just updated my G05 12.2018 swiss car to 03/2020.24 two days ago (S18A-20-03-524). I coded several stuff. Works great !
Driver recorder is normally not available in Switzerland (legal stuff). There is something to do with Esys to code this option or is just a connecteddrive posibility. Of course not available for my country.
Regards,
Miguel
Note: Drive_Recorder in MGU ncd is already aktiv.
      03-28-2020, 02:50 PM   #159
ifr
ifr's Avatar
United Kingdom
1197
Originally Posted by 007bandido View Post
Hello,
Regards,
Miguel
Connected drive subscription only I'm afraid.
Nothing coding can help with
      03-28-2020, 03:00 PM   #160
Xmel`
Drives: BMW X5 G05
Thanks in advance
I Mean some parameters that probably can modify the sound of asd. We discussed it before.
By the way can you write parameters that switch it of?
      03-28-2020, 03:55 PM   #161
007bandido
Switzerland
Bad news ! But thanks.
      03-31-2020, 06:13 PM   #162
Xmel`
Drives: BMW X5 G05
Do you know if it is possible to code off-road package?
I know there should be a trigger on the central panel. But maybe it is possible from the idrive menu as well.
Any ideas were to check those settings?
      04-04-2020, 12:23 PM   #163
AAN
Drives: X5 G05
Hello
I have X5 40i and I’m living in the middle east, the car is equipped with ConnectedDrive option and Carplay. The car agent in my country does not have agreement with the internet service provider, hence the ConnectedDrive practically does not work as it can not connect to BMW Cloud, consequently I can not create driver profile (always as Guest) and can not have the BMW apps, etc., but fortunately, Carplay still working and seamlessly connects to my iPhone.
Now my car is due for service and the agent wants to update the iDrive (currently on 03/2019.35) and he warned me that I will lose Carplay by this update because BMW has made Carplay as part of ConnectedDrive and I will not be able to have it any more.
My question if there is any way to reactivate the Carplay after the iDrive update? And if it would be helpful to deactivate the ConnectedDrive through Esys to force the car to enable the Carplay and create driver profile? Need your help please.
      04-04-2020, 06:34 PM   #164
mandomedic122
Drives: BMW 2019 X5M G05, Mini 2016 S
Originally Posted by X5G05SYD View Post
Anyone been able to code the rear tail lights to be on as rear DRLS lights on with Front DRLs ?
Cheers
J.
Add 8TL to VO/FA and code BDC
      04-13-2020, 06:26 AM   #165
vet23
Drives: G30 530D
Does anyone know how to add interior color?
      05-17-2020, 02:00 PM   #166
Atlanteg
Drives: BMW X3 F25 LCI 20d 2016
Yes sure
      07-01-2020, 08:35 PM   #167
TRX
Drives: 2019 BMW X5 50i M sport
Originally Posted by AAN View Post
Hello
Hi I guess your car is from Abu Dhabi dealer? From what I know Abu Dhabi dealer doesnt have agreement to use connected drive (no internet or apps) but dubai does, now mine after 03/2020 update my apps were removed (had news, weather, and soms other), maps were renwed and now I see more details in instrument cluster map, as for connected drive its strange that Apple carplay was taken out from you, cause its part of car specs when you buy it, so just contact them and try to get it installed for you they should bring it back, as for.coding I heard so far that it voids warranty in our region, you can double check because I know it shouldnt but thats what 3 series owner told me that agent wont accept coding.....
      07-03-2020, 08:05 AM   #168
Abdulllh
Drives: BMW X5
I'm using Bimmercode to fix FM Radio band
I imported a car from Canada to UAE Dubai
I tried expert mode settings
TUNER_FM_AM_REGION and I changed the region but I still can't tune my radio
Anyone could help please
      07-05-2020, 03:07 AM   #169
atlas
Australia
378
Drives: F10 535i, M2 LCI, G05 X5 40i
Anyone know if it's possible to code the front fog lights to come on at startup?
      07-26-2020, 01:22 PM   #170
Curamrda
Curamrda's Avatar
Drives: F13
how to turn of the automatic start the driving assitants after engine on?
coz its really annoying the keep line assistant.
      08-17-2020, 02:52 PM   #171
Curamrda
Curamrda's Avatar
Drives: F13
nobody? at least coding to remember last setting?
      08-17-2020, 03:05 PM   #172
RayoVac
RayoVac's Avatar
Drives: 2020 X5 M50i
I think the problem is from your previous post, your request is not clear. Maybe language barrier involved, but I can't decipher what feature you are talking about?
If you mean selecting a default drive mode, starting with the car in Sport, Comfort, Eco etc. Yes, that can be coded, but I don't think we can code to remember what the last mode you used and startup in that mode again.
Now if you are talking about Auto Start-Stop (car shuts off when at a stop light etc.). Yes we can code that to remember the last used setting and retain it through ignition cycles.
If neither of the above, you will need to better explain the feature you are interested in.
Rayo
      08-18-2020, 10:08 AM   #173
Curamrda
Curamrda's Avatar
Drives: F13
Hi sorry. No. I ment if I hold the Inteligent safety button for a while to turn all assistents off, or if I set some of the assistent OFF - like eg: line assist.
I wanna to keep the setting even after turn off the engine.
      08-21-2020, 04:55 AM   #174
Zethii
21
Drives: BMW X5 G05
You seem to be in guest profile. Set up a personal profile and your INDIVIDUAL safety settings should be stored. I am not sure if - ALL OFF- will be stored.
      08-23-2020, 06:16 AM   #175
Curamrda
Curamrda's Avatar
Drives: F13
That was just sample foto. Yes. I need ALL-off memory !
This has to be somehow codeable. Does anybody know which ECU is responsible?
      08-31-2020, 02:22 AM   #176
Element_115
Drives: ‘23 M3 Comp
I’ve coded a few things with BimmerCode but now have a question if anyone may know the answer.
I have a US Spec ‘20 M50i and have coded Video In Motion. Does anyone know how the iDrive system reads the USB. How does it list the videos? By Size? Date Modified? Name?
For some reason each time I add a new video to the USB and then plug it in (front tray above cup holder) the system rearranges all the videos on the USB in no particular order.
Thanks in advance to anyone who may have an answer.
Tags
2019, bluetooth, carplay, coding, display, g05, laser, obd, obdii, remote
